Hi James, Sorry to all for opening up an old post but I'd love to know how you went on this.
I'm doing something similar, and as I haven't had time to build the hardware, I wrote the OS and while I come from a background of non-preemptive multitasking code, have switched to a single thread for my latest build, and wrote a new version of CP/M which I published openly on Github a few months ago. The repository is called LokiOS, and includes a Windows-10 compatible z80 assembler and an emulated Z80 environment that matches the original believed Loki architecture developed by Sinclair in the 80s but that was never brought to market.
Anyway, I was wondering how you were progressing.? It would be great to hear about what you were further doing in this space.
On the topic of OS, I'd recommend considering CP/M over DOS structures.
My ultimate intent is to drop in a preemptive multitasking overlay on CP/M 2.2 ( or rather, on the rewritten CP/M I wrote, though in practice, it would work with CP/M 2.2 also ) as my existing architecture has hardware support for process IDs, including hardware switching of mapped RAM when a process is running, with support, ultimately, for up to 256 concurrent processes, although I'll probably drop that to around 128 for the prototype. This allows a kernel task switcher to occupy it's own process, interrupt any other process, restructure the MMU to page in the other process and whatever supporting memory blocks it used, execute it, then switch back to the current or next task while maintaining state.
At present, it's just running in an emulator as I develop it, and so far, the only hardware I have put together was a proof-of-concept 256x192 ( or 512x192 ) display card that runs off of just five small chips that were all from 1985 to avoid building it with anything not of it's era. It also has some interesting features, like an ISA backplane ( rather than say a RC2014 ) so should be able to take PC cards as well, if the bios are reprogrammed and it extends on stock CP/M 2.2 structures to provide things like resident drivers, extra-bios services and uses the standard CP/M 2.2 BDOS routines as a defacto MMU system, so it creates a process list that can be viewed like linux, but can be copied like DOS - eg, A "Snapshot" of a process can be saved with a simple copy command, and process use can be interwoven with ramdisk use in real time without the need for drivers - with all memory being accessed in one of three ways. Directly ( MMU maps 4K blocks over 64K ) - Indirect ( All memory is accessed as I/O space in 128 byte chunks as CP/M likes it ) - and Disk ( A process or even the video RAM can be opened up as a file, and read to and written directly ).
As you can imagine, this is built over the top of a compatible CP/M OS, so much of this is implemented in hardware rather than software, but it uses CP/Ms quirks to support it directly - so my MMU is mapped as M: drive, and showing a directory of M: shows all the current processes and memory mapping of the MMU, and this is all stored in the flat CP/M directory structure that lends itself to such applications which DOS FAT does not.
So if you want to introduce compatability with z80 software in an OS that can multitask, it's not that difficult to expand CP/M or even write your own to extend into multitasking even if you ignore MPM and Concurrent CP/M. Though the biggest task I had in writing CP/M from scratch in a new OS was actually making it CP/M compatible... That's an overhead that the DOS programmers didn't have.
Anyway, if you have an update on where your project has gone from here, I'd love to hear it! And maybe borrow any good ideas you developed in your travels.
( And you are welcome also to borrow mine... The OS I wrote is available and if you strip the LOKI architecture away from it, it's just CP/M... So much so that I include a copy of DRI's CP/M source with it and my OS can be swapped out with the original DRI CP/M BDOS or CCP at will and still works... ). Well, there's some bugs still in how they both come together, but mostly it works and it's more of use in debugging why CP/M software isn't working than in any practical advantage gained from hotswapping the BDOS and CCP.
Also, In case you're not familiar with solo-writing an OS, it is possible, but it's a big task. Writing a CP/M compatible OS from the ground up took me more than 3 months, or more than a year part time if you include the development environment... But I think the number of people who have written a complete OS without borrowing code can still be counted on one's fingers. Even CP/M itself had many builders.
Good luck with your endeavor.
David.
David.
