For some reason, the regularly used logic families doesn't seem to include a 4bit binary to 7 seg. hex decoder. and for some reason, the standard BCD to 7seg. decodes the input A-F to more or less garbage - very niche symbols at least.
So in the quest of getting a hex display for my data bus on a computer, I've come across a schematic of using an EPROM as a programmable logic, using A0-3 as 4bit input, and D0-7 as 7seg output. Seeing EPROMS being very cheap today, and me having a bucketful, that sounded like the solution! (Because microcontrollers is cheating).
Has anyone tried this? and would one need to buffer the outputs to drive the 7seg display?
--Christoffer
