Hello,
Thank you Fraser for your feedback and CaptDon for having started this thread.
Just a short passage for sharing my feeling about this kind of old Russisn/USSR night vision device.
I was starting my teaching in this NV world with an old T3C-2 equipped with a gen 1 tube from the company EKRAN (if i rmember well), wit a lens "Helios" 100mm/2. It was a nice unit quite capable in urban environment with light pollution but far to be usable in passive mode under "starlight" conditions.
I was nevertheless able to improve its performances in passive mode, by making two "modifications:
- the first was to use faster lens (50mm/1.2 for instance, or faster....)
- the second was to modify a bit the voltage DC supply, in order to increase the gain of the tube.
Typically the common concept is to use a low voltage oscillator and to inject the alternatif signal produced by this oscillator in a voltage multiplier (diode bridges in cascades..). The resulting DC high voltage/low current is applied between the photocathode and the "phosphore screen", with the using of a voltage divider for feeding an electrostatic focusing lens assembly.
The tube from the T3C-2 is polarized, between the photocathode and screen, with 19kV voltage. By increasing this value, it is possible to accelerate more the electrons emitted by the photocathode. They will strike with more kinetic energy the "phosphor" screen. It will result in more brightness in the final observed image.
What i did was simply to feed the oscillator from the elctronic on board with, instead of using the 2xAA batteries (2X1.5 serial = 3V), a 9V batterie with a classical good old variable voltage regulator LM317, with a muliturn potentiometer. Therefore, i was able to increase slowly the voltage beyond the 3V required, and by being very progressive for avoiding to generate sparkles, electrical breakdown, i was able to go a bit over 5V, which would correspond to a larger value than the initial 19kV.... The gain was greatly increased, the locust or bee noise also....
By using a fast lens and this little trick, i was able to use this tube for doing some astronomy and to start to do terrestrial night vision in more darker conditions...
Sorry for the digression. Hoping it can be useful.
Thank you.
Regards.
Stéphane
