Subject: Motherboard in a 13.3 Xiaomi Ultrabook.
Camera: Seek Pro FF [IOS]
Lens: Seek native
Resolution: 320x240
Image manipulation: non' all is basic Seek App recording on a iPAD2018, no enhancement..
In this heat, where throttling easily takes place in these small thin ultrabooks, I decided to finally thermal-repaste the CPU/iGPU and the dGPU dies with some cheap paste (all sub6USD delivered) I had purchased from Aliexpress a few years back to be used with 9mm and 5.6mm laser-diode-sockets so I could easily interchange the diodes and not have to copper-press fit them.(had 3 kinds of paste, the ones in the picture, used the TG1 I likely should have taken the Shin Etsu
But it did certainly make quite a huge difference in temp-values, and found it pretty wicked that you could actually see what part of the CPU-die there where directed and in play' thrue the thermal-camera and if it was the up part or the down part or it was all over the die or first up and then centered down. (video is while a Geekbench4 benchmark-run is in motion)
and just a thermal view of the heat pipes effectiveness and different palettes. (iOS own screen-recording feature)
