Hi, is it possible to get Victor 328B to work in Linux?
I tried it with RaspiOS (Linux distributive for Raspberry Pi) - and the best I could get was a lot of "static" and a contrast object barely visible once every ~5 sec. Although with Windows 10 it works perfectly fine.
Apparently, the built-in driver for UVC cameras identified its resolution as 160*120 instead of 256*192 and framerate as 5 Hz instead of 25 Hz, maybe that's the reason, but I have no idea how to resolve it.
Any thoughts?
UPD: Everything is working fine, it was just a faulty USB hub.
