How come there are no special polishing tools for this? It all seems crazy to do it chemically because i think the oxide will result in asparities and i dont think you can chemically remove them, you need mechanical cutting i.e. polish??
I think the chemicals leave a pitted surface. When i use my experiances with metal working, you never get a nice finish from electroylsis or acid oxide removal on copper or steel. You need to refinish it with different grades of sandpaper or if its good enough use different mesh sizes of rogues to shine the surface.
With something that needs to be very flat its different but i noticed in general the more you polish something after rust removal the less it rusts.
Even going over it with a wire wheel after chemical removal helps, but you really need to remove material down to the lowest pit and polish or lap.
Imo if you have a thin mound of metal on a surface it has more exposure to oxide per surface area vs volume so oxide grows on it and strains it or something and it causes shifts.
I wanna see electron microscope pictures of the effects of all this deoxit voodoo. Chemical polishing is hard to do (used in semiconductor industry, and it still requires lots of motion). It is against my knowledge of convenctional mechanical behavior.
Now chemical rust removal is a good first step because rust is a ceramic and the metal cutting toolslike polish, sandpaper, or metal brush is all similar or less hard then the oxode layer so unless you have a correct feed and speed to work under the oxide your cutting tools take a beating ( yes sandpaper and a grinding wheel are cutting the same as a mill, it makes microscopic metal coils), if you remove the oxide first your cutting tool wears less and maintains a better cutting edge (i.e. the grits of polish or sandpaper) so your surface finish is better because there is less deformation and more cutting. Since the cutting grits of polish or sand paper maintain a better rake angle for longer.
And the rust tends to absorb oil in its cracks so it cuts the sandpaper less if the metal is clean of it
All I can think of is that the de-oxit forms a conductive pesudometallic layer, similar to aluminum magnaplating, but with gold, to the thickness of the highest asparity (it must have a acceptable range of [ro], (surface finish) to work under). And if its not thick enough, and forms a mount over an asparity, thats where then 'pot cycling' comes into play, where you knock off the high point to get a acceptable conductive layer.
I would think that a re-polish is still superior.
https://www.finishing.com/133/65.shtmlhttps://en.wikipedia.org/wiki/Chromate_conversion_coating
