Hello,
I own the following thermal lens:
I was speaking shortly about it in this thread:
https://www.eevblog.com/forum/thermal-imaging/my-first-little-diy-thermal-camera-project/But i would like to especially know more about this lens:
The only things i know are that:
- the diameter of this Germanium (i guess) lens is (optical diameter) 40mm,
- the focal length is around 40mm,
- the front surface is convex, and the rear/back surface is flat,
- the apparent average thickness of the lens by itself (without knowing if it is a single element or a 2/3... elements) is around 8mm,
- the body (around 90mm total length) is in a kind of ceramic, brown/cream outside, black mat inside, with a connecting rear metallic thread (kind of stainless steel)
No marks, brand,...
no focusing mechanism,
Therefore, it would be great to know more about it...
In advance, as usual, thank you a lot for sharing your knowledge and culture here.
Best regards.
Stéphane
