Author Topic: Inside the Tesla Roadster power inverter for 200kW motor  (Read 27651 times)
Offline tom66Topic starter
« on: February 26, 2014, 11:53:15 am »
Engineering pr0nography with thanks to "Marco2228" of Tesla Motors Club -- here's what's inside the power pack for a 300hp/200kW performance electric sportscar. He's the first to attempt a repair of such a unit after damage occurred (I doubt anyone would be tearing down a working one...!)
I'm quite surprised that they used discrete IGBTs rather than dedicated hybrid modules, but it looks to be a cost decision.
Charging input / contactors (240V @ 70A)
http://www.teslamotorsclub.com/attachment.php?attachmentid=44149&d=1393359626
Two phases ("Megapole logic") of inverter drive - identical to each other
http://www.teslamotorsclub.com/attachment.php?attachmentid=44154&d=1393359673
High performance DSP for traction control, safety interlocks, ADC/DAC and motor drive plus fan controller (far right)
http://www.teslamotorsclub.com/attachment.php?attachmentid=44151&d=1393359647
One IGBT "module" (a "Megapole") - 110kW IGBT block, 350VDC @ 650A peak (~310Arms)
http://www.teslamotorsclub.com/attachment.php?attachmentid=44150&d=1393359635
Thread:
http://www.teslamotorsclub.com/showthread.php/20709-34-Salvage-auction/page11
« Last Edit: February 26, 2014, 11:56:02 am by tom66 »
Offline Psi
Re: Inside the Tesla Roadster power inverter for 200kW motor
« Reply #1 on: February 26, 2014, 12:03:37 pm »
Aw doesn't seem to mention what IGBT part they're using.
That's pretty awesome though,  28 IGBT's per phase.
Some serious power switching there.
« Last Edit: February 26, 2014, 12:09:43 pm by Psi »
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #2 on: February 26, 2014, 12:07:50 pm »
Very interesting find!
28 TO-247 IGBTs per phase is indeed an interesting design choice. Considering the thing can put out 200kW at least for some time it's very compact.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline dr.diesel
« Reply #3 on: February 26, 2014, 12:12:59 pm »
That is pretty awesome.  Corp666 was right, pretty soon Summit Racing will be selling Souped-Up boards with 96 IGBT's/phase.
Wonder when the local track's Supercharger will be installed?
Online NiHaoMike
    • Facebook Page
« Reply #4 on: February 26, 2014, 04:28:55 pm »
I was expecting a large FPGA or two to handle the low level modulation and control. (There might be, just not pictured.) Hard to tell for sure, but it might also be a multi level inverter with all those transistors and capacitors per phase.
Meanwhile, Toyota directly mounts IGBTs dies into modules and uses custom ASICs, but they're also dealing with much higher volumes.
Offline free_electron
    • SiliconValleyGarage
« Reply #5 on: February 26, 2014, 04:59:41 pm »
Model S uses Ixys IGBT's. there is a reason for not using modules : individual monitoring and control. These guys are not stupid ...
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: February 26, 2014, 07:09:31 pm »
I'm going to do that myself one of these days, that is, make an array with the transistors on the backside so the heatsink is clamped by screws through the board.
Discrete transistors are so damn cheap, it almost doesn't make sense to use modules.  The main difference is convenience and serviceability, I think.  For sure, if you're doing something at high frequencies, there is no module in existence that can go fast -- think the highest I've seen is a Microsemi/APT MOSFET half-bridge only rated for 200kHz resonant (compare to a fast IGBT bridge that wheezes out around 50kHz, or discrete MOSFETs that'll do MHz these days).  It appears they made no effort whatsoever to reduce lead inductance, which is shameful.
Hmm, also curious what isolation they use.  All those heatsink pads are at different potentials (B+ and AC, respectively).  Wonder if it's hardcoat anodized...
« Last Edit: February 26, 2014, 07:12:04 pm by T3sl4co1l »
Seven Transistor Labs, LLC
Online NiHaoMike
    • Facebook Page
« Reply #7 on: February 26, 2014, 07:51:03 pm »
I'm surprised just how many modern digital audio amplifiers are using through hole modules when surface mount discrete MOSFETs and chips are superior at high switching frequencies. Of course, they deal with small amounts of power as far as power electronics go.
« Reply #8 on: February 26, 2014, 10:11:04 pm »
if the transistor is built on fully depleted silicon no insulator is required. That thermal slug has no electric connection
Offline Psi
« Reply #9 on: February 26, 2014, 10:30:16 pm »
Building my own electric car and making the speed control unit is something i would find quite fun.
Probably wouldn't do regen braking to keep things simple but testing out different control systems would be interesting.
Not sure about the safety aspect though, I wouldn't want some code error to cause fullspeed lockup while driving with other cars nearby.
In NZ all electrics cars are required to have a control for the driver that mechanically disconnects the batteries so E-stop would always be possible in an emergency.
Multi kW speed controller design is probably a lot more complex than i think it is but it still sounds like fun.
DC pwm and a brushed motor would be the easiest
« Reply #10 on: February 26, 2014, 11:00:51 pm »
For safety interlock, the simplest system would be two identical processors cross-checking each other, with each having an independent accelerator input from the pedal. The gate drive signals each generate could be AND-ed  for the final drive signals, and an XOR-circuit could be generating an interrupt indicating a processor exception which would immediately result in the battery contactors opening if the disagreement time exceeds some pre-set limit. In addition, applying the physical brake hard-down should command the inverter to stop delivering power.
In the Roadster PEM it looks like the Xilinx FPGA/CPLD near the phase connector might be doing some cross checking. It's also possible the checks are done outside the PEM, maybe in the vehicle management module, and that the PEM is fairly "dumb" - just taking a torque input command and producing an output. But the TI DSP seems like a bit much if it's just doing that. There's definitely some traction control management going on there as there's some tech docs talking about how the original "analog PEM" (presumably full of op-amps with no DSP...)  without traction control being terrible at handling.
« Last Edit: February 26, 2014, 11:04:43 pm by tom66 »
Offline T3sl4co1l
« Reply #11 on: February 26, 2014, 11:01:46 pm »
I don't think a device like that has ever existed...?  It certainly wouldn't work with a minority carrier device.
All modern switching MOSFETs and IGBTs are either some variant of VDMOS (the die backside is doped for the drain/collector connection, built around a lightly doped wafer, which becomes the drift region) or superjunction (the drift region is alternating N/P columns).  In either case, the backside is always a terminal, and in TO-247 packages, almost always physically connected to the center pin (cut and formed from a single piece of tin plated copper).
There are isolated tab devices, usually using DBC (an aluminum nitride type ceramic insulator with copper plates direct-bonded to both sides). I suppose they could've used these, but I doubt the cost would be justified.  (They probably did use hardface anodize... it's cheap, and easy to apply to a lightweight aluminum heatsink, which probably needs anodizing anyway for corrosion protection.)
Offline Dago
« Reply #12 on: February 27, 2014, 07:47:49 am »
There are loads of devices with insulated tabs. First one I found with 10s of searching: https://www.fairchildsemi.com/ds/HG/HGTG30N60B3.pdf
« Reply #13 on: February 27, 2014, 03:12:08 pm »
Would the isolated tab not make it harder to keep the IGBT cool?
« Reply #14 on: February 27, 2014, 06:57:53 pm »
Does not look like it does, seeing as max thermal resistance is 0.6 C/W. Even copper is around that figure, so the internal isolation must be pretty good.
« Reply #15 on: February 27, 2014, 07:08:37 pm »
I think I recall them saying the vehicle is 86% battery-to-wheel efficiency
Probably breaks down around 95% inverter efficiency, 95% motor and 95% battery.
This means at peak power the inverter is dissipating over 10kW, or each device on average around 120W... (assuming IGBTs are the biggest lost, sounds about right)
So they'd better get the cooling right!
« Last Edit: February 27, 2014, 07:32:37 pm by tom66 »
Offline T3sl4co1l
« Reply #16 on: February 27, 2014, 10:33:45 pm »
Did you paste the wrong link by accident..?
Here's an example,
http://www.digikey.com/product-detail/en/IXGR48N60C3D1/IXGR48N60C3D1-ND/2117159
but it's a little more expensive (though the ratings aren't quite equal, either).
Offline mos6502
  • Country: aq
« Reply #17 on: February 27, 2014, 11:14:01 pm »
Here's an example,
That's an interesting part. Funny enough, a big FET like the FDH44N50 costs about the same, has very similar ratings, and would dissipate about the same amount of power at 55A (about 160 Watts):
http://www.digikey.com/product-search/en?WT.z_header=search_go&lang=en&site=us&keywords=fdh44n50&x=0&y=0&formaction=on
But those aren't available with an insulated tab.
for(;;);
« Reply #18 on: February 27, 2014, 11:53:30 pm »
It seems that they are using these from a little hint by Marco
http://datasheet.octopart.com/IXGX120N60B-IXYS-datasheet-11760468.pdf
about $20 in onesies, $10 in high quantities.
Driven by a TC4451 IGBT driver, which is a Microchip part. A 12 amp IGBT driver; I've never seen one that high before, I thought most of them topped out around 4 to 5 amps.  Microchip in a Tesla -- a pretty big endorsement of Microchip's analog/power division; then again, I have often found them to be the only manufacturer of some parts I needed.  Perhaps this was the same in Tesla's case.
Tab is not isolated.
« Last Edit: February 27, 2014, 11:57:28 pm by tom66 »
Offline T3sl4co1l
« Reply #19 on: February 28, 2014, 12:46:20 am »
The only other high capacity gate drivers I know of, offhand, are the IXDD614 series (414, 614, different packages, invertering/non, etc...), which go up to 30A or so.  There are probably others, I just haven't looked in forever.
Micrel often second-sources chips like that... or Microchip is the second source, I don't know. :P  Offhand, Digikey lists the MIC4451 (non stock), though they don't have an exposed-pad type (which is probably a good idea for something like this?), which Microchip does.
« Reply #20 on: February 28, 2014, 01:13:31 am »
no. it is not a problem. there is still a heat transfer inside. either fully depleted silicon or a slice of aluminum oxide.
we can grow depleted silicon on the backside of the wafer. that acts as barrier.
Tesla uses a 3 phase 4 pole induction motor. Other EV's are all permanent magnet BLDC constructions.
« Last Edit: February 28, 2014, 01:15:45 am by free_electron »
« Reply #21 on: February 28, 2014, 01:19:56 am »
Well it's irrelevant because they use a nonisolated tab so I figure they just isolate them externally, not sure how though.
Offline T3sl4co1l
« Reply #22 on: February 28, 2014, 03:54:36 am »
Isolated devices are built with traditional thick film ceramic construction techniques.  An insulator (these days, probably aluminum nitride or oxynitride, but oxide is the classic material) with metal plated on both sides.  The top side is etched (chemically or by laser) to make electrical connections as needed, especially handy if co-pack'd with a diode.
I know this is typical of SOT-227 packages and other modules.  It's probably typical of the isolated types too, but I haven't broken any open yet.
Intrinsic silicon is not used as an insulator, never has been(?), and never will be.  It is impossible in general to use for that purpose.
Offline Psi
« Reply #23 on: February 28, 2014, 04:01:34 am »
Excellent, i know what IGBT i'll be using in my solid state tesla coil upgrade :D.
Offline T3sl4co1l
« Reply #24 on: February 28, 2014, 04:03:55 am »
I've gotta say, I'd love to see a 10HP SSTC :o :o >:D
