Author Topic: Colecovision  (Read 710 times)
Offline WawavounTopic starter
  • Someday I'll get you, Red Baron !
Colecovision
« on: April 19, 2023, 06:24:53 pm »
Hi All !
I have found a Colecovision game console (FR model) in very good shape.
But there is no power supply and no Subd15 to SCART cable.
For the PSU I will use an old PC power supply with -5 V. The problem is the connector on the console side.
I found a 3d printer model for the plastic part but what can I use as metallic plugs ? The male parts on the console seems to be brass or copper pins with diameter 2.5 mm.
I have try plugs taken on a 5p1/4 floppy drive molex power supply but there are to small...
For the video I found two different wirings on the net and I am unsure about what to use.
Any help will be appreciated.
Regards.
Philippe
