Author Topic: Commodore 1084s-P1 CRT repair  (Read 5814 times)
Offline djos
« on: September 29, 2017, 07:24:12 am »
So I finally stopped procrastinating and started work on my Commodore 1084s-P1 CRT repair project. It should be fairly straight forward as the number 1 failure with these is the HOT going bang and taking the FlyBack transformer with it.
Required parts:
and this is as far as I got today before fatherly duties intervened:
At least it's fully discharged and im ready to start desoldering al the relevant components.  :-+
The impossible often has a kind of integrity which the merely improbable lacks.
Visit my Tindie store for Tandy 1000 Adapters for EX, HX, SX, SL, TX & TL etc
Offline djos
Re: Commodore 1084s-P1 CRT repair
« Reply #1 on: September 30, 2017, 05:48:34 am »
Finished off the HOT & FlyBack Transformer replacement today - just need to replace the power switch now as it doesnt stay on.
Components gone:
New ones in:
putting the neck board back together:
half done - J1 wire hasn't been soldered in yet:
and mostly back together:
and she works!
Some adjustments will be required (pic is too bright) but i'll sort that after I replace the power switch in a few days (it's in transit).
« Last Edit: September 30, 2017, 05:51:27 am by djos »
« Reply #2 on: September 30, 2017, 06:08:47 am »
Check all high value resistors ( anything over 10k) in the high voltage side, they do tend to drift high, and this causes the excessive brightness. Also resolder R3514, to make sure any hidden dry joint there does not kill the new parts.
Offline djos
« Reply #3 on: September 30, 2017, 06:21:27 am »
I haven't adjusted the "screen" pot on the Flyback yet, out of the box it's usually set too high.
Thanks for the tip, I'll definitely check the resistors and the solder on R3514. Can you reliably measure resistance in circuit?
Offline vk6zgo
« Reply #4 on: September 30, 2017, 07:36:57 am »
You are fixing a Monitor.
The big glass thing is the CRT
Calling the whole thing a "CRT" is an incredibly annoying species of "Computer person speak" which has no place in an electronics forum. >:(
Offline djos
« Reply #5 on: September 30, 2017, 07:54:11 am »
Lol, it's still using cathode ray tube technology, it's just a very highly developed distant cousin.
Offline djos
« Reply #6 on: September 30, 2017, 07:57:22 am »
Ok, I turned the "screen" pot down on the FBT and it's no longer over driving the screen.  :-+
I just need to hook up a video source and finish tweaking.
Offline djos
« Reply #7 on: September 30, 2017, 10:30:30 am »
and now focused.
I checked all the solder joints with my 5x illuminated glass and they all look fine - I couldnt even find R3514 on mine so it might be only on other models? (mine is the -P1)
Mine's obviously been repaired once before as there are quite a few solder joints with non factory rosin around them that wasn't cleaned off with IPA.
Offline vk6zgo
« Reply #8 on: September 30, 2017, 12:07:48 pm »
My rant was a bit "tongue in cheek", but it does annoy me.
The CRT is just one component of the equipment you are fixing, & the only component which utilises "cathode rays".
All the other active devices are semiconductor based.
Some people used to refer to cars as "motors", or transistor radios as "transistors".(& probably still do)
It sounded silly then, & it does now when the same thing is done with Monitors.
It can also be misleading to beginners.
On another thread someone was getting all overwrought about the dangers of CRT tubes because they read on a "computer" website that there was some large amount of lead inside the "CRT".
The website was, of course, referring to the whole Monitor, & including the amount of lead in the PCB & other soldered connections.
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #9 on: September 30, 2017, 07:03:15 pm »
CRT is short for 'CRT monitor' which is the whole thing. If you think acronyms have no place in an electronics forum then you can expect to continue being incredibly annoyed.
Offline Gyro
« Reply #10 on: September 30, 2017, 07:23:40 pm »
Err, CRT is short for Cathode Ray Tube, nothing more. It's a standalone component.  It could be in a TV, a scope, spectum analyser, camera... or a monitor ;)
CRTs in TVs and Colour monitors use leaded glass in the faceplates to minimise X-ray emission. You should be very careful not to store Port or Sherry  in them for long periods (as is the advice for Lead glass decanters) for fear of Lead leaching.  :)
P.S. "CRT tube" is a tautology.  :P
« Last Edit: September 30, 2017, 07:25:31 pm by Gyro »
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline djos
« Reply #11 on: September 30, 2017, 09:19:23 pm »
It's a silly argument, although I do get irritated by OEM's calling LCD tv's led tv's when only the backlight is led and the display itself uses an LCD panel.  |O
Offline Gyro
« Reply #12 on: September 30, 2017, 09:27:01 pm »
Me too - they'd have been really screwed it they hadn't used Organic LEDs in OLED TVs.
P.S. Yes, I agree - Just Saturday evening high spirits in my case. Don't worry, it's worn off now. :D
P.P.S. We all know we should be talking about VDUs anyway.
Chris
Offline vk6zgo
« Reply #13 on: October 01, 2017, 08:07:03 am »
Yes, but Cathode Ray Tubes are unlikely to have Port or Sherry stored in them.
I don't usually store Port for very long at all!  ;D
He actually linked to the website, & from context, & the mass quoted, it was definitely to do with the amount of solder in the monitor.
You got me there!
I noticed I had done that, & considered doing battle with the iPad to edit it, then decided "To hell with it, let someone have some harmless fun!"
« Reply #14 on: October 01, 2017, 08:25:08 am »
Definition of: LED TV
A flat panel LCD TV set that uses LEDs (light emitting diodes) for its backlight source rather than the earlier cold cathode fluorescent lamps (see CCFL). Smaller, more power efficient and having a greater optical range than the fluorescents, LED TVs produce deeper blacks and more saturated color. In 2005, Sony offered the first LED TV.
Although an LED TV is really an LCD TV with LED backlighting, the industry branded them as LED TVs to avoid monikers such as "LED backlit TV" or "LED-based LCD TV.".
Offline djos
« Reply #15 on: October 01, 2017, 09:12:14 am »
I'm well aware of why, still doesnt change the fact that "LED TV's" are nothing of the sort, they are LCD TV's with an LED backlight - we didnt stop calling them LCD Screens when front lighting was first used, or when backlighting replaced front lighting.
So in summary, "LED TV" =  marketing BS.
At least Plasma and OLED screens are accurately named.
Offline djos
« Reply #16 on: October 09, 2017, 04:27:48 am »
Replacement power switch finally arrived today after the courier company lost it and mysteriously delivered it to my mailbox 4 days after claiming to have delivered it too me in person (including me signing for it apparently). Amazing how responsive they can be when you accuse their driver of fraud!  :-DD
Unfortunately I'm of crook atm, so can't install it for a few days.
Offline BubbaMc
« Reply #17 on: October 11, 2017, 07:38:01 am »
Nice work.
Is that the model with a live chassis?
BTW feed it an RGB picture if you want to see how good it is :)
Offline djos
« Reply #18 on: October 11, 2017, 07:53:17 am »
Nice work.
Cheers.
Not sure what you mean by live chassis? The chassis is plastic so non-conductive.
Yeah I'll be testing and focusing it properly, with an Amiga putting out RGB, once I've recovered from a nasty bout of gastro that the daughter brought home from school.
Offline BubbaMc
« Reply #19 on: October 12, 2017, 01:24:13 am »
See here for a brief discussion: https://www.eevblog.com/forum/beginners/live-chassis/
One of my later model 1084S monitors has a live chassis (assume Commodore did this as a cost saving measure), so I'm not willing to attempt repair until I get an isolation transformer.
Offline djos
« Reply #20 on: October 12, 2017, 01:47:46 am »
Hmmm, I'd have to take a closer look at mine but seeing as it's a rebadged Philips Im not terribly concerned. The main danger with these is the FBT, if you dont discharge them properly before starting work on them you can end up with a paralysed arm and a nasty headache for a few hours. I recall being dismissive once back in the 90's while working on a 21" Trinitron, the jolt I got that day corrected that dismissiveness permanently and so now i'm paranoid instead!   :-DD
EDIT: there's grounding wires between all the boards and there's no live chassis that I can see - imo it's a pretty nice design.
« Last Edit: October 12, 2017, 01:51:11 am by djos »
Offline helius
« Reply #21 on: October 12, 2017, 01:55:44 am »
A lot of the reputation "live-chassis" sets have comes from the bad old days of vacuum tube rectifiers and unpolarized flex. TVs from that era did not have video in jacks because they would be unsafe, since the mains might be conducted onto the shield of the video cable!
Even if a computer monitor is not fully isolated, it can't literally be live on the chassis without conducting the mains into the computer equipment. While it may be good practice to use isolation transformers, it is not the same level of risk as the former designs.
Offline BubbaMc
« Reply #22 on: October 12, 2017, 04:21:36 am »
Good to know, thanks.
Offline djos
« Reply #23 on: October 13, 2017, 10:01:14 am »
So I'm finally recovered from a nasty dose of Gastro and made it back out to the workshop to finish off my 1084s repair:
Old switch gone:
new switch in:
Picture quality tweaked to perfection using my little a600 (finally found a use for it! Workshop Amiga!):
yeah baby:
Soooo, i was very happy .... until the new switch failed after half a dozen uses!  :palm:
Wagner Online are going to be getting a very sternly worded email from me shortly!  :box:
« Last Edit: October 13, 2017, 10:04:46 am by djos »
Offline Alex Eisenhut
  • If you can buy it for 4$ on eBay, why design it?
« Reply #24 on: October 18, 2017, 10:53:34 pm »
I had no idea there was a 1084 with a bezel looking like the 1950. Thanks for sharing!
