Author Topic: Talented PCB Designer Looking for First Jobs!  (Read 400 times)
Offline shanekent
« on: January 12, 2020, 06:22:19 pm »
Hello Everyone!
My name is Shane and I'm an Electrical Engineer in the Silicon Valley. I'm looking for some side work laying out boards of various complexity so I've started advertising on Fiverr.    I'm having some trouble launching my services and as such I've lowered my prices significantly to help boost some interest.
I've been working as an EE for a combined 3-years and during that time period I've personally designed over 40 unique PCBs from start to finish.   I have experience designing rigid, flex, and rigid-flex designs with the most complex stack-up being a 12-layer rigid section with an embedded 4-layer flex that utilizes buried and blind vias.
If you think my services would be of any use to you then please consider checking out my job posting here: https://www.fiverr.com/share/KepaNY
I appreciate your time!
-S
Offline OwO
  • Country: cn
  • RF Engineer @ OwOComm. Discord: スメグマ#2236
Re: Talented PCB Designer Looking for First Jobs!
« Reply #1 on: January 13, 2020, 03:27:46 am »
I would suggest maybe adding links or images to PCBs you have designed in the past that show off your ability, for example laying out DDR3 on a 4 layer board.
Discord: スメグマ#2236
Email: OwOwOwOwO123@outlook.com
GitHub: gabriel-tenma-white
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: January 13, 2020, 04:35:52 am »
CAD platform ?
The following users thanked this post: bgm370
Offline Berni
  • Country: si
« Reply #3 on: January 13, 2020, 06:23:48 am »
I don't think many people are looking for PCB designers on Fiverr in the first place.
When doing freelance you will typically end up working with repeat costumers the most, so it can be hard to start off when you know nobody but as the word slowly gets out and past costumers keep coming back with more work... it can quickly fill your schedule.
Also what most people find useful is complete electronics engineering solutions rather than just PCB design. If the costumer is not capable of doing the PCB design themselves they likely also are not capable of designing a schematic of the product they want to make, nor have the equipment or expertise to assemble it and test it afterwards.
As mentioned above what CAD software you use can be important. But if you are in silicon valley you should be able to find some technical company that needs a PCB designer.
Offline blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #4 on: January 13, 2020, 06:57:14 am »
Also, make sure your pricing strategy is correct. In your page, you said $157 (HKD 1224 on my computer) for a 4L+ board with up to 50 parts.
I can easily throw you a task with FPGA+ARM+DDR with all-in-one PMIC and a few passives, and there's no way you can get it done within $150.
Offline shanekent
« Reply #5 on: January 14, 2020, 05:24:31 am »
These are all great suggestions and comments, so thank you for that!
I'm going to have to spend some time to locate pictures of boards that I can actually share. Most all of my previous designs have been completed under strict NDAs so it makes sharing a little difficult...
I'm only familiar with the Altium platform and I'm currently running AD19 and AD20. Luckily their files are forward and backward compatible which allows me to work with clients that are still on older versions of Altium.
You're absolutely right about pricing strategy being important - there is no way that I would even remotely consider touching a project as dense as the one you mentioned for close to $150.   That being said, Fiverr allows for custom offers to be generated based on the complexity of a given order so that allows for quite a bit of flexibility.
I'm going to take these suggestions and comments seriously, so thank you very much for the time!
If anyone is interested in my services, then please consider reaching out via my Fiverr gig listed above or to me directly via some other fashion.
-S
Offline squagle
« Reply #6 on: Today at 07:28:26 pm »
I had shanekent build out two small PCBs for me to resolve some SPI transmission distance issues I was having.  Quick turnaround and good price.  Plan to use them again for additional boards.
