Author Topic: USB-C Power Supply PCB Design Needed  (Read 4646 times)
Offline james21180Topic starter
« on: December 10, 2019, 11:35:16 am »
I'm looking to have a USB-C Power Delivery Power Supply PCB designed.  This power supply would use a Cypress EZ-PD™ CCG3 or something similar for power negotiation.  The specs of the supply would be as follows:
Input Voltage:  12-24v
Output (USB-C): 5-20v (100 watt Max) Variable voltages (either auto negotiation or a button for manual voltage selection.
This is a good example, but I need to get 100 watts - https://www.coolgear.com/product/usb-car-charger-board-60w-high-power-pcb
Offline shanekent
    • Electron Shepherd LLC
Re: USB-C Power Supply PCB Design Needed
« Reply #1 on: January 12, 2020, 08:30:53 pm »
Hi James, do you still need support with this design?
anything worth doing is worth doing right
www.electron-shepherd.com
