Curious about "SPICE" -- does this mean you used a simulator before, or are you fluent in code? Which variant: command line based, GUI front end, LTSpice, Altium's, etc.? Might be worthwhile to be a little more specific on this and related items (e.g. I suppose that'd Altium Designer 22?). Doesn't hurt to be precise, at least when it's so few characters to add.
You do not state anywhere how well you did, i.e. what grades you got. Maybe it is not common to include these in your part of the world? Over here, it would make readers wonder whether you omit that information since your grades are poor. I would expect at least an average grade/score in the bottom "Education" section.
"Honors" implies better than average at least, but agreed there should probably be a quantifier (GPA?).
As for content, the project listing seems fine; maybe specify which classes they were labs of, where applicable (or
highlight projects that weren't!!). Be prepared to discuss things in detail -- for example, you say the oscillator came out with the wrong frequency, why? Keeping it to one page is fine at this stage, and the unbalanced two-column layout makes efficient use of space, seems good.
Ed: also to reiterate, I don't know US vs. AU differences either, so take this with a grain of salt of course.
