Author Topic: THE CAL SHOP INC. IS NOW OPEN FOR BUSINESS  (Read 7846 times)
Offline emtchris1231Topic starter
« on: November 05, 2015, 03:54:46 pm »
Introducing The Cal Shop Inc. open for business. Snuggled in upstate New York, we are here to fill the void for calibration and repair services. We are Vet owned and operated. With over 25 years in the calibration and repair field, we bring alot of experience to the playing field. We offer free quotes.
Busy schedules of companies in mind, we also offer fast turnaround on your equipment. Being ISO 17025:2005, Fully NIST Traceable, ANSI/NCSL Z540.3-2006 , TL9000, C-TPAT, and MILSTD-45662A, we bring alot of things to the table .Physical/dimensional, electronic and avionic, we do it all.
Repairing the world, one piece of equipment at a time.
Please feel free to contact us thru email ( sales@thecalshopinc.com)
or give us a call 518-254-7282
We are here to help.
Re: THE CAL SHOP INC. IS NOW OPEN FOR BUSINESS
« Reply #1 on: November 09, 2015, 02:35:03 pm »
555 East Main St #1, Cobleskill, NY 12043
www.thecalshopinc.com
(518)254-7282
Calibration and Repair
Physical   Dimensional   Electronic   Avionics
- Temperature
- Torque wrenches
- Aircraft weighing kits
- Pressure gauges
- Vacuum gauges
- Others   - Calipers
- Micrometers
- Crimp tools
- Length scales
- Others   - Multi-meters
- Oscilloscopes
- Generators
- Others
- Pitot Static Test Sets
- Ramp Test Sets ATC600s
- Nav401L
- Others
Facility QA Certifications
Fully NIST Traceable   TL9000
ANSI/NCSL Z540.3-2006 Compliant   C-TPAT
MILSTD-45662A   ISO 17025:2005 Accredited
Calibration Documentation and Services include:
Pre and Post Calibration Results   Onsite Calibration Services (location-dependent)
Certificate of Calibration   Calibration Notification Services
Individual Calibration Traceability
Other After-Market Services Include
Engineering Services   Test and De-bug (functional, ICT, flying probe, x-ray)
Repair & Refurbishment   Logistics and Fulfillment
Offline fivefish
« Reply #2 on: November 10, 2015, 05:37:48 pm »
Can you englighten us about what "calibration" is?
Do you just check the equipment (ex: Fluke multimeter) to see if it's within the tolerance spec for that model? And if it is, then it's considered "calibrated"?
or do you go in, open the equipment up, and adjust it so that a reference 5.000000 volts is read by said equipment as 5.000000 +/- .000001, then its considered "calibrated"?
Online nctnico
« Reply #3 on: November 10, 2015, 09:51:36 pm »
Adjustment is not calibration by definition. Calibration is checking if an instrument is within spec.
Offline fivefish
« Reply #4 on: November 11, 2015, 02:03:04 pm »
I was hoping the OP would reply as they're the ones offering this service.
On their website, it says:
Fluke   Various   Multimeter   $50.00
So what? I send them my Fluke, and they send it back to me with a note that says "Yes, it's calibrated" if the meter is within spec of manufacturers rating?
$50 for the assurance that "yes, it's calibrated" or is there more info that I'll receive?
And what if the meter fails spec of manufacturer?
I get a "No, it's not calibrated" for my $50? That's it?
Offline CatalinaWOW
« Reply #5 on: November 11, 2015, 06:15:28 pm »
Need the OPs answer for this, though he sounds good and legit.
I once sent 3 identical instruments to a calibration service.  Upon return and connected to the same source the three instruments literally read 0.5, 1.0 and 2.0.  (Units and instrument are not important).  Sent WTF message to calibration service.  Their response -"Tell us which one is right and we will make them all the same."
Anytime you try a new vendor in this area do the best you are able to check their work.  When you find good calibration services value them.  Let the world know.  And let the world know about the others.  The one in my story doesn't exist anymore so no naming is necessary.
Offline retrolefty
« Reply #6 on: November 11, 2015, 06:30:58 pm »
The word 'calibration' and what it means is a confusing term to many. At the oil refinery I worked for our instrument shop used words like 'validate' to mean to just measure, compare, and document the difference(s) between our shop reference(s) and any specific instrument under test. When we sent out a device for 3rd party validation, we would consider it just a validation of our reference device, not any repair or adjustment to attempt to bring the device into compliance with it's specification.
Most times we were just paying to keep a sticker current and up to date to comply with some internal or external rule or regulation. If one of our reference devices 'failed' it's validation we would generally just replace it with something new.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #7 on: June 27, 2016, 03:52:22 pm »
In my eyes calibration is the adjustement refering to a trusted instrument what we call a standart.
A calibration can pass to get the calibration tag / certificate,
or fail, to get the message it is not possible to calibrate the instrument bec. it needs at first a repair.
a trustful calibration lab have the acredition of one or more of the metrology institutes of the world, the standarts will be calibrated by them.
greetings
Martin
Offline ez24
  • L.D.A.
« Reply #8 on: June 27, 2016, 05:50:11 pm »
Not sure about this company.  Maybe there are too busy to answer any questions after 7 months.
I would say Cal Shop Maybe Open For Business
Offline bitseeker
« Reply #9 on: June 27, 2016, 09:29:08 pm »
This was a drive-by ad.
Offline ez24
  • L.D.A.
« Reply #10 on: June 28, 2016, 12:10:50 am »
Offline bitseeker
« Reply #11 on: June 28, 2016, 01:38:38 am »
 ::)  ^-^  ;D
