Author Topic: Unknown part  (Read 3104 times)
Offline shock__Topic starter
Unknown part
« on: September 15, 2018, 12:39:24 pm »
Hey there,
I'm currently in the process of partially reverse engineering a stamped card reader and stumbled upon a part I can't exactly verify.
The PCB the part is on can be dated to early/mid 70s and was at least designed in Germany.
Any ideas?
« Last Edit: September 15, 2018, 12:41:17 pm by shock__ »
Offline madires
  • A qualified hobbyist ;)
Re: Unknown part
« Reply #1 on: September 15, 2018, 01:54:07 pm »
An image with a higher resolution would be helpful. At first glance it looks like a broken resistor. Have you checked it with a DMM?
The following users thanked this post: Beamin
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
Re: Unknown part
« Reply #2 on: September 15, 2018, 02:17:35 pm »
Looks to be a diode, which says 141, 242, 343, 747. Poor resolution an poor colours. Please resend.
Voltage does not flow, nor does voltage go.
Re: Unknown part
« Reply #3 on: September 17, 2018, 04:34:34 pm »
Here's a better picture, a friend of mine who often works with vintage (analog) electronics told me it's a "flyback/recovery diode" (Freilaufdiode in German) which would make sense as it's connected to a relais.
Picture was taken with flash activated on my smartphone (which is the best I can offer). Size is slightly smaller than a common leaded resistor for signals (0207?).
Also attached is the (partial, temporary) schematic I got so far, U1 and U2 are the parts in question, the green line underneath corresponds with what I interpret as the "white marker" for the cathode.
« Last Edit: September 17, 2018, 04:46:25 pm by shock__ »
Offline PA0PBZ
Re: Unknown part
« Reply #4 on: September 17, 2018, 05:49:09 pm »
Oyes that's a diode  ;)
An 1N400X will do fine here.
« Last Edit: September 17, 2018, 05:53:04 pm by PA0PBZ »
  • Country: pt
Re: Unknown part
« Reply #5 on: September 17, 2018, 06:38:41 pm »
Maybe a 1N141. The 1984 Fairchild Databook says that a direct sub is the 1N4148.
See another version in the datasheet here:
« Last Edit: September 17, 2018, 06:42:13 pm by Quarlo Klobrigney »
Offline gbaddeley
Re: Unknown part
« Reply #6 on: September 21, 2018, 06:58:37 am »
Maybe a 1N141.
Brown Yellow Brown = 141 ?? :-\
« Last Edit: September 21, 2018, 07:02:02 am by gbaddeley »
Glenn
Offline Beamin
  • If you think my Boobs are big you should see my ba
Re: Unknown part
« Reply #7 on: September 21, 2018, 03:26:02 pm »
Why do they have U2(diode?) across  74LS00N a nand gate? Wouldn't that feed back on it self? If the | on the schematic indicates the neg side of the diode wouldn't that mean when the first (top) pin is high it and the bottom pin is high it sends out zero. But if you put a diode on the output as a wire/bridgeto input 2 it can't turn on because it would then see that pin 1 and 2 are different? I'm confused it seems like that set up would make it never turn on.
What does that circuit do?
Datasheet of that part:
http://ecelabs.njit.edu/student_resources/datas/74ls00.pdf
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
  • Country: pt
Re: Unknown part
« Reply #8 on: September 21, 2018, 08:25:08 pm »
Because it's not a multiplier band.
Quote from: gbaddeley on Today at 01:58:37
« Last Edit: September 21, 2018, 08:30:47 pm by Quarlo Klobrigney »
  • Country: pt
Re: Unknown part
« Reply #9 on: September 21, 2018, 08:34:18 pm »
Why is if followed by the?
It's all about the reference. I don't see a schematic.
Quote from: Beamin on Today at 10:26:02
« Last Edit: September 22, 2018, 12:34:09 am by Quarlo Klobrigney »
Offline gbaddeley
Re: Unknown part
« Reply #10 on: September 24, 2018, 07:32:19 am »
Maybe a 1N141.
Quoting my own post, the '??' mean I am questioning: Was it identified as IN141 by reading the colour bands?
Glenn
