Well the thing is the The8BitGuy is not an actual electronics engineer.
His level of troubleshooting comes down to just swap parts until it works. Okay sure he can actually use a soldering iron to replace a bulging electrolytic capacitor, but that's about it. He does not have the skills to actually troubleshoot a fault down to the component level.
This sort of component level repair becomes that much more of a skill when there is no service manual available, so you have to slightly reverse engineer the thing in order to figure out how it works, in order to probe stuff, in order to figure out if it has the correct waveform, in order to locate the faulty component, in order to replace it.
I have done stupid stuff with my own boatanchor repairs too, sometimes making it even more broken than before, then fixing it properly. He was just taking too big of a bite with trying to repair these things without the required skills.
Dremeling the security hex flat to get it out was just plain stupid on the other hand. Just bust out that security pin with a flathead screwdriver or dremel a straight slot across the middle for a screwdriver to fit if you really must.
