Author Topic: NEW Windows Software For InfiRay T2, T3 & HTI Thermal Cameras  (Read 31930 times)
Offline RuneHansenTopic starter
« on: August 03, 2022, 07:38:14 pm »
Hello everyone, this is my first post here.
My name is Rune Hansen and I’m an electronics engineer from Denmark with a lot of experience in designing embedded systems, power electronics, all kinds of analog electronics and programming (embedded and software).
For a long time, I have needed a solution for thermal imaging/analysis for general use, but mainly for inspection, characterization and monitoring of thermal profiles when designing high efficiency power electronics or any kind of temperature sensitive electronics.
The main problem, as you might know, is the huge price on thermal cameras and the additional price for the associated windows software. Especially if you want a FLIR camera!
I needed a cheaper solution, without spending +15K dollars on a camera and software, but I quickly learned that there wasn’t really a good “hobby” level solution for high quality thermal imaging with a good usable windows software…
I came across a company called InfiRay, which mainly makes cameras for hunting, but then also sells a series of consumer smartphone cameras. Their smartphone cameras have some amazing specs, but I wasn’t fan of the android app and having to use my phone every time.
I needed something with a windows software!!!
A lot of searching on the internet gave no results (for a dedicated InfiRay windows software or a thirs party), so I bought the InfiRay T3S camera to test its performance and I must say that it is an amazing camera. The only thing missing was a good windows software.
I tried connecting the camera to my computer and what do you know… the computer registered the camera as a standard webcam.
From that day on I decided to start my next project, which was writing my own software for the camera and OH MAN it has been a challenge… went into this with little knowledge on thermal imaging.
Even better, I couldn’t find any information about the camera anywhere, but I notices in the bottom of the image there was a lot of image meta data. So, I decided to figure out was the data meant.
I’m getting tired of writing this, so after 3 month of reverse engineering and trying to understand the data coming from the camera – and a loooooooooooottt of long nights of coding test code and reading into thermographic theory and image processing I finally finished a windows software application for the Infiray thermal cameras.
Application Features include (For version 2.0 and above):
- Full Frame Temperature data
- Max/Min Temperature Tracking.
- Center temperature
- up to 5 Point temperature measurements.
- 3D surface Plot
- Full Screen Mode (External windows for live view and 3D surface plot)
- A LOT of standard and custom colot palettes.
- Region of Interest Box analysis.
- Temperature measurements plot
And much more...
Supported Cameras, As of version 3.7.2:
- InfiRay DV-DL13
- InfiRay T2S+
- InfiRay T2L
- InfiRay T2Pro
- InfiRay T3-Search
- InfiRay T3S
- InfiRay T3Pro
- HTI HT-301
Hope you guys like it :)
It has been quite some work!
Below are some pics of the application :)
I havent really used forums before and i most most Certainly will forget to check for replies.
So if you want to talk or get the software and see the features for the newest versions of the software, Please join the discord server "DIY Thermal Imaging": https://discord.gg/3zq3zXFA8B
On discord i will share the software and you guys can contact me if you find any faults, errors or have any problems with the application
« Last Edit: September 30, 2022, 05:02:50 pm by RuneHansen »
Re: Thermal Imaging Windows Application For InfiRay T2 & T3 Thermal Cameras
« Reply #1 on: August 03, 2022, 07:41:00 pm »
Some more pics:
The following users thanked this post: carpin, Altemir, rek, svgurus
« Reply #2 on: August 03, 2022, 07:43:05 pm »
Last Pics :)
The following users thanked this post: rek, svgurus
« Reply #3 on: August 03, 2022, 07:51:38 pm »
Oh, and I have also designed an enclosure for the T3S/Pro camera, because I hated the “smartphone” camera package and needed a more “lab” looking feel for the camera.
Here it is:
The following users thanked this post: carpin, svgurus, Krist-win
« Reply #4 on: August 03, 2022, 07:57:00 pm »
pics of the final enclosure:
« Last Edit: August 03, 2022, 08:01:30 pm by RuneHansen »
« Reply #5 on: August 03, 2022, 08:07:49 pm »
Last pics, having trouble uploading all at the same time :(
Offline BmaxTom
« Reply #6 on: August 04, 2022, 05:12:49 am »
You did a great job there. I am very interested.
Offline Krist-win
  • Country: cn
« Reply #7 on: August 04, 2022, 05:38:45 am »
Amazing software.
Offline massaker
Re: NEW Windows Application For InfiRay T2, T3 & HTI Thermal Cameras
« Reply #8 on: August 07, 2022, 03:43:45 am »
@RuneHansen will it be also compatible with T3 "Search"-Version of the cam?
« Reply #9 on: August 07, 2022, 12:57:29 pm »
I can add it to the list of supported devices and you can try it out. but i would need you to send me a pic of the windows device manager name for the device :)
« Last Edit: August 07, 2022, 01:57:00 pm by RuneHansen »
« Reply #10 on: August 12, 2022, 12:57:54 pm »
The software has undergone major changes and updates.
Visit the discord server for more information and how to download the application.
The New Discord server address is:
« Last Edit: September 02, 2022, 11:49:42 am by RuneHansen »
Offline DaneLaw
« Reply #11 on: August 12, 2022, 08:13:09 pm »
Big cadeau for your work Rune, and happy to hear that T2L are being implemented    :-+
Infiray T2L  seems like a decent midrange dongle in the 256x192 microbolometer segment.
It's not that expensive.. at around 250 USD with incl. EU VAT and shipping (BG) and the T2L seem to have a manual focus.. - makes a big difference if you wanna use it for a lot of different use cases, and the T2L seems to deliver a tad cleaner picture' than the newer & more expensive T2S plus.. likely because the T2L is focused on a smaller temperature span.
My biggest concern with these dongles is the app.. which seemed to leave a lot to be desired for these Infiray-dongles, and not least for the 2-series (256x192) that appears to be even more app-limited than the 3-series (384x288) and I'm not even sure you can lock a given range temperature span..
« Last Edit: August 13, 2022, 02:22:22 am by DaneLaw »
Re: NEW Windows Software For InfiRay T2, T3 & HTI Thermal Cameras
« Reply #12 on: August 19, 2022, 06:24:08 pm »
The software has seen many revisions and A LOT of NEW features since i made this post.
If you are interested in the software, it can be downloaded via the discord server.
I frequently update the software and anyone can suggest new features or repport issues.
This is the software now (Many New features):
« Last Edit: August 19, 2022, 06:34:58 pm by RuneHansen »
« Reply #13 on: August 23, 2022, 08:05:15 pm »
New PERMANANT Discord Server Link :)
« Last Edit: September 02, 2022, 11:49:24 am by RuneHansen »
Offline thermalengineer
« Reply #14 on: August 31, 2022, 01:58:11 am »
hey i wanna ask again for windows app for all infiray models, thanks!!!
« Reply #15 on: September 01, 2022, 08:18:23 pm »
Im adding new cameras version by version. Is there a camera you have in mind?
Offline LuizBara
  • Country: br
« Reply #16 on: September 01, 2022, 11:03:08 pm »
Hey, nice job with the software, your discord link isnt working, can you send a new one pls!
« Reply #17 on: September 02, 2022, 11:51:03 am »
I have updated the server link throughout this blog.
It should not expire again.
The new link is: https://discord.gg/3zq3zXFA8B
Offline AL0S_SAUR0N
« Reply #18 on: September 10, 2022, 11:33:51 pm »
Amazing software Hansen!
I also would love to test it out. I own the T3-Search version.
I looked at the windows device manager name and the name is just "T3-Search" (without quotes). With this info will be enough to help you get the T3-Search working on a future update?
Thanks for the hard work!!  :D
« Reply #19 on: September 11, 2022, 07:45:18 am »
Yes, I will add it :) If you come on discord later we can try it out.
Offline smile
« Reply #20 on: September 13, 2022, 11:31:07 pm »
Can anyone tell me if the temperature range for T3 series is software limited? Any hopes to have increased range for T3S or T3Search?
Offline Long may the sunshine
  • Country: cn
« Reply #21 on: September 20, 2022, 02:07:25 am »
OK,I now get a new problem.
software report the connect error. CAN anyone help? :)
  • Country: cn
« Reply #22 on: September 20, 2022, 02:10:06 am »
 |O
I guess it's the matlab version problem.but i'm not sure.
« Reply #23 on: September 21, 2022, 09:29:46 am »
Could you put the issue on the discord server. I rarely look at messages here. And could you provide an English version of the error Please.
« Reply #24 on: September 22, 2022, 01:36:40 am »
oops, thank you for your information. Those help me a lot!
