Author Topic: Do you use a AC power control center thing?  (Read 370 times)
Online Alex EisenhutTopic starter
  • Place text here.
« on: September 25, 2025, 05:12:46 pm »
You know those old school AC power control centers you can plop a monitor on top? If so, how big is it? Does it look awesome?
I found a big plain one at Goodwill, but now I want a fancy 1980s themed one, like this
https://youtu.be/cImJqqtnLHs
I mean, doesn't everyone want one like this?
Offline edavid
Re: Do you use a AC power control center thing?
« Reply #1 on: September 25, 2025, 05:40:18 pm »
I do use a couple of them in the lab.  They are 12" wide and look pretty boring  :-//
The first one has some test equipment plugged in that uses too much standby power, an IEC cord, and a power strip.  The last 2 items are for when I'm working on some equipment and I want to be able to make sure it's turned off (especially if it has a soft power switch).
The second power center is connected to my soldering equipment, so I can make sure it's all turned off when I leave.
« Last Edit: September 25, 2025, 05:42:01 pm by edavid »
Offline BrianHG
    • LinkedIn
« Reply #2 on: September 26, 2025, 02:22:23 am »
OMG, talk about going down memory lane...
Offline edpalmer42
« Reply #3 on: September 26, 2025, 03:28:28 am »
I bought a couple of them a few years ago for use on my test bench.  I use them with equipment that either doesn't have a power switch or has the switch on the back.
