We assume you haven't powered down the ADC via the PRR0 register.
Besides... You have set the auto trigger bits to free running (000). From the datasheet:
If ADATE in ADCSRA is written to one, the value of these bits selects which source will trigger an ADC
conversion. If ADATE is cleared, the ADTS[2:0] settings will have no effect. A conversion will be triggered
by the rising edge of the selected Interrupt Flag. Note that switching from a trigger source that is cleared
to a trigger source that is set, will generate a positive edge on the trigger signal. If ADEN in ADCSRA is
set, this will start a conversion. Switching to Free Running mode (ADTS[2:0]=0) will not cause a trigger
event, even if the ADC Interrupt Flag is set.
Table 29-6 ADC Auto Trigger Source Selection
ADTS[2:0] Trigger Source
000 Free Running mode
001 Analog Comparator
010 External Interrupt Request 0
011 Timer/Counter0 Compare Match A
100 Timer/Counter0 Overflow
101 Timer/Counter1 Compare Match B
110 Timer/Counter1 Overflow
111 Timer/Counter1 Capture Event
Hint: Seems to imply that no trigger even will occur in free running mode... No trigger event means a new conversion won't be initiated.
cheers,
george.
