Author Topic: Driving BBD from MCU  (Read 1367 times)
Offline ErnstHotTopic starter
« on: January 21, 2015, 10:54:48 am »
I need to drive the clock inputs on a MN3207 bucket brigade device from an MCU. The clock voltage needs to be 14/15 of the MN3207's Vcc and the input capacitance is relatively high, so I need to provide enough current to overcome that at high frequencies.
This circuit(PDF) uses a CD4049 to buffer the clock signals, but that needs a higher input signal voltage than an MCU can provide on it's own and so I'm wondering if there's any reason I can't use a transistor to drive the MN3207 directly from the MCU? What would such a circuit look like, other than obviously the transistor? Is there a simple and clever way to get the inverse clock as well without using an extra pin on the MCU?
(All this is subject to my possibly flawed understanding)
Offline HalfSpace
Re: Driving BBD from MCU
« Reply #1 on: January 23, 2015, 08:51:25 pm »
Hi ErnstHot,
You could drive the MN3207 with a mosfet driver IC like the TC4428A or a lower power one. They are 3.3V compatible inputs, inverting and non-inverting outputs and can output up to 18V at high capacitive loads.
HalfSpace  :)
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever."
