Author Topic: Tandy 1100fd, What LCD does it use?  (Read 857 times)
Online DiTBhoTopic starter
« on: April 17, 2024, 11:25:20 am »
made in 1989, I can't find any teardown that shows any precise information, like...
  • mechanical dimensions
  • what interface it uses at the signal level
it's only known that it's a grayscale CGA LCD  :-//
Offline EEVblog
Re: Tandy 1100fd, What LCD does it use?
« Reply #1 on: April 17, 2024, 12:30:45 pm »
I used to own one. I think I still have the technical reference manual somewhere in the bunker.
IIRC it was a twisted nematic hitachi chipset.
Offline coromonadalix
« Reply #2 on: April 17, 2024, 05:19:38 pm »
Display: LCD super-twisted nematic, green Chip Set MN5504 LCD CGA emulation     ???  from vintage computer
The 1100 FD has an 80 x 25, high-contrast liquid crystal display
with 640 x 200 resolution.  The fold-over display measures
approximately nine inches diagonally and closely resembles the
aspect ratio of conventional video monitors.
known  under :  Panasonic Business Partner 150  ???
« Reply #3 on: April 17, 2024, 05:36:10 pm »
found some info here.
if you find the time, can you open, and measure the STN LCD-panel size?
Offline EEVblog
« Reply #4 on: April 19, 2024, 12:11:08 am »
Sold it a long time ago. I think I still have the technical manual.
