Author Topic: Thermal transparent material  (Read 931 times)
Offline danilsTopic starter
« on: January 16, 2023, 02:21:08 pm »
Dear all,
I have to make some small test enclosures to test device temperature into their ultimate enclosure.
In order to do this I have to make the top part of this test enclosure with a thermally transparent material to point the thermal camera above.
Can you suggest which material (easily available and not too much expensive) I can use?
Many thanks
Daniele
Offline markb1980
  • Country: cz
Re: Thermal transparent material
« Reply #1 on: January 16, 2023, 02:47:12 pm »
There are thermal inspection windows which are made for that purpose: https://www.flir.eu/products/ir-windows/
Pentester, Digital forensics examiner, Data recovery technitian, Author for various books
Learn thermal imaging: https://www.amazon.com/dp/B0B5KXF41Q/ | https://www.facebook.com/groups/1816479168568552 | https://thermal-image-samples.com/thermal-pixel-peeping/
The following users thanked this post: danils
Online wraper
  • Country: lv
« Reply #2 on: January 16, 2023, 03:09:17 pm »
You can put a thin polyethylene bag/film over a frame.
Offline RO
« Reply #3 on: January 16, 2023, 04:28:57 pm »
Offline Fraser
« Reply #4 on: January 16, 2023, 06:52:42 pm »
FLIR disposable lens protectors use polyolefin film. I recommend 12 micron or 15 micron thickness. It is easily bought as food and product shrink wrap ! Not expensive and applying some heat will shrink it so when in a frame it pulls tight.
Be aware that if you create a ‘top cover’ made wholly of polyolefin film, heat will radiate through it easily, unlike if a solid, thermally opaque or reflective, top cover were fitted. This could effect the validity of your measurements. A small window in a solid cover that exposes an area of interest may be a better idea.
The film will introduce a small measurement error due to its less than perfect transmission characteristics, but you can experiment with it to adjust your temperature measurements. Some cameras even have the menu option to input a thermal windows transmission figure for automatic correction to measurements.
Fraser
« Last Edit: January 16, 2023, 06:54:23 pm by Fraser »
