Author Topic: Pictures of Vintage ICs  (Read 3960 times)
Offline joeqsmith
« on: February 23, 2018, 02:52:00 am »
Hunting for some parts and came across this old gem.  This started out as a discrete circuit built.  Then onto a full custom IC.  The first pass was about 6 or so ICs like this, put on some perf board and wired.   Eventually, it became one IC.  The final part was fairly common as you would expect.  To save cost, you can see how we are sharing.
Somewhere I have the final part stuck in a plastic try.  The person who laid it out had an interesting logo.
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Offline dexters_lab
    • DextersLab2013
Re: Pictures of Vintage ICs
« Reply #1 on: February 25, 2018, 10:18:38 am »
that's quite cool! So you shared space on a wafer? What was the IC for?
i started a gold-ceramic collection a while back, it's mostly 80s/90s vintage but there is a 1975 dated intel c8702a eprom in there
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams
https://www.youtube.com/user/DextersLab2013
http://dexterslab2013.blogspot.co.uk/
Offline Ampera
    • Ampera's Forums
« Reply #2 on: February 25, 2018, 10:43:52 am »
Gotta give a LOT of love for the gold topped 68ks and the Pentium Pro. Purple and gold is so much more fun to look at than just some black resin.
This isn't mine, though that would be cool. This is a KA820 CPU module board for a VAX 8200 or 8300. The interesting thing I've noticed about it, is the chip on the bottom right. It appears to be a dual width DIP chip. It's the coolest and most insane thing I've ever seen.
C/C++/Java Programmer, Legacy hardware enthusiast, madman.
If it's broken, I probably did it.
EEVBlog IRC: irc.austnet.irc #eevblog
Offline dexters_lab
    • DextersLab2013
« Reply #3 on: February 25, 2018, 10:52:35 am »
yea, not seen anything like that before!
Online Gyro
« Reply #4 on: February 25, 2018, 11:33:41 am »
DEC were big on that sort of thing, the first time they did it was on the F11 CPU and again on the J11 (PDP11/53,73 etc) - that one was large and pretty.  :)
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline Alex Eisenhut
  • If you can buy it for 4$ on eBay, why design it?*
*Except AC/DC adapters on eBay. Avoid them all!
« Reply #6 on: February 25, 2018, 02:35:10 pm »
Oooh and I have one of these (well, a 12C508)
https://pbs.twimg.com/media/C72Zb6rVQAErcxi.jpg
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: February 25, 2018, 03:08:42 pm »
I don't have much of old ICs in my collection; these are maybe the most unusual to me.
I didn't know RCA was making SRAM as late as '88.  Then again, I never saw RCA making semiconductors in my lifetime -- they divested that a long time ago, indeed.
The PICs I don't think are all that remarkable actually, but just to tease Alex; mine's bigger. :P
The COP8 is a pretty basic, ordinary, but pretty obscure, microcontroller.  Amazingly enough, it's still supported to this day!  Example: https://www.digikey.com/product-detail/en/texas-instruments/COP8SGE728M8-NOPB/COP8SGE728M8-NOPB-ND/366487  Not cheap by any means, but I'm guessing it's used in a lot of military stuff or something, hence the need to keep it alive?  :horse:
I have a couple chips older than 1980, I think?  Forget what, I didn't run across them when I was digging these out.  I don't recall having any white ceramic parts.  The RCA package is different, much more gray and silvery colored (I wonder if the lid is just soldered on -- and I wonder if it's 90 or 100% Pb instead of AuSn?).  To me, it seems somewhat more remarkable that a lot of these chips are as new as they are -- late 90s.  It seems so strange to see CERDIPs from that era.
Most of these older chips came from a junk box, that must've been left over from a design engineer long ago.  Seems to span 80s to early 00s, everything from ATmega to Z80, with a "golden age" centered on 90s embedded systems: lots of EPROMs, SRAMs, 8 and 12 bit DACs, and some PALs and early CPLDs.
Seven Transistor Labs, LLC
Online Gyro
« Reply #8 on: February 25, 2018, 03:41:33 pm »
If you want to see what the dies inside the ICs on that V-11 (Scorpio) chipset CPU board look like... http://simh.trailing-edge.com/semi/v11.html  :)
The Multi-chip module contains the five DC327 ROM/RAM chips needed to contain the full VAX instruction set microcode.
I think the final DEC (circular heatsink) chip, top left, is the VAX-BI bus controller.
« Last Edit: February 25, 2018, 03:46:57 pm by Gyro »
Chris
« Reply #9 on: February 25, 2018, 04:05:06 pm »
How about this one, hanging on my wall in a frame now.
crDSC01484 by SeanB_ZA, on Flickr
« Reply #10 on: February 25, 2018, 04:28:44 pm »
It's not about size, it's about cuteness:) Come on, a 8 pin ceramic DIP with a quartz window?
Offline tggzzz
« Reply #11 on: February 25, 2018, 06:15:55 pm »
Burr Brown used to make thick film hybrids that were sufficiently pretty that they made a calendar out of them.
See more at https://entertaininghacks.wordpress.com/2015/07/07/images-of-late-70s-burr-brown-thick-film-hybrid-ics/
The following users thanked this post: SeanB, Gyro
Online Gyro
« Reply #12 on: February 25, 2018, 07:21:49 pm »
I like the Silicon on Silicon one!  :)
« Last Edit: February 25, 2018, 07:24:49 pm by Gyro »
Chris
Offline joeqsmith
« Reply #13 on: February 25, 2018, 08:10:21 pm »
I used a few of the National COP parts because they were fairly low cost.  It took some getting used to the instruction set before I was efficient at it.
This was a coprocessor out of an old Z80 based machine.
Offline Ampera
    • Ampera's Forums
« Reply #14 on: February 25, 2018, 08:17:00 pm »
That's dang awesome. I've never seen a ceramic/gold DIP-8 package before.
The following users thanked this post: Conrad Larsen
Offline joeqsmith
« Reply #15 on: February 25, 2018, 08:18:04 pm »
The first microcontroller I used was the Motorola MC6801.   If you watch any of my videos where I transient test the meters, the newer generator was made on a wirewrap board using this same microcontroller  in my attempt to remember the better years gone by.  Let me just say, they were not so great.  Fitting all that code into a few K took some work and wire wrapping is no fun.   :-DD
We would use the MC68701 to develop with, then have masked parts produced.  None of this buggy code as you normally bought 10's of thousands off the mask.   :-DD  Later Hitachi came out with a CMOS version of it.  The top part is an OTP.
Offline joeqsmith
« Reply #16 on: February 25, 2018, 08:24:18 pm »
Dexter's lab has a BB part.  Here is an old ADC.
Offline joeqsmith
« Reply #17 on: February 25, 2018, 08:26:11 pm »
For the digital fans, here's some early Altera parts.
Offline dexters_lab
    • DextersLab2013
« Reply #18 on: February 27, 2018, 07:02:39 pm »
loads of that kind of thing around here! quantel must have bought them by the truckload  :-DD
Offline Richard Crowley
  • KE7GKP
« Reply #19 on: February 27, 2018, 07:14:13 pm »
At some intermediate step in the evolution of microcontrollers, we didn't have the technology to make non-volatile memory and the processor logic on the same chip. So kludgy things like this were used to combine the firmware storage on an EPROM which plugged into the CPU package.
Offline Kjelt
« Reply #20 on: February 27, 2018, 07:22:42 pm »
AFAIK these were also the first of a kind versions for a new microcontroller to be able to easily "reprogram" during debugging instead of erasing the processor you had a bunch op eproms which were much cheaper to have around.
I could repair a Philips laservision player from the begin of the 70s just because they had these piggyback chips  :)
Offline bsudbrink
« Reply #21 on: February 27, 2018, 07:36:09 pm »
I've used a number of vintage ICs in the Cyclops cameras that I have built.  There are pictures of them on my web site:
http://wsudbrink.dyndns.org:8080/cyclops/index.html
You can click for larger versions of most pictures and you can see the die of a Mostek MK4008P-9 (used as the image sensor) in some of the assembly pictures.  Pictures of other vintage ICs are in the "Collecting Parts" details page.
Offline Kjelt
« Reply #22 on: February 27, 2018, 07:44:19 pm »
Still got this little gem in its original alufoiled inside covered box, 24kB SRAM for the Tandy Model 200.
They only had 8kB chips in those days so they put three of them on a ceramic carrier and added a H138 address decoder  :)
Offline dexters_lab
    • DextersLab2013
« Reply #23 on: February 27, 2018, 08:52:04 pm »
those ceramic hybrid sram things seem to have been very popular, did the sram makers stop making them in pdip or something? :-//
Offline Kjelt
« Reply #24 on: February 27, 2018, 11:28:59 pm »
I am not exactly sure that I understand your question.
In any case the Tandy Model200 and 100 were the portable small computers of that day, lcd display, running on AA batteries for what I remember 12 hours or something like that, size did matter. So 8kB pdip srams would occupy too much space.
