I need to do some analysis of thermals for some rack-mount computer servers under load.
Essentially, I need to power on the server, and run some load tests - and ideally capture a video of the thermal either inside the chassis, or for the front/rear cooling vents during the test.
I've looked at something fairly cheap like the FLIR E4 - however, this only takes still images, not videos.
Is there anything that can either record video itself, or that can connect to a PC/Mac to record thermal video files?
(Not sure what a thermal video file would be like - but can you embed point temperature data somehow over time?)
Thanks,
Victor
