Since I cannot (yet) build an AC ramp up and ramp-down circuit I will try to use an in series
thermistor to protect the bulb from inrush current. Its a bit tricky to size the correct thermistor,
so maybe you can verify my choice.
A typical OSRAM 60 Watt incandescent lamp has a 61 Ohms resistance when cold and 808 Ohms
when hot, with 220V AC.
So the inrush current will be 3.6A which is 13 times more than its working current of 272mA.
The thermistor that I chose has the following specifications:
Resistance @ 25 degC = 400R
Resistance @ Max Current = 9.8R
Max Steady State Current = 200mA
Thermal Time Constant = 32 sec
Dissipation Factor = 11mW/degC
I will use the thermistor in series with the bulb and these are the two states of the circuit:
Thermistor CircuitSo the inrush current during the cold state will be 477mA and the working current when the
thermistor is hot will be 269mA. There will be no stress on the bulb but the initial current
will be 1.7 times more than the thermistor max value. Do you know if the thermistor will be able
to handle that? It will be for a short time. I don't want to save the bulb and stress the thermistor...
Do you think that the above thermistor choice is correct?
How can you calculate the time it takes for the bulb to light up fully?
There is a way to short the thermistor when it gets hot with a latching relay but I not sure
yet how to do it.
Any help is appreciated.
Thank you!
