Well thing is that software emulating a parallel memory bus is hard work. Even a slow 20MHz bus is actually pretty fast in terms of latency. Sure MCUs have interrupts but a modern ARM take about 10 to 20 or even more cycles to enter an interrupt routine because it has to context switch. So even if it takes 10 cycles and you have a 180 MHz CPU you can only enter an interrupt at a rate of 18MHz, but this doesn't include the time taken to also exit it so that the interrupt can be called again, halving it again to 9MHz. And this is without any code inside the routine, as soon as you add actual code that does something it will take even longer to complete the interrupt. So this makes it very difficult for a MCU to pretend as being SRAM on the bus. What is easier to do is to talk to the MCU over something like a parallel port since in that case the Z80 can talk to it however slowly it wants. But you could implement something in between by having a dual port FIFO chip for write operations to the MCU. That way the Z80 can barf data at it at full speed and get back to doing other things while the MCU works trough it as its own pace. So then only read operations would be slow.
All of this means you also can't really use a Raspberry Pi GPIO bus to directly connect to a Z80 bus. Sure the CPU might run at 1.2 GHz but its still not responsive enough because GPIO is on a slower peripheral bus, interrupt latency is really long and running linux means the CPU is constantly interrupted by the OS scheduler so response times are all over the place. As for getting OpenGL working there is a nice simple library for it called RayLib (
https://www.raylib.com/) and you don't have to use it for any 3D, works for 2D just as well but all of that 2D is done in hardware by the GPU so its very fast.
On the other hand a FPGA could handle running a Z80 bus at 200 MHz just fine while simultaneously generating 4K video output and emulating a FM synth with 32 voices. Actually mplementing a simple GPU in a FPGA is not all that hard. Tilemaing, sprites and ROM text are easy, because its just a matter of looking up the correct pixels in memory. Things get more complicated if you want fancy features like the SNES Mode 7 effects and similar things from the 16bit era. These simple GPUs also usually have no features for drawing lines or shapes (They tend to get some of those abilities once they are for 3D ).
In general FPGAs are very useful with retro computers because they can interface to pretty much anything, allowing you to easily implement custom addin cards, coprocessors, accelerators... etc by simply loading new firmware into a FPGA chip. Makes it easy to emulate the custom hardware on motherboards from home computers like a C64, AppleII etc. heck even the entire Z80 could run inside the FPGA, and run faster than your real chip even, but emulating the entire system inside a FPGA doesn't really have as much of a retro charm to it.
