Cameras that see into the THz range don't operate as direct microbolometers. They add another step onto this Pile Of Detection™ - RF(ish) to heat conversion, directly on the pixel. They do this by depositing an antenna on each pixel, with what effectively is a dead short across it. The radiation is then focused onto the sensor(believe it or not, you can focus it using some polymers!), at which point your sensor isn't looking at emitted heat, but rather an "afterimage" of what the RF is heating up on the sensor. Essentially, operating in what normally is a fault mode, where a hot object leaves a long lasting(minutes) mark on the sensor.
