Author Topic: Pico Style PC PSU modules for older AT motherboards  (Read 1755 times)
Online dexters_lab
    • DextersLab2013
« on: July 18, 2018, 01:52:04 pm »
Those ultra small switching 'Pico' ATX power supply modules have been around for a long time now but i was wondering if someone makes one for the older AT style power sockets that have the -5v and -12v rails used on the older motherboards?
i have a small 386 board here that i am going to try and mount into a custom case but an original AT PSU would nearly double the volume of the box needed
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams
https://www.youtube.com/user/DextersLab2013
http://dexterslab2013.blogspot.co.uk/
Offline mariush
Re: Pico Style PC PSU modules for older AT motherboards
« Reply #1 on: July 18, 2018, 05:13:42 pm »
You can easily make the -5v and -12v rails with a couple of MC34063 or MC33063 switching regulators. Plenty of example circuits and component calculators out there. Or you can just go on ebay and get a ready made board.  If you need small, I would get a STX power supply and add a tiny circuit board inside it to add the two voltages....  or actually just the -5v as the -12v should still be around.
I would advise against using picoATX style power supplies because typically they're only able to output something like 4-5A on 3.3v and 5v rails, or something fairly small, and those old motherboards usually use 5v in a significant amount (to power the CPU and chipset and maybe even ram)
Online dexters_lab
    • DextersLab2013
« Reply #2 on: July 19, 2018, 09:22:24 am »
a STX power supply would be overkill and no smaller than the regular AT supply i already have
indeed, which is why i was asking for a AT specific one
TBH i might have a play around with powering it from my bench PSU and take some measurements, it's all going to be on the 5v and other than the RS232 ports i can't see what else would use the negative rails
Offline rdl
« Reply #3 on: July 19, 2018, 03:16:09 pm »
Mini-ITX (or Flex-ITX) are a slightly smaller form factor if you end up going in that direction.
It's too bad an off the shelf solution isn't available. I have an old 486 and I'd love to have a modern power supply for it. That's the only part making noise now the the HDD has been replaced with CF.
Offline Ampera
    • Ampera's Forums
« Reply #4 on: July 19, 2018, 06:14:56 pm »
There ARE modern AT supplies being made, albeit in the same AT/ATX PSU form factor they always have (not much in terms of mounting changed with that X tbh). These are done by companies like Athena Power, which is the brand of my 486's supply, and has lasted pretty well for some years. StarTech also makes a modern AT supply, according to Newegg.
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007657%20600014008
If you can at all fit a full sized supply into the case, and want an AT supply, these might be options.
C/C++/Java Programmer, Legacy hardware enthusiast, madman.
If it's broken, I probably did it.
EEVBlog IRC: irc.austnet.irc #eevblog
Offline Halcyon
  • Moderator
« Reply #5 on: July 20, 2018, 09:45:55 am »
Or you could also use an ATX to AT adapter cable which allow you to connect a modern ATX power supply to an AT board. There are a stack on ebay, Amazon etc...
I use these myself and they work perfectly.
The following users thanked this post: elecdonia
Offline rdl
« Reply #6 on: July 20, 2018, 11:38:19 am »
Apparently the -5v was part of the spec for ISA expansion slots only and not used by the motherboard. So unless my sound card needs the -5v I would be okay with the adapter.
Online dexters_lab
    • DextersLab2013
« Reply #7 on: July 24, 2018, 10:53:09 am »
thanks everyone, those ATX cable adaptors look like a good idea and i had forgotten about the ATX Flex PSUs, i used one a while ago when i replaced the PSU in my old Atari TT so i am not sure why i didn't think of it. In this case it's probably a good option given i also need to power the hard and floppy disk drives.
i've not looked at the actual 5v power consumption of this 386 but the entire system (including floppy & hdd) only draws 33 watts right off the mains. It also seems that the -5v is not being used anywhere, the i/o card does use the -12v though, presumably for the RS232 serial ports.
Offline tssva
« Reply #8 on: August 18, 2018, 07:59:04 pm »
I know I'm a little late to this party but if later you find you do have a need for the -5v, ATX to AT cables with the -5v are available on eBay. PhilsComputerLab did a review of one on his YouTube channel, https://youtu.be/8QXmxdiNWIs
Links to the eBay seller for the adapter he tested is included in the notes for the video.
Sent from my PH-1 using Tapatalk
Online dexters_lab
    • DextersLab2013
« Reply #9 on: August 21, 2018, 08:34:06 am »
i went for a hunt in my parts bin and actually found i had a small FSP branded atx power supply that has the -12 and the -5v looks like it might be a mini-itx size, so all i need is the AT/ATX adaptor cable.
always pays to check your parts bins before buying new stuff!
