Author Topic: Assembler for 8088  (Read 3764 times)
Offline admiralkTopic starter
Assembler for 8088
« on: September 13, 2019, 11:31:59 pm »
I am a bit confused on what to use to program the ROM in my computer build that is based on an 8088 processor. If I understand right, I can use NASM with ith format. Assuming that is correct, does anyone know if the file is created in text or binary. I assume it is text based. I have never been that good at reading files, so it would save a lot of trial and error if I started with the right assembler and the right format.
Much of this project involves building my own tools, as it is not based on any particular computer. At this point I am looking to develop an EEPROM programmer and it would help a lot if I knew what kind of format I need to read. To start I just want to be able to open the assembled file, display it, and send it to whatever hardware I build to do the actual programming. Eventually I hope to have a functioning IDE.
Offline Ampera
    • Ampera's Forums
Re: Assembler for 8088
« Reply #1 on: September 14, 2019, 09:47:30 pm »
Assemblers are program that take assembly language and compile it into machine code *binaries*.
NASM is totally capable of generating 8088 compatible binaries, just ensure you've set it to 16-bit mode. GCC's assembler is, afaik, not capable of this, and the Intel, Borland, and AT&T assemblers are I believe capable of this. NASM, however, is the most simple and common option.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: September 15, 2019, 12:27:53 am »
Microsoft Macro Assembler (MASM), possibly an early version if you want to run it on contemporary hardware rather than effectively cross coding (somewhere around, I guess, version 4-6, the executable (not the output) went 386+ only, I think?).
I've not actually used NASM but if it offers macros then that's nice.  There are several others that claim compatibility with MASM so I guess also support macros.
Macros aren't at all needed, but they're definitely handy.  You'll find repetitive patterns all the time, and it's nice to have standard formats to work with them.
There's something to be said for using C as well, just because you get the C preprocessor -- a more powerful macro system than most assemblers have (I think?).
Seven Transistor Labs, LLC
Online SiliconWizard
« Reply #3 on: September 15, 2019, 02:37:12 pm »
I second NASM, it has a powerful preprocessor and even a pseudo-language, and supports pretty much all x86 variants. It's still actively maintained (latest release end of 2018).
https://www.nasm.us/xdoc/2.14.02/html/nasmdoc0.html
« Reply #4 on: September 15, 2019, 03:16:05 pm »
I have used NASM before, but it has been several years and for a more modern processor. It sounds like I am good there.
I have been experimenting with a .hex file from Atmel Studio. That appears to be a text file as I have no problem getting it to print the ASCII on the screen, but have been unable to get it converted hex, so far. I guess I should try writing a small file with NASM and see if that works any better.
« Reply #5 on: September 15, 2019, 03:53:18 pm »
Many EEPROM programmers support pure binary files, which NASM can generate, additionally to .hex files.
If yours doesn't, you can use some "bin2hex" utility. There are many out there.
See this for instance: http://srecord.sourceforge.net/
srec_cat will allow you to convert files and do much more.
« Reply #6 on: September 15, 2019, 10:29:17 pm »
Now I ran into another problem. It appears there is a bit of syntax difference between NASM and MASM. The sample code I have is MASM and I am not familiar enough with assembly to translate it. I can assemble the code to an .obj, but that is as far as I can go as the 16-bit linker is long gone. I can only find dead links to it. I did find an old version of VC++, but an not too sure that it will run on Widows7 or that it has the right link.exe to begin with. Maybe I can get NASM to do the last part?
Online T3sl4co1l
« Reply #7 on: September 16, 2019, 01:31:21 am »
This any help?
https://www.seventransistorlabs.com/masm6_1.zip
MASM 6.11 compatibility, ML 6.15, LINK 5.60, all win32 executables, should be able to do everything?
Note that EXE is relocatable and contains headers; you want, I think, either COM (.org 100h though?) or the right switches or directives to generate binary output.  This should be helpful:
http://www.sxlist.com/techref/language/masm/toc.htm
If you need LINK to run on 8086, probably the OBJ file format is compatible(?!!) and any contemporary version will do; I know it came with QuickBasic, and probably the other too?
https://winworldpc.com/product/macro-assembler/1x
Note: these are probably not illegal links; I don't know about my hosted file specifically, but WinWorld at least has been around for a very long time, MS is aware of their existence, and they continue to take no action against them with regards to old products like this.
« Last Edit: September 16, 2019, 01:36:35 am by T3sl4co1l »
« Reply #8 on: September 16, 2019, 11:37:21 pm »
Thanks, I found a link to all the old MASMs, but as far as I could tell, they all required DOS. I will give the win32 exes a shot when I get some time.
I was thinking maybe I could just take out the ASUME macro, and what it references, and see if NASM would work. As near as I can tell that is where the errors are coming from and I saw a couple references to doing that, or that is all it looked like they did anyway.
Online T3sl4co1l
« Reply #9 on: September 17, 2019, 12:20:47 am »
NASM doesn't use ASSUME directive?
You may need to change or add segment prefixes on the applicable references.  Below an ASSUME <segreg> = <segname>, make sure that every reference to a label in that segment, that's not using the default segment (DS), has <segreg> prefixed.
Actually, I forget offhand if ASSUME actually does anything with code generation (i.e., ASSUME ES=MySeg, and MyLabel is in MySeg, a MOV AX,[MyLabel] should automatically prefix ES: on it?) or if it's just for checking (if you didn't set ES above, it's probably a warning?).  Hmm no, the latter wouldn't even make sense.... Well anyway, it's in the docs, I should look it up rather than ramble here.
« Reply #10 on: September 17, 2019, 12:55:04 am »
Nope, that seems to be the problem.
SEGMENT BOB ;Define the code segment
ASSUME CS:BOB,DS:BOB,SS:BOB ;Set all segment registersto
;the same location
ORG 7F0h ;The 2716 location for the 8088
;powerup instruction of FFFF0h
START: MOV AL,00000001b ;This will light the zero light
;on the 373's output
AGAIN: OUT 10h,AL ;Since the 373 is enabled by
;IO/M directly, it will respond
;to any port reference
JMP AGAIN ;Go light the LED again
BOB ENDS ;Tell assembler this is the end
;of code for this segment
END START ;Tell assembler this is the end
Too tired to fix the formatting, but it starts on line 2.
Matrix.asm:3: error: parser: instruction expected
Matrix.asm:15: error: parser: instruction expected
Matrix.asm:17: error: parser: instruction expected
It originally had BOB before SEGMENT and was thinking BOB was a label. I am not sure of the last error, I thought it was not supposed to read past END. Anyway, that is for another day.
I did find the place I got the MASM files from. It also has a bunch of tools that might come in handy.
http://www.nj7p.info/Computers/Software/Tools.html
« Reply #11 on: September 17, 2019, 02:11:05 pm »
Nope. See there: https://www.nasm.us/doc/nasmdoc2.html
As part of NASM's drive for simplicity, it also does not support the ASSUME directive. NASM will not keep track of what values you choose to put in your segment registers, and will never automatically generate a segment override prefix.
« Reply #12 on: September 19, 2019, 10:04:21 pm »
After a bit of experimenting, I almost found a solution.
Using MASM with original example file; ml > link > com2hex gives me
3A 30 30 30 30 30 30 30 31 46 46 0D 0AUsing NASM with all the ASSUME parts removed and ith format gives me
3A 30 36 30 37 46 30 30 30 42 30 30 31 45 36 31
30 45 42 46 43 37 35 0D 0A 3A 30 30 30 30 30 30
30 31 46 46 0D 0A
Using NASM with all the ASSUME parts removed and no file type option gives me
B0 01 E6 10 EB FCWhich is correct, except for the lack of an offset. I checked the com file and it turns out it was the same.
So it looks like I can just remove the stuff NASM does not like and use it. The only problem is how to get it to pad the start with all the 0s. In other words, instead of
00000000    B0 01 E6 10 EB FCI need
00000000    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000007E0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000007F0    B0 01 E6 10 EB FC
Online T3sl4co1l
« Reply #13 on: September 20, 2019, 07:22:29 am »
Put this at the top of the code:
.org 7e0
« Reply #14 on: September 20, 2019, 07:25:45 pm »
Thanks, but it does not like that
I already had ORG in it to begin with also. This is it cleaned up some.
You would think something this simple would just work.
« Reply #15 on: September 24, 2019, 11:08:14 pm »
OK RTFM  |O
It looks like NASM uses ORG different than other assemblers. I think I remember something like this, now, but it has been about 15 years. The correct answer is
ORG 0
                TIMES 7F0h-($-$$) DB 0
;ORG 7F0h ;The 2716 location for the 8088
Thanks for all the suggestions.
