Computing => Vintage Computing => Topic started by: joeqsmith on February 06, 2018, 06:02:08 pm
Feel free to post pictures of your oddball vintage IBM PC/XT/AT compatible cards.
To get started, this is an old IRMA board used to interface the PCXT with an IBM 3270.
https://en.wikipedia.org/wiki/Irma_board
For you early network people, here is a Proteon ProNET-4 board for the AT.
http://www.historyofcomputercommunications.info/Book/12/12.22_Proteon.html (http://www.historyofcomputercommunications.info/Book/12/12.22_Proteon.html)
A couple of videos showing my old PC/AT powering up with some of my own hardware and doing some speech recognition for the fun of it. Life was simple in those days.
https://youtu.be/Ju96T2SPcMA
https://youtu.be/N85dGIrcT5E
I dearly remember those IRMA ISA cards. I once fiddled with them back in early eighties to connect IBM PCs with mainframes using 3270 protocol. Later, IBM developed its own 3270 emulation card in their PC-3270 (5271) computers.
I think I still have one of those 3270 cards somewhere at home.
At one time I bought a Sony 21" Trinitron. It has a serial port on the monitor so you could control it with the PC. It took up the desk. I bought the Media Vision ProGraphics 1280 card to drive it.
Very nice pictures, thanks! The Proteon and MV cards are both rare and historically significant (Proteon was a very influential network company, although 3Com has been more recognized because it still exists; the Media Vision card was designed by ex-Silicon Graphics engineers working at a startup called Pellucid (http://www.vcfed.org/forum/showthread.php?27697-MediaVision-Pro-Graphics-1280p), that later splintered into both NVidia and 3Dfx). Interesting about the MV card is that it has separate 1280x1024 and VGA pipelines: the Cirrus GD-5401 and Brooktree DAC are for VGA only (and can be completely disabled with the jumper!), and the TI-fabbed MV451 gate-array and three DAC chips are for high-resolution mode. The MV451 was originally designed by Pellucid for a MIPS NT workstation.
Thanks for creating this thread, nice photos. :-+
Have a Targa and 5250 cards tucked somewhere, need to dig it out.
Oops, here was the recognition software I wrote running on the AT with my custom hardware.
https://youtu.be/pnkUPFOw_Yo?t=178
My old BYAD CPM card running in my IBM PC.
https://youtu.be/SbYcjrezJHs
Whaaa? You didn't want to go with the CP/M-86 option? I can't figure out why...
i say, that's a rather gratuitous three dac shot there! :o
i think the first decent video card i bought was a Genoa Phantom based on the venerable Tseng Labs ET-4000 (what a classic that chipset was!), i am sure it was a VLB card.
As for 8 and 16 bit ISA cards, i checked i don't have a single one now!
I remember them well, along with Trident. I think the most memorable aspect of old computers (and my childhood) is the good old fade-out of the "Energy Star" logo on boot.
(https://i.imgur.com/ipn72q6.gif)
Here are a few select specimens from my collection:
mmmm VLB
This is the card in my 486 (not my picture)
(https://image.prntscr.com/image/M4najR1eRVeqW3fnBf2c5w.png)
Beautiful card, works very well for the price. Mine is upgraded to 2MB, and in some respects outperforms my Mach64GX (in image quality mostly). It's a later VLB graphics card, almost everything on one chip.
mmmm VLB
I'm in two minds about VLB (VESA Local Bus).
Personally, I never bothered, for two reasons. Firstly, it put quite a bit of mechanical stress on motherboards if you were inserting them inside a case, even with all the stand-offs fitted. These days, I'd be *very* wary about shoving one of these cards into a slot on old boards, you'll be sure to fracture a solder joint or two.
Secondly, you wouldn't think of using VLB on anything other than a 486 machine (as long as it had a front-side bus of more than 33MHz). VLB ran at whatever speed the FSB of the CPU was, while PCI initially came in at 33 MHz. Also, conflicts between VLB cards and other I/O cards weren't uncommon.
That being said if all you had was VLB (no PCI) and your 486 processor was decent, yes it had its advantages but bigger was not always better.
Actually, I have found the force needed to insert them on my board isn't all too much. Connection issues have also never really been an issue for me.
In terms of weight, they are still WAY lighter than modern cards, and I have no doubts about VLB's ability to hold them in right.
As for FSB, my 486 has a 40mhz FSB, so it runs faster than PCI.
Too many memories... I might have one oddball or another, but most went to the trash over the years. The most unique I used to use was a four channel Caller ID ISA card we designed in early 90's; a beast with four 8051's and four hybrids for POTS interface and all discrete logic ('LS373s). I wish I had a picture...
mmmm VLB
You are too kind... ;D With the mechanical tolerances of the generic desktop cases of the time, VLB put a lot of stress in most of the PCs I assembled at the time. I recall when folks reported the mouse leaving marks on the screen due to flaky contacts on the bus.
Certainly, but IIRC VLB came before PCI was mainstream on the home PC. It was the only alternative to differentiate yourself from the ISA video boards and the ultra-performing ATI All-In-Wonder ISA cards - most 486DX2/66MHz greatly benefited from it.
I have a couple of high end professional PCI video cards somewhere, late 90s to very early 2000's I think. Much newer than most of the stuff posted here but still old and somewhat exotic. I should dig them out and take some pictures.
indeed... VLB was a cheap, quick, short term stop-gap, so much was getting crippled by the 16 bit isa bus it was well needed but flawed
I had a Diamond VLB card in an old 486 motherboard. The internet, everything is there in a quick search:
http://www.motherboards.org/files/manuals/47/486vs8a.pdf (http://www.motherboards.org/files/manuals/47/486vs8a.pdf)
Back in those days I kept notes for each PC and how they were setup. Guessing most of you did the same thing. I have attached my notes for those interested. I wrote some assembler code back then to adjust the Cyrix's registers to try and improve it's performance.
I got an old Boca research Bocaram card, which was an early memory expansion board, though it was in a 16 bit ISA card. Also somewhere is a hard drive cache card, which promised a faster read and write performance on IDE drives.
Here is an old EPROM programmer... I wonder if I can still find the software.
I've still got an old half slot ISA GPIB card (National Instruments) that has been in most of my older PCs. I think it is 1980s vintage. I haven't used it for many years but it probably still works.
The only other 'interesting' card I've got is from about 1997 and that's an old Voodoo2 12Mb graphics card. Still in the box as new (with all the paperwork) as I only used it for a few months before upgrading. I played GLQuake with it a few times and then upgraded. I've got a few old ISA 56k modem cards and also an ancient ISA serial port card in the loft somewhere but that's about it.
http://matthieu.benoit.free.fr/Circuit_Cellar_serial_programmer.htm (http://matthieu.benoit.free.fr/Circuit_Cellar_serial_programmer.htm)
This is an Intel brand expansion board for the IBM XT. You would gain an extra printer, serial port, real time clock and more memory than you could ever use. Back then mostly I remember those Six Packs and Six Pack Plus cards with the PCs. Note the Mitsubishi DRAM.
This is one of my first home Ethernet boards used in the AT. This is a 3Com Etherlink 16. There was some software that 3Com had with the card to do error reporting. I actually had two of these cards stuffed into a PC with a lot of copper foil that went into a chamber to test some device.
Ugh, those damn RTC cards... I always had trouble making the system read the time at startup and many had to be tested before a magical combination was able to make them work. Obviously that my experience was with "clone" XT systems, which could be anything but standard.
It's been so long ago, I am not sure. Things I remember are Wordstar having an error that there was not enough memory when you went above 480K or something and using Debug to hack their software to find they had used a wrong compare. The more painful problems like this stuck with me for some reason. Or how painfully slow the PC booted with 640K. It was worse than watching the released version of the 121GW autorange! :-DD At least with the PC you could change the DIP switches to tell it there was only 64K to get it to boot then overwrite the memory size. An you needed the PC to boot fast because your Visi Schedule software would crash after each new task was added. :-DD That said, I had used the IBM PCs to run some test equipment and had them in service for over a decade.
I saw a lot of those AST Six Pak Plus cards, I liked those, they always seemed to work well. I'm pretty sure there's one in the XT I still have.
I don't member having any problems with the Six Pack hardware as well in those old cards. $240 back then for one with 64K installed.
https://books.google.com/books?id=hoPbDSDNLTQC&pg=PA43&lpg=PA43&dq=six+pak+expansion+card+ast&source=bl&ots=Kfhgnb2wzM&sig=1jbj3ye8V6yhwSyWrRaKADaf8sk&hl=en&sa=X&ved=0ahUKEwj83_DZmp_ZAhUkmeAKHcV8DgsQ6AEIOzAD#v=onepage&q=six%20pak%20expansion%20card%20ast&f=false
I had an MF384 for the 8-bit slot as well. What was nice about this card is they provided the schematics for it. I may still have the documentation for that one around.
You had to go there, hadn't you? :-DD
In my XT days the best ones used NEC V20s at 10MHz with 1024kB of memory but with the existing DOS 3.2 or 3.3 we could rarely use the extended memory for anything other than a RAM disk - people that insisted to run Sidekick as a TSR and wanted to do anything else was an exercise in frustration. On our 286s we could do a bit better only when the newfangled HIMEM.SYS of DOS 5 became available (but we all had to be burned by 4.0 first). Managing all these TSRs to get a couple of more kB was really an art, but totally worth it when Wordstar, Chiwriter, Autocad, Orcad or Corel Ventura could run without screaming at you. There was another utility that promised to put all *.OVL files to the extended area but it never worked for us.
I've never had to do such shennanigans, thankfully. However, it was really interesting when you got the DIP switches wrong and your card ended up at the same I/O address of the video or the keyboard controller, for example. :P
In my AT, there is a card that is made by Everex (SP?) that could do both extended or expanded modes. I had some software from Pharlap (SP?) that allowed fairly easy access to the memory using bank switching from what I remember. When I tried to make the video, I ran into a problem where some of my software was using that memory. The RAM disks were nice for compiling and setting up general temporary areas. I think the first C compiler we used was from C-Systems in CA. It would run on a PC with DOS 2 and two floppies. I was also using Quarterdeck memory manager with its multi-DOS window. So my code would look something like,
.286
CSEG SEGMENT PARA PUBLIC 'CODE'
ASSUME CS:CSEG
ORG 100H
START: JMP MAIN
QEMM200 DB 'EMMXXXX0',0F0H ;QUARTERDECK MEMORY MANAGER 2.0
QEMM702 DB 'EMMXXXX0',03FH ;QUARTERDECK MEMORY MANAGER 7.02
QEMM704 DB 'EMMXXXX0',043H ;QUARTERDECK MEMORY MANAGER 7.04
;EMM386N DB '$MMXXXX0',0CCH ;STANDARD DOS MEMORY MANAGER NOEMS
EMM386N DB 'EMMXXXX0',0ECH ;STANDARD DOS MEMORY MANAGER NOEMS
;EMM386R DB 'EMMXXXX0',0CCH ; " " " " RAM
EMM386R DB 'EMMXXXX0',0ECH ; " " " " RAM
and I would figure out what hardware/software I was running. Nightmare but if you needed the memory, it got you over that 640K limit.
I never had any of the NEC parts. I did have an accelerator card that took the AT'c clock from 6MHz to I think maybe 8.
I still have my old DOS Orcad. The last time I used that, I had hacked out a driver to allow it to use that Diamond graphics card. I uploaded the driver onto their BBS and they deleted it. They had that Gendrive thing that allowed 800X600 res. The mouse took up your whole screen and it was impressive!
For you VLB fans, this was the disk controller I was using in that PC, made by Promise Technologies. You can see from the previous sheet its a DC4030VL-2. At the time had 8Meg of DRAM installed for the cache.
And one last one that I had dug out. Let's see if anyone here knows what this card is. It may be fun to make a video showing it in operation. At the time, this card almost seemed like magic. :-DD
http://www.minuszerodegrees.net/manuals/Perstor/Perstor%20PS180-16F%20-%20Advertisement.pdf (http://www.minuszerodegrees.net/manuals/Perstor/Perstor%20PS180-16F%20-%20Advertisement.pdf)
After seeing the connectors and not looking at helius' response, I knew it was a MFM controller. I had a similar one in our first XT, a 30MB Seagate ST238.
It's a ST412 controller that uses "ERLL" to double the label capacity of MFM drives. Kind of neat, I didn't know that existed until now.
My first MSDOS machine, I originally bought as a dual floppy model. After using it about a year liek that, I knew I needed a hard disk. But looking at my stack of floppies, I figured that common 20MB was too small - so I got the 32MB one which was an RLL drive. A bunch of years later, I was still using this machine (it was 8MHz to begin with, with a switch to flip back to 4.77MHz for compatibility), upgraded with a NEC V20 and also a 8087. I found another of the exact same Seagate RLL drive in the back room at work, condition unknown. I took it home and it initially worked but soon failed. I used Gibson SpinRite to do it's thing, which was a low level format but also more - after two passes, the drive again worked and was reliable for at least 3 more years that I had the machine.
I know I had a RTC in it, I forget how that was added - no need for a 6-Pack type of card since the system had memory slots on board for a full 640K and also had 2 serial and 1 parallel port built in. I'm trying to remember how I hacked the second hard drive in as well, since I kept the dual floppies and there was only one more bay for a 5 1/4" drive under the two floppies. That was probably the most solid and reliable computer I've had since the dawn of the DOS age. It even survived being kicked into a wall - while the system was on, with the hard drive.
Joe!! DUDE!!
I may need your help! I have been waiting to find someone else with a Perstor!
I have one that quit working properly after I lent it to a friend many, many years ago. I need to dig it up and get you to probe a few things for me on your good one so I can figure out what the heck is wrong with mine. :)
PS-180-16FN, if I recall correctly... I can't recall what BIOS is on it right now, but it was sent back to Perstor for an upgrade very early in it's life.
The Perstors don't quite double the capacity. It was 31 sectors per track instead of 17 for MFM or 26 for RLL. I used mine for years on a pair of Miniscribe 3650 drives in the BBS machine until the media and the positioner finally started to give out. The 3650/3675 were still stepper-motor drives. I couldn't afford voice-coil-actuated drives back in those days. :)
Joe!! DUDE!!
Shouldn't be a problem if you know what you want to have looked at. From what I remember, when I bought the board it had a problem that they had corrected and I had to return it for an upgrade, similar to what people are seeing with the 121GW. So back it goes and I get a whole new card. Plug it in and it does not work at all. Back on the phone with their tech support. As I started to look at the board, I realized they had left one of the ICs out. Sure enough, another problem and the second one was returned. Third time was a charm.
Now I am wondering what is in the old AT as I thought it had this with the MEMO-4000 boards. Anyway, here is the Everx memory card that supports both memory modes in hardware.
Quite the quality control, Joe... Gives that warm feeling of reassurance...
(Wait! You almost forgot the 8088 on this PC. Quick! Go to the warehouse and grab one from the bin. No, you can pick one with your bare hands - I don't believe in this ESD folly)
It was one of the 40-pin parts they had left off. That's going way back.
Eh, that chip's not important. Besides, we just reduced the power consumption and cut BOM costs. :-DD
--Randy
nice! I was very curious what the Media Vision cards looked like back in the day...
if I could do so, I'd bring back my scanner to my parents' place to scan images of the cards I have... not as high end - but I do have a Diamond Edge 3D (2000? 3000?) that uses the nVidia nv1. I remember it being billed as the first chip that can really draw curves with little processing power, akin to vectors I think...
I think I have that same programmer, and probably have the software for it, too. I'll look around if you'd like.
Ahhh memories. Used to make heaps of multi-channel serial / 232-485-fiber-etc cards. EPLDs / FPGAs were new and awesome.
Even blew ~$20,000 on a Texas Instruments TMS34010 video SDK / full hardware development kit and made a VGA card with a whopping 256K
video memory !!Sadly, a few weeks after I finished it, and was tweaking specs, damn Taiwanese brought them out. Bastids :-)
Up till then, we mostly only had CGA, EGA, Mono hires. Gave it all away a few years ago, at a swap meet.
Sure were wild days
I was one of the founders of STB Systems. We made a butt-load of Apple and IBM PC add-in cards. They were sold under our own name and OEMed to numerous PC manufacturers (IBM, ATT, Dell, Gateway, NCR, Unisys, etc).
Our president bough one of the first IBM PCs ever sold. He bought it at a Sears computer store. One week later we were shipping memory expansion cards (it helps when your president was also a sales rep for a PCB house and Mitsubishi ICs). At the time 64 KB of DRAM was over $200 and our first card went to 192 KB. Imagine... you could have a computer with a whopping 256 KB of memory!
I still have an IBM PC/AT with a two digit serial number (or is it three digit). Picked it up from Computerland 1 second after they were allowed to sell them...
I left Computer Automation to start STB. AST Research was also started by ex-Computer Automation engineers.
Pretty cool story, texaspyro! I surely remember STB Systems.
Also, quite impressive to have a genuine AT 80286 - did you fit a math coprocessor? That was an object of desire when AutoCAD 9 required one but we could not afford the ~$500 and had to get by with a slow software emulator.
At the time, math coprocessors were available from even more manufacturers than CPUs. Cyrix got its start making x87 coprocessors, and they were also available from Intel, AMD, IIT, Texas Instruments, Weitek, ULSI, Harris, and Xtend.
Also NEC (?) had a CMOS math chip for the 8088. I put one in my Toshiba T1000 laptop (4.77 MHz 80C88). The T1000 has the 768 KB memory expansion board which increases the RAM to 640K. The rest of the memory is used as a RAM disk. The T1000 is still ticking. I just rebuilt the battery pack a couple of month ago. I mainly use it as a terminal to Data I/O Unisite and 3980 device programmers
And yes, the PC/AT had a math chip and a 16 MHz crystal upgrade. It has a 20 MB Rodime hard drive which now sounds rather iffy.
I've always liked the IBM ATs. A few years ago somebody found a stash of NOS ATs still sealed in the box, I was really tempted to buy one but couldn't justify paying a few hundred bucks for something I don't need.
In my country (Brasil) the coprocessors were not readily available; Cyrix started to flood the market there only when their i387 was mainstream.
The PC-XTs in Brasil were mostly NEC V20s; much faster at 10.368MHz (IIRC) when compared to the regular 4.77MHz. Our 286, however, was a full blown 16MHz and the motherboard had SIPP memory interfaces.
I swapped my 8088 with a v20 in my system - it was already an 8MHz 8088 so it was faster even without the NEC CPU, but the NEC one was even faster. I don;t recall (or at least it wasn't as readily available) NEC math coprocessor, I had an ordinary Intel 8087.
Digging in a box of old chips (in anti-stat foam), I somehow still have the v20. I don;t think I would have bought 2 of them, and I last used the machine in the mid-90's when I donated it to the model railroad club I belonged to, complete with a couple of programs I wrote to keep track of membership and also manage the small store we ran. Can't imagine I would have swapped the CPU back, but obviously I did. Unless I came across a second v20 later on - I put the v20 and the 8087 in it when I was still in college, probably in '87.
I do remember STB, and particularly AST - one of the companies I worked for, we commonly sold AST servers.
Yep that be my mystry card =-)
Odd ball board. Emulex DCP-286. We used them for high speed async and sync market data feeds in the 80s and 90s. In the late 1990s, everything switched to udp and tcp.
Cheers,
Rich
(https://uploads.tapatalk-cdn.com/20181006/fd18dbb5214182b771b8e6ef454aff94.jpg)
Sent from my SM-T810 using Tapatalk
