Author Topic: Tandy 1100fd, What LCD does it use?  (Read 3223 times)
Offline DiTBhoTopic starter
« on: April 17, 2024, 11:25:20 am »
made in 1989, I can't find any teardown that shows any precise information, like...
  • mechanical dimensions
  • what interface it uses at the signal level
it's only known that it's a grayscale CGA LCD  :-//
Offline EEVblog
Re: Tandy 1100fd, What LCD does it use?
« Reply #1 on: April 17, 2024, 12:30:45 pm »
I used to own one. I think I still have the technical reference manual somewhere in the bunker.
IIRC it was a twisted nematic hitachi chipset.
Offline coromonadalix
« Reply #2 on: April 17, 2024, 05:19:38 pm »
Display: LCD super-twisted nematic, green Chip Set MN5504 LCD CGA emulation     ???  from vintage computer
The 1100 FD has an 80 x 25, high-contrast liquid crystal display
with 640 x 200 resolution.  The fold-over display measures
approximately nine inches diagonally and closely resembles the
aspect ratio of conventional video monitors.
known  under :  Panasonic Business Partner 150  ???
« Reply #3 on: April 17, 2024, 05:36:10 pm »
found some info here.
if you find the time, can you open, and measure the STN LCD-panel size?
Offline EEVblog
« Reply #4 on: April 19, 2024, 12:11:08 am »
Sold it a long time ago. I think I still have the technical manual.
The following users thanked this post: DiTBho, fabriciotm
Offline fabriciotm
  • Country: br
« Reply #5 on: July 26, 2024, 10:55:23 pm »
I'm also looking for this service manual. My screen broke and I want to see if I can use another one. Please save me.
Offline hexbus
« Reply #6 on: November 12, 2024, 01:07:55 am »
If you find this manual, please scan it.  The community has been looking for it for the past decade.... seriously :)  (I registered here just to say that)  One such post:https://forum.vcfed.org/index.php?threads/panasonic-business-partner-150-tandy-1100-fd-rom-image.72011/....
I've been trying to coax Panasonic to release the BP150 service manual (it's the same system but with a backlight) but haven't been able to get that SM either.
EMS ram card:  https://imgur.com/gallery/panasonic-bp150-cf-ba161-1mb-ram-card-yOlTTvy
(BTW, I'm new - but hey there - Atlanta Historic Computing Society's in the house!) :)
Here's the parts list in case anyone wants it....from a web scrape.
Manufacturer Item Code Description Location Exch Price EA Core Price EA Total Price EA Status Qty
PANASONIC (MATSUSHITA) 2SB1073QTW TRANSISTOR - $7.05 $0.00 $7.05 Not Stocked
PANASONIC (MATSUSHITA) 2SD1257P TRANSISTOR - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) 2SD592ANCQ TRANSISTOR - $3.33 $0.00 $3.33 Not Stocked
PANASONIC (MATSUSHITA) 2SD592AR TRANSISTOR - $3.86 $0.00 $3.86 Not Stocked
PANASONIC (MATSUSHITA) 2SJ-U1S50J CONNECTOR - $17.96 $0.00 $17.96 Not Stocked
PANASONIC (MATSUSHITA) 6000-0049-00 CABLE - $10.98 $0.00 $10.98 Not Stocked
PANASONIC (MATSUSHITA) AN8002 IC - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) CF-AA910Z ADAPTER - $77.80 $0.00 $77.80 Not Stocked
PANASONIC (MATSUSHITA) CF-AA96C ADAPTER - $147.92 $0.00 $147.92 Not Stocked
PANASONIC (MATSUSHITA) CF-AA96M ADAPTER - $107.12 $0.00 $107.12 Not Stocked
PANASONIC (MATSUSHITA) CF-ZS9612 BATTERY - $51.10 $0.00 $51.10 Not Stocked
PANASONIC (MATSUSHITA) CF150IB INSTRUCT BOOK - $18.68 $0.00 $18.68 Not Stocked
PANASONIC (MATSUSHITA) CR2477-1GVF BATTERY - $15.19 $0.00 $15.19 Not Stocked
PANASONIC (MATSUSHITA) CR2477-1VC BATTERY 3V LITH VANADIUM VERT - $22.17 $0.00 $22.17 Not Stocked
PANASONIC (MATSUSHITA) DA14C88 IC - $7.21 $0.00 $7.21 Not Stocked
PANASONIC (MATSUSHITA) DA14C88MTEN IC - $7.21 $0.00 $7.21 Not Stocked
PANASONIC (MATSUSHITA) DA14C89 IC - $14.77 $0.00 $14.77 Not Stocked
PANASONIC (MATSUSHITA) DA14C89AMTEN IC - $14.77 $0.00 $14.77 Not Stocked
PANASONIC (MATSUSHITA) DA150A1 IC - $58.85 $0.00 $58.85 Not Stocked
PANASONIC (MATSUSHITA) DA150B1 IC - $21.83 $0.00 $21.83 Not Stocked
PANASONIC (MATSUSHITA) DA150C1 IC - $34.99 $0.00 $34.99 Not Stocked
PANASONIC (MATSUSHITA) DA2050F0AW IC - $51.49 $0.00 $51.49 Not Stocked
PANASONIC (MATSUSHITA) DA49HG-528 IC - $15.09 $0.00 $15.09 Not Stocked
PANASONIC (MATSUSHITA) DA49HG-530 IC - $51.34 $0.00 $51.34 Not Stocked
PANASONIC (MATSUSHITA) DA70108G-8D IC - $47.32 $0.00 $47.32 Not Stocked
PANASONIC (MATSUSHITA) DA74HCU04AF0 IC - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DA93C46001XQ IC - $10.58 $0.00 $10.58 Not Stocked
PANASONIC (MATSUSHITA) DALM393ML IC - $3.80 $0.00 $3.80 Not Stocked
PANASONIC (MATSUSHITA) DAM5237LTAM IC - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DAM5247FPT IC - $4.33 $0.00 $4.33 Not Stocked
PANASONIC (MATSUSHITA) DARF5C15-T IC - $16.12 $0.00 $16.12 Not Stocked
PANASONIC (MATSUSHITA) DCCD3F220J CAPACITOR - $2.52 $0.00 $2.52 Not Stocked
PANASONIC (MATSUSHITA) DDA895Z221K COIL - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DDAWZ151KV COIL - $7.05 $0.00 $7.05 Not Stocked
PANASONIC (MATSUSHITA) DDAWZ221KV COIL - $4.11 $0.00 $4.11 Not Stocked
PANASONIC (MATSUSHITA) DDAWZ330KV COIL - $7.05 $0.00 $7.05 Not Stocked
PANASONIC (MATSUSHITA) DDB1Z029 COIL - $2.09 $0.00 $2.09 Not Stocked
PANASONIC (MATSUSHITA) DDB1Z084T COIL - $7.05 $0.00 $7.05 Not Stocked
PANASONIC (MATSUSHITA) DDB6Z003T COIL - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DDB7Z003T COIL - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DDB8Z008 COIL - $13.00 $0.00 $13.00 Not Stocked
PANASONIC (MATSUSHITA) DDI9Z009 TRANSFORMER - $24.93 $0.00 $24.93 Not Stocked
PANASONIC (MATSUSHITA) DEANR4J5J103 ARRAY - $3.02 $0.00 $3.02 Not Stocked
PANASONIC (MATSUSHITA) DEANR4J5J472 ARRAY - $3.02 $0.00 $3.02 Not Stocked
PANASONIC (MATSUSHITA) DEBM11R7N1LX CRYSTAL - $4.27 $0.00 $4.27 Not Stocked
PANASONIC (MATSUSHITA) DEBM16R0N2LX CRYSTAL - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DECQ00032H3W CRYSTAL - $3.02 $0.00 $3.02 Not Stocked
PANASONIC (MATSUSHITA) DED03P2JT1 THYRISTOR - $4.97 $0.00 $4.97 Not Stocked
PANASONIC (MATSUSHITA) DEDAY5551KS DIODE - $3.26 $0.00 $3.26 Not Stocked
PANASONIC (MATSUSHITA) DEDC3P2JT1 DIODE - $4.61 $0.00 $4.61 Not Stocked
PANASONIC (MATSUSHITA) DEDRC81004L9 DIODE - $10.65 $0.00 $10.65 Not Stocked
PANASONIC (MATSUSHITA) DENAE1B103TL CONTROL - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DENAE1B332TL CONTROL - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DEVAI3B502 CONTROL - $35.71 $0.00 $35.71 Not Stocked
PANASONIC (MATSUSHITA) DFAC0002ZAW LAMP - $71.82 $0.00 $71.82 Not Stocked
PANASONIC (MATSUSHITA) DFAFPKM174EP BUZZER - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DFBC0052Z1 KNOB **NLA** - $2.60 $0.00 $2.60 Unavailable
PANASONIC (MATSUSHITA) DFBD0023Z1 KNOB - $2.76 $0.00 $2.76 Not Stocked
PANASONIC (MATSUSHITA) DFBD0024Z2 KNOB - $3.26 $0.00 $3.26 Not Stocked
PANASONIC (MATSUSHITA) DFDH0006Z BOARD - $42.21 $0.00 $42.21 Not Stocked
PANASONIC (MATSUSHITA) DFGX0076Z1 COVER - $5.86 $0.00 $5.86 Not Stocked
PANASONIC (MATSUSHITA) DFGX0077Z COVER - $4.27 $0.00 $4.27 Not Stocked
PANASONIC (MATSUSHITA) DFHG201Z HOLDER - $3.18 $0.00 $3.18 Not Stocked
PANASONIC (MATSUSHITA) DFHG202Z HOLDER - $3.18 $0.00 $3.18 Not Stocked
PANASONIC (MATSUSHITA) DFHG917Z2 SEAL - $1.67 $0.00 $1.67 Not Stocked
PANASONIC (MATSUSHITA) DFHG919Y RUBBER - $11.34 $0.00 $11.34 Not Stocked
PANASONIC (MATSUSHITA) DFHR51542Z2 HOOK - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DFHR5154Z2 HOOK - $1.09 $0.00 $1.09 Not Stocked
PANASONIC (MATSUSHITA) DFHR5154ZA-2 HOOK - $3.10 $0.00 $3.10 Not Stocked
PANASONIC (MATSUSHITA) DFHR5159Z PROTECTOR - $1.09 $0.00 $1.09 Not Stocked
PANASONIC (MATSUSHITA) DFHR7069Z PLATE - $9.65 $0.00 $9.65 Not Stocked
PANASONIC (MATSUSHITA) DFHR8052Z CUSHION - $1.09 $0.00 $1.09 Not Stocked
PANASONIC (MATSUSHITA) DFHR8053Z CUSHION - $1.09 $0.00 $1.09 Not Stocked
PANASONIC (MATSUSHITA) DFJE24A105AS CABLE - $9.81 $0.00 $9.81 Not Stocked
PANASONIC (MATSUSHITA) DFJN183Z DISC - $21.60 $0.00 $21.60 Not Stocked
PANASONIC (MATSUSHITA) DFJP00Z55Z CONNECTOR - $10.65 $0.00 $10.65 Not Stocked
PANASONIC (MATSUSHITA) DFJP02C32Z CONNECTOR - $2.18 $0.00 $2.18 Not Stocked
PANASONIC (MATSUSHITA) DFJP02C55ZAJ CONNECTOR - $2.35 $0.00 $2.35 Not Stocked
PANASONIC (MATSUSHITA) DFJP02C59Z CONNECTOR - $1.91 $0.00 $1.91 Not Stocked
PANASONIC (MATSUSHITA) DFJP02C63Z CONNECTOR - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DFJP03C11Y CONNECTOR - $2.35 $0.00 $2.35 Not Stocked
PANASONIC (MATSUSHITA) DFJP08C13Z CONNECTOR - $2.18 $0.00 $2.18 Not Stocked
PANASONIC (MATSUSHITA) DFJP09E14Z CONNECTOR - $10.08 $0.00 $10.08 Not Stocked
PANASONIC (MATSUSHITA) DFJP50D10Z CONNECTOR - $18.38 $0.00 $18.38 Not Stocked
PANASONIC (MATSUSHITA) DFJS00Z92Z CABLE - $45.04 $0.00 $45.04 Not Stocked
PANASONIC (MATSUSHITA) DFJS01Z01Z CABLE - $45.04 $0.00 $45.04 Not Stocked
PANASONIC (MATSUSHITA) DFJS02C20Z CONNECTOR - $4.24 $0.00 $4.24 Not Stocked
PANASONIC (MATSUSHITA) DFJS02C30Z CONNECTOR - $2.18 $0.00 $2.18 Not Stocked
PANASONIC (MATSUSHITA) DFJS08N19Z CONNECTOR - $2.18 $0.00 $2.18 Not Stocked
PANASONIC (MATSUSHITA) DFJS14N19Z CONNECTOR - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DFJS24N13Z CONNECTOR - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) DFJS28R11Z SOCKET - $4.70 $0.00 $4.70 Not Stocked
PANASONIC (MATSUSHITA) DFKE0145Z1 COVER - $3.44 $0.00 $3.44 Not Stocked
PANASONIC (MATSUSHITA) DFKE0146Z1 COVER - $3.44 $0.00 $3.44 Not Stocked
PANASONIC (MATSUSHITA) DFKK0014Y0 COVER - $11.08 $0.00 $11.08 Not Stocked
PANASONIC (MATSUSHITA) DFKK0014Z0 COVER - $11.08 $0.00 $11.08 Not Stocked
PANASONIC (MATSUSHITA) DFKM0092Y0 CASE - $27.40 $0.00 $27.40 Not Stocked
PANASONIC (MATSUSHITA) DFKM0092Z1 CASE - $12.73 $0.00 $12.73 Not Stocked
PANASONIC (MATSUSHITA) DFKM0094X0 CABINET - $37.23 $0.00 $37.23 Not Stocked
PANASONIC (MATSUSHITA) DFKM0094Y0 CASE - $22.07 $0.00 $22.07 Not Stocked
PANASONIC (MATSUSHITA) DFMC0209Z PLATE - $10.91 $0.00 $10.91 Not Stocked
PANASONIC (MATSUSHITA) DFMC0221Y PLATE - $15.68 $0.00 $15.68 Not Stocked
PANASONIC (MATSUSHITA) DFMC0222Y PLATE - $10.82 $0.00 $10.82 Not Stocked
PANASONIC (MATSUSHITA) DFMC0223Y PLATE - $2.86 $0.00 $2.86 Not Stocked
PANASONIC (MATSUSHITA) DFMC0239Y PLATE - $4.70 $0.00 $4.70 Not Stocked
PANASONIC (MATSUSHITA) DFMD2028Z FRAME - $9.15 $0.00 $9.15 Not Stocked
PANASONIC (MATSUSHITA) DFMX0154Z SHEET - $0.97 $0.00 $0.97 Not Stocked
PANASONIC (MATSUSHITA) DFPE0025Z HANGER - $4.17 $0.00 $4.17 Not Stocked
PANASONIC (MATSUSHITA) DFPE0095Z CASE - $2.81 $0.00 $2.81 Not Stocked
PANASONIC (MATSUSHITA) DFPE0103Z PAD - $3.02 $0.00 $3.02 Not Stocked
PANASONIC (MATSUSHITA) DFPH0033Z SHEET - $1.57 $0.00 $1.57 Not Stocked
PANASONIC (MATSUSHITA) DFPK0370Z CARTON - $15.30 $0.00 $15.30 Not Stocked
PANASONIC (MATSUSHITA) DFPK0386Z CASE - $20.30 $0.00 $20.30 Not Stocked
PANASONIC (MATSUSHITA) DFPN9057Z CUSHION - $16.93 $0.00 $16.93 Not Stocked
PANASONIC (MATSUSHITA) DFQX2202YA INSTRUCT BOOK - $13.33 $0.00 $13.33 Not Stocked
PANASONIC (MATSUSHITA) DFSH1A14W SWITCH - $12.42 $0.00 $12.42 Not Stocked
PANASONIC (MATSUSHITA) DFSJ1A14W SWITCH - $12.42 $0.00 $12.42 Not Stocked
PANASONIC (MATSUSHITA) DFSX1A03Z KEYBOARD - $46.53 $0.00 $46.53 Not Stocked
PANASONIC (MATSUSHITA) DFUA0092Y FRAME - $27.40 $0.00 $27.40 Not Stocked
PANASONIC (MATSUSHITA) DFUW0032Z SPRING - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DFUW0032Z2A SPRING - $1.90 $0.00 $1.90 Not Stocked
PANASONIC (MATSUSHITA) DFUW0032ZA SPRING - $1.76 $0.00 $1.76 Not Stocked
PANASONIC (MATSUSHITA) DFWV08A004YA DISPLAY - $394.06 $0.00 $394.06 Not Stocked
PANASONIC (MATSUSHITA) DFWV08A004Z DISPLAY - $425.58 $0.00 $425.58 Not Stocked
PANASONIC (MATSUSHITA) DFWV08A004ZA DISPLAY - $425.58 $0.00 $425.58 Not Stocked
PANASONIC (MATSUSHITA) DFWV08A0052Z DISPLAY - $434.19 $0.00 $434.19 Not Stocked
PANASONIC (MATSUSHITA) DFWV08A005YA DISPLAY - $322.97 $0.00 $322.97 Not Stocked
PANASONIC (MATSUSHITA) DFWV08A005ZA DISPLAY - $322.97 $0.00 $322.97 Not Stocked
PANASONIC (MATSUSHITA) DFWV38A0032 FUSE - $8.03 $0.00 $8.03 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C146Z PRINTED CIRCUIT - $6.72 $0.00 $6.72 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C146ZA SWITCH - $7.12 $0.00 $7.12 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C147WA PC BOARD - $741.81 $0.00 $741.81 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C147Z PC BOARD - $750.59 $0.00 $750.59 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C147ZA PC BOARD - $750.59 $0.00 $750.59 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C153VA PC BOARD - $790.71 $0.00 $790.71 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C153WA PC BOARD - $718.65 $0.00 $718.65 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C153Z PC BOARD - $750.59 $0.00 $750.59 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C153ZA PC BOARD - $797.81 $0.00 $797.81 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C154ZA PC BOARD - $1,136.94 $0.00 $1,136.94 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C155Z PC BOARD - $33.49 $0.00 $33.49 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C155ZA PC BOARD - $33.49 $0.00 $33.49 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C156Z PC BOARD - $46.90 $0.00 $46.90 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C156ZA PC BOARD - $46.90 $0.00 $46.90 Not Stocked
PANASONIC (MATSUSHITA) DFWV48C157ZA PC BOARD - $125.77 $0.00 $125.77 Not Stocked
PANASONIC (MATSUSHITA) DFWV50B0006 SCREW - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DFWV65A0164 HINGE - $2.18 $0.00 $2.18 Not Stocked
PANASONIC (MATSUSHITA) DFWV65A0165 HINGE - $2.18 $0.00 $2.18 Not Stocked
PANASONIC (MATSUSHITA) DFWV65C0177 SHEET - $0.97 $0.00 $0.97 Not Stocked
PANASONIC (MATSUSHITA) DFWV65D0022 SPRING - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3466 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3467 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3468 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3469 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3470 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3471 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3472 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3473 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3474 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3475 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3476 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3477 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3478 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3479 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3480 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3481 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3482 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3483 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3484 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3485 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3486 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3487 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3488 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3489 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3490 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3491 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3492 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3493 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3494 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3495 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3496 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3497 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3498 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3499 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3500 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3501 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3502 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3503 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3504 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3505 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3506 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3507 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3508 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3509 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3510 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3511 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3512 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3513 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3514 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3515 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3516 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3517 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3518 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3519 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3520 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3521 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3522 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3523 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3524 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3525 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3526 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3527 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3528 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3529 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3530 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3531 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3532 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3533 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3534 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3535 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3536 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3537 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3538 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3539 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3540 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3541 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3542 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3543 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3544 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3545 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3546 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3547 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3548 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3549 KEYTOP - $16.70 $0.00 $16.70 Not Stocked
PANASONIC (MATSUSHITA) DFWV70C3617 KEY - $18.04 $0.00 $18.04 Not Stocked
PANASONIC (MATSUSHITA) DFWV71H0025 ROD - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DFWV71H0026 ROD - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DFWV71H0027 ROD - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) DFWV80C0123 CASE - $31.83 $0.00 $31.83 Not Stocked
PANASONIC (MATSUSHITA) DFWV80C0129 CASE - $30.92 $0.00 $30.92 Not Stocked
PANASONIC (MATSUSHITA) DFWV84A0055 CABINET - $82.14 $0.00 $82.14 Not Stocked
PANASONIC (MATSUSHITA) DFWV84A0056 CABINET - $82.14 $0.00 $82.14 Not Stocked
PANASONIC (MATSUSHITA) DFWV95C0068 CABLE - $50.29 $0.00 $50.29 Not Stocked
PANASONIC (MATSUSHITA) DFWV99B0072 DISPLAY - $287.71 $0.00 $287.71 Not Stocked
PANASONIC (MATSUSHITA) DLH3-95 TEST TOOL - $38.42 $0.00 $38.42 Not Stocked
PANASONIC (MATSUSHITA) DWSH1A14W SWITCH - $12.42 $0.00 $12.42 Not Stocked
PANASONIC (MATSUSHITA) ECHS1H683JZ CAPACITOR - $4.11 $0.00 $4.11 Not Stocked
PANASONIC (MATSUSHITA) ECUX1H101JCG CAPACITOR - $1.35 $0.00 $1.35 Not Stocked
PANASONIC (MATSUSHITA) ELEPL101KA COIL - $3.18 $0.00 $3.18 Not Stocked
PANASONIC (MATSUSHITA) EME-213AMC FDD UNIT - $168.95 $0.00 $168.95 Not Stocked
PANASONIC (MATSUSHITA) EME213AMC DISK - $199.11 $0.00 $199.11 Not Stocked
PANASONIC (MATSUSHITA) EME213AMCJ DISK DRIVE - $207.26 $0.00 $207.26 Not Stocked
PANASONIC (MATSUSHITA) EME213AMCV DISK DRIVE - $160.97 $0.00 $160.97 Not Stocked
PANASONIC (MATSUSHITA) EME213MCV DISK DRIVE - $160.97 $0.00 $160.97 Not Stocked
PANASONIC (MATSUSHITA) ER0S2TKF1052 RESISTOR - $1.00 $0.00 $1.00 Not Stocked
PANASONIC (MATSUSHITA) ERJ14YJ241 RESISTOR - $1.21 $0.00 $1.21 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF1202 RESISTOR - $1.21 $0.00 $1.21 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF2002 RESISTOR - $1.05 $0.00 $1.05 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF2201 RESISTOR - $1.21 $0.00 $1.21 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF3001 RESISTOR - $0.95 $0.00 $0.95 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF3602 RESISTOR - $1.31 $0.00 $1.31 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF4021 RESISTOR - $1.56 $0.00 $1.56 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF4301 RESISTOR - $1.21 $0.00 $1.21 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF6801 RESISTOR - $1.56 $0.00 $1.56 Not Stocked
PANASONIC (MATSUSHITA) ERJ6ENF7501 RESISTOR - $1.56 $0.00 $1.56 Not Stocked
PANASONIC (MATSUSHITA) ERJ6GMYJ202 RESISTOR - $1.12 $0.00 $1.12 Not Stocked
PANASONIC (MATSUSHITA) ERJ6GMYJ432 RESISTOR - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) ERJ6GMYJ621 RESISTOR - $1.12 $0.00 $1.12 Not Stocked
PANASONIC (MATSUSHITA) ERJ6MYJ201 RESISTOR - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) EVNAIAA00B14 CONTROL - $67.24 $0.00 $67.24 Not Stocked
PANASONIC (MATSUSHITA) IB-CF150 INSTRUCT BOOK - $7.29 $0.00 $7.29 Not Stocked
PANASONIC (MATSUSHITA) IB-CF150B INSTRUCT BOOK - $7.29 $0.00 $7.29 Not Stocked
PANASONIC (MATSUSHITA) K-C1526TAE4 LAMP - $28.97 $0.00 $28.97 Not Stocked
PANASONIC (MATSUSHITA) K-C152T6AE4 BACK LIGHT - $33.78 $0.00 $33.78 Not Stocked
PANASONIC (MATSUSHITA) MA3062MTW DIODE - $2.35 $0.00 $2.35 Not Stocked
PANASONIC (MATSUSHITA) MA3075MTW DIODE - $2.42 $0.00 $2.42 Not Stocked
PANASONIC (MATSUSHITA) MA3240MTW DIODE - $2.76 $0.00 $2.76 Not Stocked
PANASONIC (MATSUSHITA) MN12862 IC - $76.80 $0.00 $76.80 Not Stocked
PANASONIC (MATSUSHITA) MN41C4256L08 IC - $68.19 $0.00 $68.19 Not Stocked
PANASONIC (MATSUSHITA) MN53020RFQ IC - $34.47 $0.00 $34.47 Not Stocked
PANASONIC (MATSUSHITA) MN53030RFS IC - $88.15 $0.00 $88.15 Not Stocked
PANASONIC (MATSUSHITA) MN5502 IC - $76.80 $0.00 $76.80 Not Stocked
PANASONIC (MATSUSHITA) QG-CF150B INSTRUCT BOOK - $13.33 $0.00 $13.33 Not Stocked
PANASONIC (MATSUSHITA) RHG338Z0 FOOT - $1.01 $0.00 $1.01 Not Stocked
PANASONIC (MATSUSHITA) SM-CF150 SERVICE MANUAL - $19.64 $0.00 $19.64 Not Stocked
PANASONIC (MATSUSHITA) UP6V1R8AJHP BATTERY - $59.12 $0.00 $59.12 Not Stocked
PANASONIC (MATSUSHITA) UP6V1R8AJHP1 BATTERY - $53.40 $0.00 $53.40 Not Stocked
PANASONIC (MATSUSHITA) XBA0800VFS FUSE - $7.79 $0.00 $7.79 Not Stocked
PANASONIC (MATSUSHITA) XBAD0800VFS FUSE - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) XBAD2500VFS FUSE - $3.52 $0.00 $3.52 Not Stocked
PANASONIC (MATSUSHITA) XBAD72R500K FUSE - $6.72 $0.00 $6.72 Not Stocked
PANASONIC (MATSUSHITA) XBADPR1R6005 FUSE - $4.64 $0.00 $4.64 Not Stocked
PANASONIC (MATSUSHITA) XBADSNR80003 FUSE - $6.55 $0.00 $6.55 Not Stocked
PANASONIC (MATSUSHITA) XTV3+10GFN SCREW - $1.01 $0.00 $1.01 Not Stocked
« Last Edit: November 12, 2024, 01:19:53 am by hexbus »
Offline EEVblog
« Reply #7 on: November 12, 2024, 04:03:59 am »
I'm pretty sure I know where it is down in my storage bunker, I might drop past on my way home today. IIRC it had fold out schematics as well.
Offline EEVblog
« Reply #8 on: November 12, 2024, 05:04:01 am »
Got it!
Fold out A3 schematics
Glue binding though unfortunately I'll have to cut the spine off to scan it, but I don't have the cutter to do that, would have to get one.
Can probably rip out the A3 schematics and scan those.
I have my dumpster A3 copier/scanner thing
Currently asking on X for the best way to de-bind it so it's scannable.
https://x.com/eevblog/status/1856201958987837919
« Last Edit: November 12, 2024, 05:34:07 am by EEVblog »
The following users thanked this post: coromonadalix
Offline EEVblog
« Reply #9 on: November 12, 2024, 06:15:11 am »
I used a document scanner I had, rate how usable this is:
https://eevblog.org/files/Tandy1100FD-Addendum.pdf
It's OCR PDF searchable too.
Will have the scan the A3 schematics separately.
Offline EEVblog
« Reply #11 on: November 13, 2024, 12:42:58 am »
The following users thanked this post: fabriciotm, hexbus
Offline hexbus
« Reply #12 on: November 13, 2024, 05:57:58 pm »
Final scans:
https://eevblog.com/files/Tandy1100FD-Service-Manual-Schematics.pdf
https://eevblog.com/files/Tandy1100FD-Service-Manual.pdf
https://eevblog.com/files/Tandy1100FD-Service-Manual-Addendum.pdf
YOU ROCK!
Thank you SO MUCH!  I'll make sure this gets to TVDog and to VCFed and to the other people who have been looking that I know.  This also mostly covers the Panasonic Business Partner 150, which was the same machine, different ROMs, and had a small daughter card with an inverter that supplied HV for a LCD backlight.  (Tandy was too cheap with their BOM to add that and wanted the profit margin.)
The following users thanked this post: EEVblog
Offline EEVblog
« Reply #13 on: November 13, 2024, 09:51:14 pm »
Final scans:
YOU ROCK!
Thanks. It's already indexed on Google as the first hit for 1100FD service manual, but yeah, definitely needs to go on all the retro sites.
Offline hexbus
« Reply #14 on: November 14, 2024, 02:24:25 pm »
The biggest bonus?  We have the ISA card compatible pinout now!  This was previously only used for the very rare 1MB EMS card I posted a link to.  We can try to make an adapter to a small ISA card like the PicoMem (I don't know if it'll fit, but we can try).
Also, the addendum for the backlight was essentially the Panasonic BP150, so we have the service manual for THAT model now too in essence!  (Yours had the daughter card inside the system schematic as well as the bits that went inside the display lid!)
I just sent the entire lot to FedEx Printing to get a nice coiled book printed to make my own manual, and to get the schematics printed on A3 size paper.
The following users thanked this post: EEVblog, coromonadalix
