General => Work Wanted => Topic started by: james21180 on December 10, 2019, 11:35:16 am
I'm looking to have a USB-C Power Delivery Power Supply PCB designed. This power supply would use a Cypress EZ-PD™ CCG3 or something similar for power negotiation. The specs of the supply would be as follows:
Input Voltage: 12-24v
Output (USB-C): 5-20v (100 watt Max) Variable voltages (either auto negotiation or a button for manual voltage selection.
This is a good example, but I need to get 100 watts - https://www.coolgear.com/product/usb-car-charger-board-60w-high-power-pcb (https://www.coolgear.com/product/usb-car-charger-board-60w-high-power-pcb)
Hi James, do you still need support with this design?
