^^ yep, yep. + sometimes wrapping bundles of 30 AWG wires with.... a piece of 30 AWG wire. But hot glue is great for only a few wires. OP get one of those CHEAP glue guns with the temp adjust dial. Yeah, it will take forever to heat up compared to an expensive super glue shooter, but you can leave it on all day without burning the glue or your fingers.
As for tidy, I find it is insane waste of time to cut the wire exactly to the right length. Then you have to flip the board around to solder the other connection, and you have to capture that loose end with tweezers. And then it will want to twist and turn the wrong way. So then you have to fiddle with the end to get it to point the right way, cuz you have no extra wire to manipulate. And then when you solder it, the insulation softens and where you are holding the end with the tweezers, it smooshes and exposes the wire.
I solder the first end, then lay the wire to the other connection, strip it there with one of those open-ended strippers and solder the other end. Only after both ends are soldered do I cut the wire. Nice and tidy. You might have to bend the wire a bit to get the right angles for the second joint, but you're bending it in the middle and you never need to hold the wire with tweezers, just your fingers, because you never need to hold it so close to the joint. For really short connections, reveal a long length of bare wire before you solder the first end, then strip a short section of Kynar and slide it down in place like a piece of macaroni on a string. (With a longer jumper, you have more room to strip it in the middle, plus the longer length of insulation has more room to compress as you push the wire stripper to break the insulation. Hence, why I leave a longer naked end of wire with the short jumpers.)
