Author Topic: Macintosh LC II not being able to see two hard drives at the same time  (Read 1238 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
I got an LCII with a hard drive inside.
As I wanted a second hard drive I decided to make an adaptor to connect my other SCSI drive to it's rear SCSI port.
If I start with the external HD connected it boots from the external Hd and the internal is not visible.
If I start with the internal HD and later connect the external HD the external does not mount.
Anything I should do such as setting the external as slave? Or come pinout on my adapter that I am missing?
Offline tunk
  • Country: no
The following users thanked this post: I wanted a rude username
Re: Macintosh LC II not being able to see two hard drives at the same time
« Reply #2 on: August 01, 2020, 10:14:11 am »
that makes sense, thanks!
they both mount at bus 0. I will see if I find a jumper to change their scsi id.
