I have recently heard about the Biefeld-Brown effect, the electrostatic effect, and the electrokinetic effect. (I think he played with all of them.) Anyhow, all of them involve high voltages, charges, and capacitors of various shapes. Apparently, it is important to avoid "edge effects" (whatever they mean) for some reasons (unwanted consequences). I can see why sharp edges at high voltages are more likely to generate corona effects and corresponding power losses from unwanted currents. But, I haven't been able to find out much on why "edge effects" are bad if sufficient anti-corona protection is in place so that obvious arcing and sparking and current does not flow. I'm working with 10-50Kv at less than a milliamp (eg. 100 or 200 microamps), on small devices about 6 inches in size, where all electrodes are encased in epoxy and have no contact with the air.
Could anyone here shed some more light on this topic, or point me to some good web links on the topic? Thank you.
