Author Topic: Thermal eye 4500, 3600AS  (Read 4886 times)
Online Fraser
Re: Thermal eye 4500, 3600AS
« Reply #25 on: August 29, 2020, 11:56:49 am »
The 3500/3600 and 4500 may be configured via their USB port using the Thermal Eye GUI.
See my post on the L3 X50 That I repaired......
https://www.eevblog.com/forum/thermal-imaging/raytheon-l-3-thermal-eye-x-series-repair-new-patient-for-fraser-x50/
Fraser
« Last Edit: August 29, 2020, 11:59:56 am by Fraser »
Cogito, ergo sum
Offline Collat3ral
  • Country: si
« Reply #26 on: September 17, 2020, 09:30:21 pm »
This is going to be a shot in the dark but anyway:
Anyone selling a narrower lens for the 4500 core? What came with the 4525 or 4512? Willing to put mine in for trade.
The alternative is building a zoom lens from znse, but that would add about 10cm infront of the camera
Online Hydron
« Reply #27 on: September 19, 2020, 09:13:17 pm »
Do you know what lens it came with? A relatively wide angle one I assume?
Fraser or others - do you know whether the 4500AS and 3600AS share the same lens mount, and whether the optics are compatible?
If they are compatible then I might consider swapping my 3600AS lens for a wider 4500AS one - my 3600AS FoV is a bit narrow for my applications. I do not know the exact FoV/focal length of the one I have, though if there is interest I can probably work it out.
Online Fraser
« Reply #28 on: September 19, 2020, 09:35:32 pm »
Sorry I do not know whether lenses are interchangeable between the 4500AS and 3600AS.
A recalibration of the core would normally be needed as well to achieve a flat field with the different lens Characteristics.
Fraser
Cogito, ergo sum
Offline Collat3ral
  • Country: si
« Reply #29 on: September 28, 2020, 05:24:53 pm »
@Hydron It's a 50° lesn. Way to much for my usage.
@Fraser (or anybody) I've found one on ebay, that has a larger window.
The seller doesn't know anything, only what's in the pictures
Online angelortega
« Reply #30 on: October 17, 2020, 05:55:41 pm »
i have thermal eye cores in my collection 3500as 4500as and the 4512as the all work well and some are radiometric  it would be nice to turn it off for a clean image view. so i added the extra lines in there connectors to plug them to the usb  but i do not have the software . can anybody help me find it. i added the polarity and zoom buttons the the 4500as core from the eagle 2 firefighter cameras, that same connector i tried on the 4512as core from a nvti multicamera unit i just got a week ago from ebay for 125-bucks$$ and found it has a higher zoom range that works great with the bigger lens it has, it would be nice to tryout the software for my cores to add to my collection i also have my first real thermal camera the atn x150 xpfrom 2009  i would like to thank fraser for the pictured he show of the repair of the same type i own  i was nice to see the inside working design layout
