Author Topic: Yet another cheap thermal imager incoming.. Seek Thermal  (Read 782579 times)
Offline LesioQ
  • Every king should be naked.
Re: Yet another cheap thermal imager incoming.. Seek Thermal
« Reply #2375 on: January 02, 2018, 09:15:49 am »
Guys,
How can I induce firmware reload to Seek Thermal XR camera flash IC ?
I mean 1.3.0.0 version, built-in into apk.
Either Android way or Windows-way.
Offline methael
  • Physics student at york university
« Reply #2376 on: August 23, 2018, 09:23:15 pm »
Hello everyone,
I have looked at the code for seek thermal compact, and everyone seemed to have written their code interfacing the iAP interface. I am wondering why this interface and not the other that is available?
https://github.com/sgstair/winusbdotnet
If you look at the lsusb that was posted here(in the link below) it says that theres another interface available. (the interface is called com.thermal.pir206)
https://github.com/zougloub/libseek
I am wondering this because i had to write c++ code to communicate with this camera and i also used winusb to do it. I decided to use iAP interface cause everyone else used it. I want to be able to run 2 seek thermal cameras in parallel.  I have done that using multi-threading however i realized that there seems to be some sort of race condition. When using winusb_readpipe function with two seek thermal cameras, the function sends the data to a unique winusb_interface_handle however the PipeID remains the same. So i think that two threads might be racing for this function. So i was thinking to communicate with the second camera run on the other interface because it has another pipeID. However when i do winusb_controltransfer/winusb_writepipe/winusb_readpipe using the second interface i will get windows errors like "Invalid access to memory location",A device attached to the system is not functioning" and "The parameter is incorrect". I am confused as to why?
Any help is appreciated thank you!
Edit:
I found this link on endpoints and pipes.
https://docs.microsoft.com/en-us/windows-hardware/drivers/usbcon/usb-endpoints-and-their-pipes
It makes me think that my conclusion on the problem is correct. As there are 2 devices hence 2 endpoints but only 1 pipe. So my 2 threaded readpipe functions are just racing for the pipe.
« Last Edit: August 24, 2018, 02:30:01 pm by methael »
Offline IwuzBornanerd
« Reply #2377 on: August 25, 2018, 07:28:38 am »
I'm not clear from your post whether you are actually getting data from both cameras.  Are you getting images from both cameras but erratically?  What do you observe that makes you think there is a race.  One pipe for two distinct devices seems crazy and makes me wonder if you got 2 handles to the same device (which does not make sense to me either but might be more likely than the one pipe for 2 devices).
I have run 3 Seeks simultaneously using 3 separate instances of my C/C++ code and did not notice any problems, but that is using libusb under Debian Linux and I have not tried running multiple cameras in separate threads of one program.  i also don't process many errors...
I am not opposed to exercise, unless it is an exercise in futility.
Offline meanie2
« Reply #2378 on: October 07, 2019, 08:31:47 pm »
It seems some people are using hti apk on the seek...
http://4pda. ru/forum/index.php?showtopic=851614&st=960#entry88641913
http://htimeter.m.icoc. me/en/h-col-103.html
Offline Uho
  • Country: ua
« Reply #2379 on: October 07, 2019, 08:50:15 pm »
The inclusion of an additional menu. Now you can see the frame rate.
https://youtu.be/5ZnWuD_yQ2I
Offline tonykids
« Reply #2380 on: October 08, 2019, 01:19:54 am »
I tried that ,it did work ^-^
Offline pauledd
  • Riesige Gepanzerte Luftschiffe
« Reply #2381 on: October 08, 2019, 10:06:57 am »
I tried that hti APK on my Android with my CompactPro but it was quite disappointing... The Seek Software is much more sophisticated and they also seem not to handle deadpixel substraction. I discovered
four dead pixels with their app which I've never seen on the seek app...
Would be interesting to know how it comes that they seem to use the same Software to Hardware communication as the seek devices... Maybe the are just selling rebranded Seek devices?
human being - without Windows® - excuse my bad english
Offline tonykids
« Reply #2382 on: October 08, 2019, 12:22:05 pm »
SEEK modules "C2 Starter Kit" https://detail.1688.com/offer/580307068706.html
it seems that
HT-101=SEEK COMPACT
HT-101=SEEK COMPACT PRO
HT-A1=SEEK SHOT
HT-A2=SEEK SHOT PRO
it's interesting that HT-101/A1 is 220*160 but seek is 206*156
HT-301=xinfrared T3S :)
Offline Cat
« Reply #2383 on: October 08, 2019, 06:29:29 pm »
Should probably be HT-201 = SEEK COMPACT PRO ;)
On the Internet, nobody knows you're a cat.
Offline meanie2
« Reply #2384 on: October 10, 2019, 08:37:26 am »
Anyone can advise if the pc cable for seek compact is available on amazon.com?
Or advise how to DIY a pc cable?
I only saw the YCS extension cable there.
Seek Compact Camera Cable
http://www.ivytools. com/v/vspfiles/photos/seek-compact-cable-2.jpg
https://seekreveal.com/
http://www.ivytools.com/
There is even a holder with tripod mount for the Seek Compact.
Seek Compact Camera Clip
http://www.ivytools. com/v/vspfiles/photos/seek-compact-clip-4T.jpg
« Last Edit: October 10, 2019, 08:39:18 am by meanie2 »
Offline rev0
« Reply #2385 on: March 17, 2020, 05:42:19 am »
Sorry to revive an old thread, I was wondering if anyone has been able to make an adapter to use the iOS/lightning connector version on PC. I bought one of these at a better price for iOS at the time, and only just discovered these awesome PC apps and would love to give that a try. I'm an Android user and basically only have an iPhone dedicated for when I use my thermal cam which is a bit silly.
I attempted to use an old iPhone power bank PCB and wire up a USB cable to its female lightning connector but nothing is detected on PC. I have GND (pin 1), D-, D+, NC, and 5V (pin 5) connected, following this for reference: https://www.quora.com/Are-pins-1-5-on-the-Apples-Lightning-Connector-used-to-pass-the-dc-voltage-to-charge-iphone-ipad
« Last Edit: March 17, 2020, 05:45:32 am by rev0 »
Offline tonykids
« Reply #2386 on: March 17, 2020, 01:55:02 pm »
IOS does not use pin 5 to provide power to otg device,it uses pin4 and/or pin 8,you should connect USB's 5V to SEEK's pin 8 or pin 5(do your own risk)
I opened the SEEK camera and direct solder the wire on PCB(IOS and android PCB are the same ),it work well
Offline RoshV
« Reply #2387 on: April 14, 2020, 07:37:16 pm »
Sorry for reviving this old thread, I am new to using SEEK thermal and have been getting nowhere with available python codes on Github.
I am trying to run it on RPI4, with python 3.7 and SEEK thermal compact XR
I get this error:
 File "seek.py", line 150, in <module>
    disp_img = get_image()
  File "seek.py", line 104, in get_image
    send_msg(0x41, 0x53, 0, 0, '\xC0\x7E\x00\x00')
  File "seek.py", line 32, in send_msg
    assert (dev.ctrl_transfer(bmRequestType, bRequest, wValue, wIndex, data_or_wLength, timeout) == len(data_or_wLength))
  File "/home/pi/codes/lib/python3.7/site-packages/usb/core.py", line 1043, in ctrl_transfer
    self.__get_timeout(timeout))
  File "/home/pi/codes/lib/python3.7/site-packages/usb/backend/libusb1.py", line 883, in ctrl_transfer
    timeout))
  File "/home/pi/codes/lib/python3.7/site-packages/usb/backend/libusb1.py", line 595, in _check
    raise USBError(_strerror(ret), ret, _libusb_errno[ret])
usb.core.USBError: [Errno 32] Pipe error
The C++ version from https://github.com/maartenvds/libseek-thermal works well.
Many thanks for your help
Offline jumpy9734
« Reply #2388 on: April 14, 2020, 10:30:08 pm »
I've wanted to ask, are there any Linux binaries of SeekOFix?
Offline frenky
  • Country: si
    • Frenki.net
« Reply #2389 on: April 15, 2020, 11:50:47 am »
Emm no... But something usefull could be on github: https://github.com/search?q=seek+thermal
