Hi Guys,
Thanks for your posts, a few minutes ago I´ve tested it again, in the Livingroom.
Holding the cam in direction to the lamps on the ceiling, focussing it clear and sharp...looks good.
After a while, maybe it´s the minute, it stucks shortly (refresh? Can´t hear a sound), then you see what´s actual on the screen plus again the lamp but somekind of inverted.
And it stays, even when you turning to something else in the room.
After a while, maybe again the minute (must measure it), it vanish.
Hopefully it´s something which can be fixed...
Martin
