Author Topic: C64 / C128 Video on HDMI screen - improving image quality possible?  (Read 12523 times)
Offline TinkeringSteveTopic starter
Re: C64 / C128 Video on HDMI screen - improving image quality possible?
« Reply #25 on: December 29, 2020, 01:15:09 am »
Retrotink is NOT the best for C64! It and the clone I menioned have the "white stripe" problem!
CRT is just inacceptable bulk, and often already too dark (worn tube).
Not a real option for my taste.
As said, the "Mcbazel ODV" has a distinctly overall better image than all other tested, including the clone of retrotink.
Its only downside is that it does not up-scale, which is not relevant for my versatile monitor that can be set to scale but retain aspect ratio.
I got that one to be able to also play old 4:3 PC games, and I'd reckon that I'm not the only fancier of older games who has a monitor like that, so an up-scaling feature of a HDMI converter is kinda irrelevant.
The tip with TV's video inputs still perhaps helpful to others reading. I myself don't have a TV, and that's unlikely to change.
So that hyped Retrotink thing is not all that impressive. Especially not for the price.
« Last Edit: December 29, 2020, 01:18:53 am by TinkeringSteve »
Offline Bud
« Reply #26 on: December 29, 2020, 01:38:23 am »
Lumafix and such are difficult to adjust because "they are holding it wrong", lol. They mix the inverse clock signal into the composite signal. But the thing is that the interference mostly comes from Chroma output of the VIC. I guess noone bothered checking Luma and Chroma signals with a spectrum analyzer.  I did, so there you have it. Some of the Lumafix variations do add a portion of the inverse clock to Chroma but they do it incorrectly , when mixing in to Chroma the added clock should Not be inversed.
Offline JohnnyMalaria
    • Enlighten Scientific LLC
« Reply #27 on: December 29, 2020, 01:42:09 am »
You'll never get a modern display to give you the same experience as an interlaced SD CRT. Get a used studio monitor off eBay. I was going to junk mine until I saw I could get $500 for it.
Offline Alex Eisenhut
  • Place text here.
« Reply #28 on: December 29, 2020, 04:07:06 am »
It really sucks and I spent a lot of time and energy and money on various "pro" and consumer scalers, and I agree with your assessment.
The only scaler I like is the Viewsonic VB50HRTV and its successors.
It seems to handle the crap C64 video just fine, albeit with all the flaws piped right through.
The "pro" scalers give you lots of control, but it turns out the controls are useless. I'd like to have complete control on how it digitizes the video but since they are professional units they assume perfect by-the-book video signals. So the controls are mostly for the output side. Not useful.
I also tried LCD TVs and it is also hit or miss. Only certain LCD TVs work.
I am sticking to my 1080 monitor. The 2002 is the same. I don't like the 1084 series as they are flakey and fail. The 1702/1701s are great but hard to find.
It's a shame that Commodore didn't try to address the very real noise problems with the VIC-II, for a flagship graphics and sound machine a very sloppy approach. Oh well.
« Reply #29 on: December 29, 2020, 09:31:00 am »
Well it was all kinda rushed from that I remember.
An expression I got from the Bob Yannes interview.
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #30 on: December 29, 2020, 10:52:17 am »
The sales numbers of the VIC-20 and C64 prove that the design was perfect...
Who would care 40 years ago if there would be display issues on flat screens by 2020.
The cheapest options - as I said before - are:
- The C64 Maxi
- Raspberry Pi 3 running BMC64
- Using a CRT TV
- Using a 1701/1702 or 108x monitor
  • Place text here.
« Reply #31 on: December 29, 2020, 02:57:58 pm »
No, it means it was good enough. If the chips were perfect, why did Commodore spin so many revisions? They could have spent a bit of time cleaning up the noise too.
Offline Rasz
    • My random blog.
« Reply #32 on: December 29, 2020, 03:23:43 pm »
interlace is the key here for the 240p signal Im sure
so the CRT was soo good you wanted to throw it out
until someone told you its a veblen good
<taps on horehead>genius</>
They did so many revisions because they only had inferior engineers left after usual Tramiel excess staff cleaning maneuver. He fired almost whole C64 team after product release - Bruce Crockett (manufacturing), Al Charpentier (VIC) and Robert Yannes (SID) went to start Ensoniq, company Creative had to buy to provide actually working DOS compatibility on PCI cards.
Commodore kept to this strategy even after Tramiel left, they similarly got rid of Amiga hardware team (Jay,RJ,Needle) resulting in shipping same chipsets for 7 years under different names. Whole 9 years of Amiga without HD floppy (required basic PLL update inside Paula).
no buts, I found the perfect solution, and its cheap too https://www.eevblog.com/forum/repair/convert-640x200-video-screen-to-640x480/msg3385758/#msg3385758
instead of digitizing video with ADC it uses comparators and tunes every single bit threshold individually, reconstructs digital signal perfectly. Specifically designed for 8 bit computers.
« Last Edit: December 29, 2020, 03:34:50 pm by Rasz »
Offline Shadowfire
« Reply #33 on: January 07, 2021, 05:03:19 pm »
What white line are you talking about?
Here's my C128 NTSC hooked up to a 720p flatscreen via HDMI and the retrotink.
Note: I had to crop the original image to get it under the 4000kb forum file limit.
For the life of me, I have no idea what you are talking about.  Even with this photo you can clearly see the jailbars on the blue background (its actually worse in real life than in this picture), but there is no white line anywhere.
Edit:  I looked at the pictures in the the threads that you linked earlier, and did the standard POKE53280,0/POKE53281,0 to get a black background like in those pics, and still no line on the edge of the display like in those threads.  I'm not sure what to say, maybe its your TV?  I'll dig out my PAL C-64 and check it out in a bit.
« Last Edit: January 07, 2021, 05:15:57 pm by Shadowfire »
Offline Shadowfire
« Reply #34 on: January 07, 2021, 05:26:37 pm »
OK, I have done a little running of cables and made some findings.
This is the PAL C-64 (running on the only TV I have in the house that will actually show a PAL video signal) with the C-64 Video Enhancer.  There are moire patterns on this picture, but you don't see anything like that in person, its a pixel-perfect image.
1146938-0
I then put the retrotink on the PAL 64 and fed it into the same TV.
1146942-1
It seems that the Retrotink does indeed show a bright line on the left side of the display, but only if you use it with a PAL unit.
Edit: I would suggest contacting Mike Chi about this; however, this may be what the pal C-64 is actually putting out (in the old days with a TV this would be in the overscan area where you couldn't see it, similar to how the NES had a horrible edge when horizontal scrolling)
(confirmed by below post, seems to be a problem with the PAL VIC-II chips.  You don't remember it being there because it was offscreen on the TV/monitor you were using back then.  Another reason to go with the video enhancer.)
« Last Edit: January 07, 2021, 05:40:42 pm by Shadowfire »
Offline Bicurico
  • Country: pt
« Reply #35 on: January 07, 2021, 05:34:01 pm »
That line is a bug/feature of the VIC-II.
FWIW this is neither the color burst nor the sync signal. It is a bug/feature in the VIC chip that makes the first 1.5 or so pixels of every line white.
The color burst signal would be to the left of the white line, and is not usually visible. Color burst is some defined color at zero intensity - so on a TV this would show up as black. On a B/W monitor and composite input with horizontal position adjustment you can see this as a faint band on the left if you move the screen entirely to the right.
The sync signal is even further to the left, and is 'blacker than black', certainly not white.
Source: https://www.lemon64.com/forum/viewtopic.php?t=73229
Regards,
Vitor
Offline Rasz
    • My random blog.
« Reply #36 on: January 08, 2021, 02:34:51 am »
this guy https://github.com/c0pperdragon/C64-Video-Enhancement ? This is totally skipping VIC-2 output, only way to successfully remove jailbars
works great with RGBtoHDMI https://videogameperfection.com/forums/topic/hdmi-output-using-raspberry-pi-zero/
Offline Shadowfire
« Reply #37 on: January 08, 2021, 01:40:49 pm »
Yes, the C64VE is c0pperdragon's board.
The RGB2HDMI project is an RGB -> HDMI converter (just like it says) but it needs to be tuned to the clock frequency of the generating hardware to produce good results.  They are basically sampling the analog signal and it needs to sample near the center, not the edge, of a pixel.  This would probably work well* (I haven't used one but the theory seems to be sound) to convert the C64VE's output (which IIRC can be configured to output RGsB instead of YPbPr) to HDMI.
Offline Rasz
    • My random blog.
« Reply #38 on: January 08, 2021, 02:29:55 pm »
Its sampling at ~96MHz, I say thats enough to catch perfect transitions :)
https://stardot.org.uk/forums/viewtopic.php?f=3&t=14430
Offline tszaboo
« Reply #39 on: January 08, 2021, 03:22:19 pm »
If it is really a clock signal going into the component video signal, there must be a way to remove it, the good old way. Analog filters. If you would filter all the signals that are faster than the component video, so 4-ish MHz, you should be able to get rid of those lines. All you need is 3 opamps, and some passive circuits.
Offline Bud
« Reply #40 on: January 08, 2021, 05:56:15 pm »
Regards,
Vitor
Right, it comes out of the VIC chip and can be clearly observed as a luminance spike on the oscilloscope at the beginning of an active line.
Offline Shadowfire
« Reply #41 on: January 14, 2021, 03:05:20 am »
My point is that the C-64 changes pixel colors with an 8mhz clock, and if the sampling clock isn't locked to it (even though it might be running 12x faster) you will have the oddball color change last 13 or 11 clock cycles.
Offline Rasz
    • My random blog.
« Reply #42 on: January 14, 2021, 03:51:40 am »
have you looked at the link? its training its sampling clock to the signal. Its even able to recover pixel perfect picture out of BBC micro, computer which varies its pixel clock depending on whats on the cpu bus.
  • Place text here.
Offline Rasz
    • My random blog.
  • Place text here.
« Reply #45 on: February 06, 2021, 01:39:20 pm »
Oh crap. Why is it so damn difficult to make a "RCA" (why can't they just label it video, NTSC, PAL, composite, or s-video?) to VGA with the same controls?
« Last Edit: February 06, 2021, 01:47:45 pm by Alex Eisenhut »
Offline JDet
  • it's never too late ... do it. ;)
    • My Github repositories
« Reply #46 on: May 12, 2021, 08:14:27 am »
Hi together,
I dived in this subject almost three years ago.
I wanted to connect my old C128D-CR to a modern Display ... I already own a CRT with a SCART input and an old split cable DIN-8 + D-SUB-9 to SCART with a switch for choosing 40 col. or 80 col. mode. I searched through the infinite internet and found something like CGA2RGB converters for the 80 col. mode and the GBS-8200 to connect the D-SUB-9 to the CGA2RGB converter and then the CGA2RGB converter to the GBS-8200 and finally a VGA or DVI Display to the GBS-8200.
Fine - winner, winner, chickens dinner ;)
But what's about the 40 col. mode?????
So I developed my own solution to connect a C128 to a SCART display device.
It is not perfect - the 80 col. mode ist nice but the 40 col. mode with the LUMA, CHROMA & COMPOSITE signals depends on the cable and the quality of the display device. Many TVs with a SCART input do not support S-VIDEO (CHROMA&LUMA) with SCART or have a bad qualitiy.
It is a mess ... doesn't make a lot fun. My device works the best with a CRT.
You can watch my video, if you are interessted.
https://youtu.be/qOvFwwrAEIk
In my opinion @Rasz is right.
If you want to connect a C128 to a modern display with good picture quality, you have to use:
1. build or buy the RGBtoHDMI converter https://github.com/hoglet67/RGBtoHDMI/wiki with digital interface to use the 80 col. mode. You can connect the HDMI output of the Raspi Zero to the HDMI input of yout TV and enjoy the 80 col. mode of your C128
2. build or buy the C128 component video mod from c0pperdragon https://github.com/c0pperdragon/C64-Video-Enhancement/issues/64 I pushed c0pperdragon a little to design a smaller version that fits into the C128. So it is possible to get component output of the VICII / 40 col. mode. Currently you can't buy the new version for the C128. You can buy and use a version for the C64 https://videogameperfection.com/products/commodore-component-video/, but it is too big to mount it into a C128. If that is done, you can connect this mod to the component input of your display. Then you can enjoy 40 col. mode on your big TV.
The best solution would be a further development of c0pperdragons way.
Designing and building an FPGA based solution to grab the necessary signals direct from both video ICs (VDC & VICII) and generate an HDMI output signal.
That sounds simple, but unfortunately it will be tricky.
Is there anybody with FPGA knowledge and time to do such a project?  ;D It would be challenging  :box:
So cheers and RETRO ON.
« Last Edit: May 12, 2021, 08:19:56 am by JDet »
