Author Topic: Amber/Raytheon Triple Field of View (TFOV 60/180/500 mm) Lens  (Read 5687 times)
Offline Fraser
Re: Amber/Raytheon Triple Field of View (TFOV 60/180/500 mm) Lens
« Reply #25 on: June 20, 2024, 10:21:40 pm »
Something I am seeing from the files provided with UserMenu is file names "GALPRC" and "GALUPRC". I am thinking GALPRC is an advanced menu and GALUPRC is a standard menu. I hope there is no password barrier to accessing any advanced menu that may exist. I see that the GALUPRC ICD file mentions only the DFV lens whilst teh GALPRC ICD mentions DFV and TFV.
I tested both of my Radiance 1 cameras with UserMenu running on an era appropriate 80286 PC to see if that would work. I still had communications test timeout errors with NIL data received, so it is not a case of needing the right age of computer to use this DOS software.
Thank you for the file. Have you had UserMenu3 working with a Galileo ? I hope the copy of UserMenu3 that I have is not in some way faulty  :palm:
Fraser
The following users thanked this post: MrSheep
Offline MrSheepTopic starter
« Reply #26 on: June 20, 2024, 10:24:19 pm »
Yeah I have not tested usermenu myself as I have been using the TWI software with the Galileo/Radiance HS. It is on my to do list though. I have to setup Dos in a box and hopefully I can communicate via that. Or else I have to find something old enough to run MS-DOS haha.
Offline Fraser
« Reply #27 on: June 20, 2024, 11:12:14 pm »
I shall have to try the TWI software with my Radiance 1 to see if it complains about not seeing a Galileo HS connected. I should have done that before now :palm: That would show whether there really is a camera identity code present in the command protocol. Such a pity if there is and it is embedded in the UserMenu EXE file.
Fraser
« Reply #28 on: June 20, 2024, 11:15:13 pm »
The TWI software is very specific with the firmware. Maybe typing 3.0 will work? But not sure. I find using RTool's Radiance 1 GUI the best. You dont need a license to run just the Radiance 1 software. Also I will update you on the Data Acquisition of the Radiance 1. If I can get the pleora LVDS working with the Radiance 1 you will most likely be able to use it in FLIR ResearchIR
The following users thanked this post: Fraser
« Reply #29 on: July 15, 2024, 07:40:02 am »
Huge progress on both figuring out Usermenu as well as the TFOV menu. Given that there were no instructions in any of the usermenu version. I decided to just take a look at all the files itself under a text editor.
I came across a few batch files found in an older version of usermenu called GAL158 (GAL probably means Galileo :D). They had a weird format so to investigate deeper I went into Usermenu itself. After firing up Usermenu and hitting F1, I found an interesting function under the Direct Menu Manipulation Commands:
;mn, ‹filename>, ‹menuname> (diagnostic user only).
After comparing this structure to the batch files I found that the command:                ;mn,Galuprc,MainMenu
came up a alot. So when firing up Usermenu.exe from Menu3 in DosBox I typed in (exactly as seen):    ;mn,Galprc,MainMenu
And boom it showed the advanced menu. I chose this specific command because of what @Fraser found earlier in Galprc
Also notice the difference between the titles in the attached photos. One says Usermenu Menu: Radiance HS and the other says Diagnostic Menu: Radiance HS
Once I get this connected to a serial monitor I will see what kind of commands (most likely hex) are being sent out. And hopefully this will once and for all solve the mysterious TFOV commands :)
But it is pretty late so I will investigate tomorrow haha.
« Last Edit: July 29, 2024, 02:26:23 am by MrSheep »
« Reply #30 on: October 31, 2024, 07:03:01 pm »
Got around to playing with the .HEX File I extracted from the main 87C51 chip and these are the results. Plan is to play around with it in the a dev board.
