Author Topic: When Greaseweazle fails...  (Read 950 times)
Offline heliusTopic starter
« on: November 04, 2023, 12:45:24 am »
You can always read the magnetic signal using an oscilloscope, and analyze the analog signal using more advanced software means, even redrawing the peaks by hand if necessary.
It's a good post, although I think the bit about the signal strength increasing linearly with rotation speed is wrong. It increases with the square of rotation speed, doesn't it?
Offline Shonky
Online ebastler
Re: When Greaseweazle fails...
« Reply #2 on: November 04, 2023, 12:29:16 pm »
I don't think so. If B is a changing magnetic field and U the voltage induced in the read head's coil, U ~ dB/dt. And dB/dt should be proportional to the linear velocity of the disk track, and hence to the rotation speed?
Offline 50ShadesOfDirt
« Reply #3 on: November 04, 2023, 04:18:42 pm »
I did just order a greaseweazle, hoping to recover some floppies & such ... fascinating device from what little I've read.
I hope these guys are in the box with it ...
