Author Topic: What's this thing on the microbolometer?  (Read 977 times)
Offline Logan
« on: October 09, 2021, 03:09:52 pm »
Hi guys.
I found a metal thing on my Scott's sensor package, it's like metal stick.
Please look at the 3 pictures, they were taken by Fraser, but we have a similar model. I marked that thing with an arrow.
That thing seems only exist on some microbolometers, not all models.
Does anyone know what's that for?
Thanks.
Online Fraser
Re: What's this thing on the microbolometer?
« Reply #1 on: October 09, 2021, 04:16:06 pm »
From memory it is the getter firing pin that is used to improve the quality of the vacuum during production.
Fraser
The following users thanked this post: Logan
Online Fraser
Online Fraser
« Reply #3 on: October 09, 2021, 04:32:38 pm »
The manufacturer of getters for sensitive applications such as microbolometer arrays states the use of porous getters and films that operate at room temperature. I believe these are what you find in modern microbolometers…
https://www.saesgetters.com/products-functions/applications/sensors-and-mems
I cannot see an evaporative getter being used inside a microbolometer and the exact nature of a microbolometer getter that requires an activation pin is not known to me. It is likely detailed in microbolometer research documents though.
Fraser
Online Fraser
« Reply #4 on: October 09, 2021, 04:41:22 pm »
Detail of a machine used for sensor assembly, including microbolometers. It states the getter is either heat or electrical activation.
https://bseteq.com/mems-packaging/
I assume in a microbolomter the getter material may be heated using a voltage and associated current applied to the getter pin but unlike a thermionic valve, it is a more refined process that activates the getters vacuum contaminant adsorbing properties without splattering material all over the interior of the module !
« Last Edit: October 09, 2021, 06:40:08 pm by Fraser »
Offline Bill W
    • Fire TICS
« Reply #5 on: October 09, 2021, 04:46:17 pm »
Yes, it is a firing / refiring pin.  Big as it might be an amp or two going through it.
The earlier ULIS sensors also had such an arrangement although sometimes it was in the normal pinout.
The instructions had dire warnings about overheating the whole package if you dared to try using it.  I think they recommended a copper block jig to clamp the sensor.
Never had much luck using it as a refiring repair, no doubt added in case it was useful as the whole peltier structure can outgas a fair bit.
Bill
« Last Edit: October 09, 2021, 04:48:24 pm by Bill W »
Offline Logan
« Reply #6 on: October 11, 2021, 06:42:16 pm »
Thank you guys.
I was thinking if we can repair a sensor which lost vacuum, so this is the answer ;D
Offline Spirit532
  • Country: by
    • My website
« Reply #7 on: October 27, 2021, 04:55:30 pm »
Thank you guys.
No, if it goes up to air then the activated getter will immediately expire, and will need replacement.
It's a start-once run-many component.
