You know those old school AC power control centers you can plop a monitor on top? If so, how big is it? Does it look awesome?
I do use a couple of them in the lab. They are 12" wide and look pretty boring
The first one has some test equipment plugged in that uses too much standby power, an IEC cord, and a power strip. The last 2 items are for when I'm working on some equipment and I want to be able to make sure it's turned off (especially if it has a soft power switch).
The second power center is connected to my soldering equipment, so I can make sure it's all turned off when I leave.
