Author Topic: HP 2648 running at 50 hz  (Read 1429 times)
Offline Cocorito PapTopic starter
« on: April 21, 2021, 06:34:40 am »
Hello,
I got an HP2648 terminal from the US.
I read in the manual that if you run the machine with 230V 50Hz power ( like we have in Europe ) beside changing a couple of fuses , you should also replace the display timing card crystal.
The one required is 17.5 Mhz but I am not able to find this anywhere.
What if use a crystal with a frequency close to the required one , say 17.1 Mhz ?
Would this work ?
Thanks
Ste
Offline james_s
Re: HP 2648 running at 50 hz
« Reply #1 on: April 21, 2021, 07:20:52 am »
I suspect this is just to prevent interference between the video refresh rate and the mains frequency. Personally I would try it as-is and see if it causes any problems.
« Reply #2 on: April 22, 2021, 07:02:37 am »
This makes sense, thanks.
What about using a crystal with frequency close to the one required ( 17.1 Mhz for example ? ) .
Ste
Offline fcb
    • Electron Plus
« Reply #3 on: April 22, 2021, 08:26:14 am »
What crystal is fitted for 60Hz? Frequency? Size? Cut?
17.28MHz is a fairly available in the UK, however is might not be as simple as just changing the crystal - the drive circuit is likely to be tailored to the cut of the crystal, might work, might not.
Offline Phil_G
  • G4PHL
« Reply #4 on: April 22, 2021, 09:28:31 am »
If its only for project work you could buy a cheap Chinese 60hz pure-sine inverter and run it from your bench PSU.
« Last Edit: April 22, 2021, 09:54:12 am by Phil_G »
« Reply #5 on: April 22, 2021, 02:47:55 pm »
For 60Hz is 21.06 MHz
« Last Edit: April 22, 2021, 03:00:17 pm by Cocorito Pap »
« Reply #6 on: April 22, 2021, 02:51:44 pm »
That is an option , but my OCD is strong with this one .
