Hello there !
I have rebuild the Microbox II 6809 based computer.
This computer has a rtc chip MC146818 keeping date, time and also some parameters. The rtc is backed up by a 3.6 V battery.
It seems that SOMETIMES rtc datas are corrupted at power down.
The computer wont restart.
By clearing the rtc (pin 22 to gnd) default values are restored at next boot and he restart well.
I have try two different chips (Motorola and Hitachi) with the same problem.
I put the scope on CE pin of the rtc set into one shot mode. At power down the scope trigger and I see several pulses.
The monitor has no code for doing something into the rtc at this moment so this is abnormal.
This CE signal is made by decoding E, S0, S1 coming from the 74LS783 SAM and A2, A3, A4 coming from the proc (via buffers).
This is working well because I can read and write easely into the rtc.
I have try 3 different power supplies with the same problem (one is linear serial with cut off button at the output so power down is immediate, nos discharging of capacitors etc...).
I will put the logic analyzer and try to understand how these pulses are generated.
I need some advices if this is a kown problem and if its the case what are usually the solutions.
Regards.
Philippe
