Author Topic: Another ask, help ID this chunky piece of retrotech  (Read 1038 times)
Online Alex EisenhutTopic starter
  • Place text here.
« on: August 08, 2023, 10:04:36 pm »
Here's another dead-end thing, anyone have any ideas what this connected to? Can't find much on the webz.
https://www.ebay.ca/itm/334473452923
I haven't bought anything useless in two months, now I have the hoarding monkey on my back real bad!  :palm:
I'd guess from the connector that it's simply ground, power, and TX and RX somehow and there's a protocol like on the C64?
Offline SiliconWizard
Re: Another ask, help ID this chunky piece of retrotech
« Reply #1 on: August 08, 2023, 10:10:06 pm »
I don't know, but the company was a lab equipment vendor, so I'd guess to lab equipment of some kind? Not to general-purpose computers.
https://www.radiomuseum.org/dsp_hersteller_detail.cfm?company_id=13010
Offline Benta
« Reply #2 on: August 08, 2023, 11:15:34 pm »
Perhaps a wild guess, but...
The 5-pin DIN connector suggests audio to me, and program/data storage on audio cassettes were a standard thing back then.
This might be a floppy drive emulating the cassette storage system.
In that case it could be really useful for retro computers.
  • Place text here.
« Reply #3 on: August 08, 2023, 11:52:16 pm »
Only way to find out is to buy it...  >:D
What's intriguing is the metal clip in the back, looks like it holds the DIN connector.
Offline Benta
« Reply #4 on: August 09, 2023, 12:08:23 am »
The clip doesn't look original, more like a kludge from a lab guy irritated about the cable dangling around.
Offline c64
« Reply #5 on: August 10, 2023, 04:47:52 am »
This item has been fully tested by our tech department and is in good working condition
Ask the seller? If it was tested, they must know what is it
« Reply #6 on: August 10, 2023, 05:57:25 am »
Yep, I'm pretty curious about how they have tested it. ;D
Offline Stray Electron
« Reply #7 on: August 10, 2023, 05:52:01 pm »
  They probably "tested it" the same way that sellers "recondition" their reconditioned equipment that they sell on E-Sucker. You know, the stuff that has broken broken knobs, bad displays, missing feet, cut off power cords and dirt, scrapes and scratches all over it.
  Q: "Found in a dumpster in an industrial area?"   Check >  TESTED!
The following users thanked this post: c64
Online Halcyon
  • Global Moderator
« Reply #8 on: September 15, 2023, 03:29:54 am »
Just more eBay nonsense words.
"Tested" = We plugged it in/switched it on, something lit up and it didn't go bang. Nothing further is known.
"Stored in a climate controlled environment" = It was stored indoors at home, occasionally we might have had the air conditioner/heater/fan running.
"Working pull" = It was once working sometime in its history, so we just assume it still works now. Haven't tested/won't test it.
"New old stock" / "New in box" = We haven't tested it. Might work, might not. You take the gamble.
"Rare" = We found no or few other listings in the few seconds we spent searching ebay at the time of listing, so it must be rare.
"Sold as-is" = There's something not quite right about this item, but it's up to you to piece it together from the photos/description.
The following users thanked this post: Alex Eisenhut, DimitriP, c64
Offline Nusa
« Reply #9 on: September 15, 2023, 07:23:23 am »
The 3.5" drive in it is likely nothing special, so the parallel to rs-232 (probably) interface board and protocol is what's special. And that's worthless except to someone who needs it for it's original purpose.
If you still want it, offer $20 and see what happens. That's about what a 3.5" floppy to USB solution would cost you today.
