Author Topic: Thermal Imaging - Giza Pyramid  (Read 6910 times)
Offline bookaboo
  • Country: ie
« on: November 10, 2015, 04:56:46 pm »
All over various news items are some "anomalies" found with the Giza pyramids.
http://www.bbc.co.uk/news/world-middle-east-34773856
http://www.dailymail.co.uk/sciencetech/article-3311075/Anomalies-thermal-scanning-Egypt-pyramids.html
http://www.express.co.uk/news/history/618350/Secret-passage-found-in-pyramid-Thermal-scans-show-STRANGE-heat-spots-and-hidden-chambers
All I can find so far are grainy photos of photos, I'd really love to have the images to import into Flir tools for evaluation (as well as the relevant data on ambient and reflected temperatures).
Reading very roughly off the scale (8°C span I think) it does appear that some stones are ~3°C hotter than their neighbours. But there also appears to be a ~2°C variation across the same stone, could be wind factors or thermal load of the "cooler" stone beside it but that strikes me as strange.... an indication that other factors may be at play, as such a large thermal mass as a lump of granite should not have significant temperature variations.
According to engineering tables granite has an emmissivity of 0.45, so reflections are a big issue, perhaps raising questions about the images. On the other hand this figure is much lower than I would have guessed intuitively, perhaps the tables are referring to machined granite. In any case, quite interesting.
Online CatalinaWOW
Re: Thermal Imaging - Giza Pyramid
« Reply #1 on: November 10, 2015, 05:41:16 pm »
Emissivity is supremely sensitive to the surface topography.  It is seldom dominated by the intrinsic properties of the material.  These apparent temperature differences could easily be the result of differences in surface weathering or dirt or differences in orientation of the tiny crystals of the various materials that make up granite.  Another answer would come from an instrument that uses two different spectral bands to estimate temperature, as emissivity is less likely to be wavelength dependent, or better yet, contact measurements with a thermocouple on particular areas which seem to show anomalies.
Offline bookaboo
  • Country: ie
« Reply #2 on: November 10, 2015, 06:03:00 pm »
I was thinking that rough granite would have a high emmisivity, I wonder if the tables I found refer to polished granite like in kitchens etc. , that said there seems to be sky reflections on one of the photos. Although on reflection (pun intended) for the image anomaly to be caused by reflection the heat mass would need to be quite significant, using what looks like a person in the image for scale a reflected heat source would need to be several meters high. The only other reflection possibility I can think of would be the sun? In any case would be easy to verify with different angle images.
The other possibility would be the presence of moisture due to different material or surface. If my understanding is correct a damp stone would hold the heat longer at night.
If the idea of a hidden passage were correct would it show up like this? Assume they took an image in the morning as the sun warmed the cool stone, blocks with nothing behind them would in theory warm up faster as they have no thermal heat sink behind them.
Online CatalinaWOW
« Reply #3 on: November 11, 2015, 12:32:00 am »
While you can get thermal lags like this, it seems unlikely in this case.  If the hypothetical hidden passages were only a few centimeters from the surface they would definitely show such a signal under appropriate conditions.  But a rock wall that thin would have been obvious to any number of other observation techniques that have been used in the past.  If the passages are further from the surface the thermal signal will start to disappear for a couple of reasons.  First the thermal time constant gets long relative to a day.  Secondly, the passages need to be human scale, or else cave-ins or detections be other means would have occurred.  But if human scale, lateral heat spreading tends to blur any signal.
That leaves you with theories only the ancient astronaut or crystal energy crowds could believe.  Theories like "The materials of these rocks were engineered to have different thermal characteristics so that they could be detected once a sufficiently advanced civilization developed."  And they predicted how far in the future that would occur so that the engineered rocks would be on the surface after the theft of the surfacing stones and erosion/weathering of the layers underneath.
As an aside, I thought the pyramids were mostly constructed of limestone with granite only on a few interior walls and features.  Same arguments about emissivity apply to limestone.  If granite is seen on currently exposed faces of the pyramids that is a far bigger clue to interior passages than any thermal differences.
Offline bookaboo
  • Country: ie
« Reply #4 on: November 11, 2015, 08:54:31 am »
Indeed you are right, limestone was used on the outside granite only on the chambers.
The image in question:
I wonder if water could have accumulated somehow increasing the thermal capacity.
But I wonder what they are doing here, surely inside a pyramid chamber will be as close to equilibrium as you can possibly get, even if there was air behind a stone it's not going to have enough heat mass to change the surface temperature, unless as you say its a very thin stone sheet.
« Last Edit: November 11, 2015, 08:59:08 am by bookaboo »
Offline EEVblog
« Reply #5 on: November 11, 2015, 10:56:39 am »
Wow, sounds like they went to town to prove this. It's not like someone with a Flir just showed up and waved it around.
I can remember the UPUAT II robot in the air shaft finding that door. That was exciting. Don't recall whatever came of that.
Offline EEVblog
Offline free_electron
    • SiliconValleyGarage
« Reply #7 on: November 11, 2015, 02:07:48 pm »
Simply tear it down beginning at the top stone. then you'll know for sure.
All that work for a pile of rocks with a long dead guy in it...
Offline DenzilPenberthy
« Reply #8 on: November 11, 2015, 02:21:30 pm »
Wouldn't this be relatively easy to detect with SONAR/ultrasound? Send acoustic pings through the walls and look for reflections caused by the discontinuity where the wall becomes air in the hidden room?
Online nctnico
« Reply #9 on: November 11, 2015, 02:29:30 pm »
I was thinking along the same lines but somehow progress doesn't arrive at all places. For example: yesterday I was reading an article about a completely new invention which allows to measure the depth of burn wounds without physical contact and that everybody was so happy with it. Several years ago I build a device (for a customer) which does the same and much better because it also produces a 3D model of the wound.  :palm:
« Reply #10 on: November 11, 2015, 02:37:56 pm »
Also some colleagues of mine are working on 'cosmic ray muon tomography' I believe this is/will be used to look at the internal structure of the pyramids. As well as the internal structure of the Fukushima reactors/volcanoes/look for very dense e.g. nuclear materials in shipping containers at ports. I don't know a lot about it but I understand it works like an x-ray machine but it uses the passive background level of muons caused by cosmic rays to illuminate an object and create an image.
Offline lapm
« Reply #11 on: November 11, 2015, 03:20:02 pm »
Damn, they found my super secret fusion power core im building to help me take over the world... :-/O Who would have thought some idiots drags thermal camera next to pyramid...  :-DD Humans, they always find ways to suprise you...
Electronics, Linux, Programming, Science... im interested all of it...
Offline TimFox
« Reply #12 on: November 11, 2015, 09:26:53 pm »
I believe that a group headed by Alvarez did muon tomography of the great pyramid back in the 1970's, looking for unknown chambers.
Their final report specified a minimum dimension:  anything larger would have been detected.
Offline TimFox
« Reply #13 on: November 12, 2015, 09:43:17 pm »
A more recent reference with many technical details:
https://repositories.lib.utexas.edu/bitstream/handle/2152/13354/Wright_-_Physics_07.pdf?sequence=2
It includes a citation for Alvarez' work in the 1960s.
Offline EEVblog
« Reply #14 on: November 12, 2015, 10:27:27 pm »
I recall that was well. Nobel prize winner Luis Alvarez did it. Found nothing.
Offline Galenbo
« Reply #15 on: November 13, 2015, 07:44:09 am »
And some call me a philistine...
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline dexters_lab
    • DextersTechLab
« Reply #16 on: November 13, 2015, 08:47:35 am »
sounds like a load of spin to me, Egypt trying to keep their tourist industry going in the midst of the Sharm el Sheikh crisis
Offline EEVblog
« Reply #17 on: November 13, 2015, 10:42:09 am »
Strange how this kind of work and promotion of it has been going on for many many decades then.
Zahi Hawass was the master of promotion. Remember this?
http://www.telegraph.co.uk/news/worldnews/africaandindianocean/egypt/1407589/Live-TV-pyramid-spectacular-ends-in-anticlimax.html
