Author Topic: Blank media shelf  (Read 2621 times)
Offline Halcyon
  • Global Moderator
Blank media shelf
« on: January 11, 2023, 02:39:54 am »
This was an "IRC exclusive" but I figured I'd post here also.
I've been re-evaluating my storage and sorting through a lot of stuff I had. Donating something components, testing and throwing away faulty stuff etc...
Part of this exercise was to organise my blank media where I could easily find them, rather than being tucked away in boxes. So I set up some cheap garage shelving from the hardware store inside a spare wardrobe.
I'd love to hear about and see what types of media you guys have laying around. The more obscure, the better!
From top to bottom:
  • 3.5-inch double-sided, high-density disks
  • 3.5-inch double-sided, double-density disks
  • Box of mixed 3.5-inch disks of various capacities, including some old Amiga software
  • 8-inch, double-sided, double-density disks
  • 5.25-inch double-sided, double-density disks
  • 5.25-inch double-sided, high-density disks
  • Box of mixed 5.25-inch disks
  • DVD-R in jewel cases
  • BD-R (25 GB) discs
  • DVD+R (8.5 GB) dual-layer discs
  • CD-R (700 MB) discs
  • CD-RW discs
  • DVD-R (4.7 GB) single-layer discs
  • DVD+R (4.7 GB) single-layer discs
  • MiniDV cassettes in various lengths
  • Compact cassette tapes
  • ZIP disks (100 MB)
  • ZIP disks (250 MB)
  • Castlewood ORB (2.2 GB) disks
  • 130mm (2.6 GB) magneto-optical disks
  • Jaz disks (1 & 2 GB)
  • 90mm/3.5-inch (230 MB) magneto-optical disks
  • 9-track tape reels (600 feet long, 6250 bits/inch/track
  • Various VHS tapes
  • Boxes of LTO-2 tapes
« Last Edit: January 11, 2023, 02:42:12 am by Halcyon »
Offline cfbsoftware
    • Astrobe: Oberon IDE for Cortex-M and FPGA Development
Re: Blank media shelf
« Reply #1 on: January 11, 2023, 05:56:38 am »
I use the Quad-density 2S/4D, 96 TPI, 5 1/4" floppies on my Sage computers allowing up to 800 KB to be stored on a single floppy.
Chris Burrows
CFB Software
https://www.astrobe.com
The following users thanked this post: Halcyon
Offline Psi
« Reply #2 on: January 11, 2023, 08:24:43 am »
You need some LS120 disks
and maybe some DVD-RAM
The following users thanked this post: ledtester
Offline Halcyon
  • Global Moderator
« Reply #3 on: January 11, 2023, 09:34:08 am »
I plan on expanding my collection of both disks and drives. Currently I don't have anything that is LS-120. I would love it though.
Offline Alex Eisenhut
  • Place text here.
« Reply #4 on: January 11, 2023, 10:04:21 am »
Yeah, quad density 5.25 floppies, with the SFD-1001 drive gets me 1 MB of storage.
74 minute Minidisc.
90 minute Sony NT digital microtape
3.25" floppy disc
Hoarder of 8-bit Commodore relics and 1960s Tektronix 500-series stuff.
Online Kleinstein
« Reply #5 on: January 11, 2023, 11:29:59 am »
AFAIK the Commodore SFD1001 floppies were still 2D media, just a more efficient data format than normal MFM with a fixed number of sectors per track.
Offline AndyC_772
« Reply #6 on: January 11, 2023, 12:39:43 pm »
No DAT, or DDS tapes...?
The following users thanked this post: Ed.Kloonk
Offline Halcyon
  • Global Moderator
« Reply #7 on: January 11, 2023, 12:55:09 pm »
Actually now that you mention it, I do have some somewhere... I'm sure I'll come across them during my organisation. I have a DDS drive.
« Reply #8 on: January 11, 2023, 02:08:26 pm »
Used to have blank Betacam SP tapes around, used as a source of case parts in the instance a SP tape master needed to be repaired. Also had a few Umatic tapes around for the same reason.
Also had a few 74188 32x8 fusible link proms, used as display decoders in some bespoke avionics, and also used as memory decoders as well elsewhere in the test benches.
« Last Edit: January 11, 2023, 02:18:43 pm by SeanB »
Offline gamalot
  • Correct my English
    • Youtube
« Reply #9 on: January 11, 2023, 02:17:00 pm »
QIC tapes are my favorite.
  • Place text here.
« Reply #10 on: January 11, 2023, 06:04:26 pm »
I also have a microcassette, like answering machine thingies.
  • Place text here.
« Reply #11 on: January 11, 2023, 11:21:00 pm »
Both the SFD-1001 manual and the spec of the mechanism say that double-density media will work, for some reason it is Commodore 8-bit lore that you need quad density disks for a SFD-1001. Maybe because of the 100 TPI thing. I don't know.
Offline granzeier
« Reply #12 on: January 12, 2023, 12:30:56 pm »
Do you have Stringy Floppys, from Exatron (https://en.wikipedia.org/wiki/Exatron_Stringy_Floppy )? A friend had one for his TRS-80 Model I.
I also seem to remember that there was an 8-Track system, but don't remember anything else about it.
  • Place text here.
« Reply #13 on: January 12, 2023, 02:59:00 pm »
Oh, why yes I do. Forgot about that one, since I never opened it. It's the Entrepo version for the 64, called the Quick Data Drive.
Offline cfbsoftware
« Reply #14 on: January 12, 2023, 09:36:39 pm »
Quad density disks are hard to find, and they were even hard to find in the 80s. It turned out that you could format regular double density disks (the same disks used in the 1541) as quad density disks and they usually worked. No disk manufacturer would guarantee them if you did that, of course. But with no other options, people did it. Of course, it’s better to locate and use actual quad-density disks in the SFD.
https://dfarq.homeip.net/commodore-sfd-1001
Chris Burrows
CFB Software
  • Place text here.
« Reply #15 on: January 13, 2023, 01:24:23 am »
"It turned out that you could format regular double density disks"
So it turned out that you could use the media the manufacturer specified?
You think the manufacturer of the mechanism and the drive somehow got it wrong that it just needs double-density media.  :-//
Offline helius
« Reply #16 on: January 13, 2023, 05:42:50 am »
They certainly look heavy duty with the solid machined aluminum baseplate. But the situation with the decayed tension bands is a big hassle as there is no exact replacement available. Substitute bands made for ladies' brassieres or food packaging plants may work for data recovery, but their longevity when used for real backup purposes is a question mark. And changing them is certainly not easy for the inexperienced.
Offline cfbsoftware
« Reply #17 on: January 14, 2023, 12:11:14 am »
"regular double-density disks" are 48 TPI. Unfortunately the so-called "Quad-density" disks are also referred to as "Double-density" but they are 96 TPI. Refer to the section headed 5.25" Floppy Disks in the following article:
http://www.3480-3590-data-conversion.com/article-floppy-disks.html
Chris Burrows
CFB Software
Offline helius
« Reply #18 on: January 14, 2023, 02:17:54 am »
The magnetic characteristics of the media does not determine the number of tracks; that is determined by the drive. The magnetic domains of the media have a characteristic B-H curve that set a limit on the number of flux transitions per length and the intensity of the field, but these are more relevant to the data rate (or bits/track) and not the number of tracks since the tracks are so far apart.
They are referred to the same because they are the same in every parameter that matters, such as coercivity and flux transitions per inch.
Your cited article says:
These double the capacity of the original drive by doubling the number of cylinders (tracks) from 40 to 80. They use the same media as the the 40 cylinder 48 TPI drives
So if the media is the exact same, by would it ever be labeled differently? Magnetic media carries defects, and the location of those defects can be important. Depending on the formatting scheme, defects may be impermissible on the first track, or even on all tracks. That requires that disks are formatted&verified with the same track layout as they will be used with. Even there you may come unstuck, since some sector sizes and sector gaps may contain defects that are not detected using other sizes.
Offline retiredfeline
« Reply #19 on: January 14, 2023, 03:46:11 am »
In your photo do you need to store the floppies in a lockable box? I suppose if a thief wanted to nab them to auction at Sotheby's they'd take the whole box. :-DD
« Reply #20 on: January 14, 2023, 07:32:43 am »
Lockable box was so they would not fall out when you inevitably dropped it
Offline Halcyon
  • Global Moderator
« Reply #21 on: January 14, 2023, 12:15:19 pm »
The lock is not important. I use it for storage so I can quickly flip through disks that have already been written to. It's a nice way to organise boot disks, programs etc...
The lock box is more for nostalgia at this point.
Online ebastler
« Reply #22 on: January 14, 2023, 05:06:55 pm »
Paper tape, both the 1" (8 bit) and 11/16" (5 bit Baudot) variant.  :)
Running low on these... If you know of a source selling them at a reasonable price, or have some rolls you would want to sell or trade, please get in touch!
Offline marcopolo
    • Retronik
« Reply #23 on: January 22, 2023, 12:26:54 pm »
90MB Bernouilli
44 or 88 MB Syquest
French Electronic Documentation and Magazines: www.retronik.fr
The 68K Archives: marc.retronik.fr/motorola/68K/68000.html
Offline Psi
« Reply #24 on: January 22, 2023, 12:29:02 pm »
OMG SyQuest,  not seen one of them in many many years.
