Author Topic: Yet another cheap thermal imager incoming.. Seek Thermal  (Read 767686 times)
Offline Uho
  • Country: ua
Re: Yet another cheap thermal imager incoming.. Seek Thermal
« Reply #1950 on: July 31, 2015, 05:24:26 pm »
x3 is composed of two lenses. First ZnSe 25mm. Second Ge12.5mm. The image flips.It works well with Seek.I plan to sell. The prototype for HemaVision too X3. It consists of three lenses. It works with Seek. I think that working with other thermal imagers. He has a latter lens 20mm. We need to test. Who knows the diameter of the lens from Flir E4?  Using a telephoto lens X3 for Seek. Video.
https://youtu.be/kZtH9Nq4AHk
« Last Edit: July 31, 2015, 05:56:03 pm by Uho »
Online Fraser
« Reply #1951 on: July 31, 2015, 06:05:18 pm »
@Uho,
Very nice work. I applaud what you have achieved with simple, off the shelf lens types. Your lens housings also look neat. Are they made on a lathe, printed or constructed by some other means ?
From what you have said they invert so they are a Keplerian design. I have commercial lenses that are also Keplerian and I will either need to introduce erector lens groups or correct the captured images in post production.
If you are going to sell your designs you may wish to design adapter brackets to clip them onto the new FLIR ONE as it will be another healthy market for you. If the lenses could include an erector element pair they would be more marketable to the general public. I was going to use a pair of 12.5mm or 25mm FL Plano convex ZnSe lenses for the task. The down side, as you know, will be the extra physical length of the lens. The only way I know to shorten the length is to use all Germanium lens elements due to their large refractive index.
As I said..... Excellent work....... Respect :)
Aurora
« Last Edit: July 31, 2015, 06:40:32 pm by Aurora »
Offline Uho
  • Country: ua
« Reply #1952 on: July 31, 2015, 06:32:39 pm »
Thank You. I tried to make nice. I made on a lathe. Lens X1.7 not turns. I used a negative lens. It is expensive and rare. It is difficult to buy. And it does not allow a large increase. The first lens has to be very large diameter. Why did only one lens for tests.
Online frenky
  • Country: si
    • Frenki.net
« Reply #1953 on: July 31, 2015, 08:08:49 pm »
Do any of you have a good optics simulation software?
I was trying to simulate Seek's 3.8mm lens with additional 50mm ZnSe...
My ultimate goal is to find a configuration to convert Seek's non focus camera to a focusable one.
Could you help me with that? I have one 50mm and one 100mm ZnSe lens.
The only free (non java) software that I have found is this:
https://chrome.google.com/webstore/detail/ray-optics-simulation/egamlemiidmmmcccadndbjjihkcfiobh?utm_source=chrome-app-launcher-info-dialog
This is simulation of 50mm ZnSe lens 30mm away from Seek's lens:
Offline miguelvp
« Reply #1954 on: July 31, 2015, 08:18:51 pm »
When I did look at something that I needed for optics a long time ago I found out about OSLO
https://en.wikipedia.org/wiki/Optics_Software_for_Layout_and_Optimization#Free_Educational_Product
http://www.lambdares.com/oslo
Edit: Link to the OSLO-EDU version:
http://www.lambdares.com/oslo-edu
They had a free version, it was hard to learn and I forgot how to use it after I was done with it.
But I bet there are other free alternatives now.
Edit: and other easier alternatives for that matter.
« Last Edit: July 31, 2015, 08:22:15 pm by miguelvp »
Online frenky
  • Country: si
    • Frenki.net
« Reply #1955 on: August 01, 2015, 01:30:27 pm »
Tnx. I'll check it out.
Offline lod
« Reply #1956 on: August 03, 2015, 02:10:34 pm »
I have unraveled the fix that Seek put in to correct for the edge gradient problem.
Essentially they use any shot of a flat surface to calibrate a correction matrix which is applied to all subsequent images.
This is done by taking blocks of sixteen pixels and calculating the average value.
These average values are again grouped into blocks of sixteen and the range between the highest and lowest value determined. This range is used to determine if the image is a flat surface to be a basis for updating the calibration.
The blocks of average values are again averaged, to get a relatively crude map of the image.
To create the correction matrix a full image is created by interpolating out the crude double averaged values. 7/8ths of the correction matrix is the previous value, 1/8th is the new interpolated values. This low pass filter prevents any glitches from having too much impact.
The corrected image is created by subtracting the correction matrix from the original.
To properly document this I have created an Octave/Matlab script. The script is not an exact reproduction of Seek's code but shows the algorithm which was used.
To get data into Octave I adjusted Seek_2.0.py by Cynfab to export a Matlab data file, I couldn't figure out how to work with the generated PNG images.
Source code, including invocation instructions, are on github:
https://github.com/lod/seek-thermal-documentation/tree/master/scripts/thermal_gradient
Floor - Before correction
Floor - After correction
Face - Before correction
Face - After correction
Online Fraser
« Reply #1957 on: August 03, 2015, 02:16:14 pm »
Excellent investigation work.
Thank you for finding the answer to this outstanding question.
Aurora
Offline in.Vitro
« Reply #1958 on: August 06, 2015, 10:05:50 am »
Hi everyone :)
at first: sorry for my bad english :P
Today UPS deliverd my Seek (Non XR-Version). Actually I want to buy the FLIR One (second gen.) but its very hard to order here in Germany... *sigh* I gived up to waiting  :(
And thats why I orderd the Seek for iOS. (FYI, I ordered the XR-Version 3 Weeks ago but sell it again and orderd the non XR Version to days ago!)
But today there was a little surprise: The non XR-Version has a focus ring!  :scared: I'm not sure if Amazon send me a wrong product.... I dont think so! Or it is a new Version. Because the Ring is much smaller!
Its hard to tell if the Focal length is similar to the XR-Version.. maybe you guys can help me
« Last Edit: August 06, 2015, 10:07:38 am by in.Vitro »
Online frenky
  • Country: si
    • Frenki.net
« Reply #1959 on: August 06, 2015, 10:19:46 am »
Thanks for sharing.  :-+
This is definitely a new model:
Offline in.Vitro
« Reply #1960 on: August 06, 2015, 10:38:04 am »
But the question is: Why is it labeld as "non-XR"? I mean, its obviously the XR because when I strech my arm and make a "selfie", my whole face filled the frame (yes, I have short arms :D )
The Ring on the "new" Model is about 5mm thick.. I would gues on the XR is the thickness about ~7,5mm? right?
Online frenky
  • Country: si
    • Frenki.net
« Reply #1961 on: August 06, 2015, 10:41:23 am »
Take a look at writings on the module.
Perhaps there is EAN or model name somewere on the module?
Online frenky
  • Country: si
    • Frenki.net
« Reply #1962 on: August 06, 2015, 10:56:28 am »
And take a look at the box to. EAN is on it for sure.
Offline in.Vitro
« Reply #1963 on: August 06, 2015, 11:01:58 am »
On the Modul is just the Serial Nummer, CE and this annoying trash bin.
the EAN is  8 55753 00518 1
Offline in.Vitro
« Reply #1964 on: August 06, 2015, 12:00:12 pm »
Good News!  ;D
Its a new Model (Hint: look at Amazon ;) )
this little sucker has impressive macro capability!!
I hold the Cam ~3cm above the PCB
Online frenky
  • Country: si
    • Frenki.net
Offline jadew
« Reply #1966 on: August 20, 2015, 10:56:58 am »
Just got a new phone (an S4 mini) and it turns out it's not compatible with it. Any ideas on why that may be? It's very frustrating.
Online frenky
  • Country: si
    • Frenki.net
« Reply #1967 on: August 20, 2015, 11:00:41 am »
Offline jadew
« Reply #1968 on: August 20, 2015, 11:06:46 am »
That's a bummer. I find it hard to believe that whatever SoC they are using in this phone, doesn't have support for USB host. Is that really the case or are they crippling them on purpose?
Online frenky
  • Country: si
    • Frenki.net
« Reply #1969 on: August 20, 2015, 11:10:15 am »
I'm not sure you should compare it to other phones with the same SoC.
P.S:
Another list of phones with USB Host:
http://goo.gl/47fjHo
EDIT: I did a quick search and it seems that none of the phones with "Qualcomm MSM8930AB Snapdragon 400" have USB Host support.
http://goo.gl/SmBdQS
« Last Edit: August 20, 2015, 11:13:28 am by frenky »
Offline jadew
« Reply #1970 on: August 20, 2015, 11:12:55 am »
P.S:
Good idea, thanks.
Edit:
A quick look over some threads at xda-developers.com would suggest that they crippled them on purpose. The hardware supports it, but they're not providing any power from the phone, so you would 1) need firmware and 2) have to provide power to to the device from an external source.
« Last Edit: August 20, 2015, 11:19:59 am by jadew »
Online frenky
  • Country: si
    • Frenki.net
« Reply #1971 on: August 20, 2015, 12:25:57 pm »
Yeah I was researching in that direction too for my old LG One P500 and HTC Desire.
But in the end I decided that is to much trouble because there is plenty sub 150€ phones that support it out of the box.
Sub 150€ phones:
http://goo.gl/avdcSs
Offline encryptededdy
« Reply #1972 on: August 20, 2015, 08:30:05 pm »
Yeah, the same issue exists with the Nexus 4 - data but no power.
I guess that's why the new FLIR One has its own battery.
Offline minim
  • Country: no
« Reply #1973 on: August 24, 2015, 06:43:08 pm »
I have read through 26 pages of this thread and I will keep reading but I just wanted to check if anyone might have tried to do the same as I want to do with this sensor and get a analoge output.
I have been helping my neighbour locating his animals on two occasions where people forgot to close the fence and once when someone sabotaged the fence and let his animals out in the mountain. I do this by flying with a RC-plane rigged with a video link and flying over a large area looking for them. I've seen that a SAR group here in Norway had a drone equipped with a FLIR camera and when searching for people or a animal herd they seem to find them really easy due to this expensive thermal camera ($4-5k). So I wanted to install the same system on my drone and help local farmers and possibly the local SAR group with search missions. I'm funding this on my own and it's not for the purpose of making money so I can't really afford to pay $5-10k for a camera. This $250 camera and some gear for making analoge video out would be perfect. I guess the purpose of my mission isn't on-topic but the analoge video out part might be a little bit on topic :)
Edit: is raspberry pi and using the audio port for analoge video out an option or isn't it possible to use the PI to read video from the sensor?
« Last Edit: August 24, 2015, 07:40:49 pm by minim »
Online Fraser
« Reply #1974 on: August 24, 2015, 07:47:21 pm »
Minim,
The distance capability of the SEEK camera is quite limited. The Microbolometer Array passes its analogue pixel levels to a Read Out IC (ROIC). This ROIC is part of the Microbolometer core. The output from the ROIC is not analogue on the SEEK.
The only way to get an analogue signal from the SEEK for your needs is to uses a small dedicated computer such as a Raspberry Pi to translate the image to composite format.
Drones such as you have described normally use a FLIR TAU or similar. There is good reason why they need such expensive cameras.
Aurora
