Hi all,
Im looking for some advice as I am a bit out of my comfort zone in vintage computer design... or just computer design...
So I am looking at replacing a PCB i have that addresses a 16bit bus into 16x TSM4256 chips simultaneously with either 8 or 9 bit addresses.
I was wondering if it would be able to replace the 16 4256 chips with a single IS41C16256C or IS41C16257C
I think it should work, however I am not sure about the refresh cycle and nuances that i have missed.
I have attached a PDF of the original DMX96.2 card that I have reverse engineered and my take on the version with the ISS chip (DMX96SL) I believe addressing LCAS and UCAS at the same time with the same CAS signal is the correct thing to do...
Any advice is much appreciated!
All the best
Chris
